cgal-discuss - Re: [cgal-discuss] Where to find criteria for mesh rejection?
  • To:
  • Subject: Re: [cgal-discuss] Where to find criteria for mesh rejection?
  • Date: Mon, 25 Jul 2016 09:20:21 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23:1EcfGB0TW4Ifzj07smDT+DRfVm0co7zxezQtwd8ZsegQKvad9pjvdHbS+e9qxAeQG96Ks7Qa06GM7PiocFdDyK7JiGoFfp1IWk1NouQttCtkPvS4D1bmJuXhdS0wEZcKflZk+3amLRodQ56mNBXsq3G/pQQfBg/4fVIsYL+kQsiM14/tiLj60qaQSj0AvCC6b7J2IUf+hiTqne5Sv7FfLL0swADCuHpCdrce72ppIVWOg0S0vZ/or9YwuxhX7vku/soFXaThdLkjVpRZCi4nOiY7/p7Frx7GGEG063EVSXkXnxwAJw/f7RbmFtfevyz/u/ZnyQeTNtHxV6F1E3z29KNsUh7vlGECMxY29WjWjop7i6cN80HpnAB234OBONLdD/F5ZK6IJd4=
On 07/22/2016 06:53 PM, Danish Manzoor Bhatti wrote:
Hi,
Over the past few weeks I've been working with CGAL for computer vision
in robotics. I've had a lot of meshes rejected by "input >> mesh" and
I'm not sure why. Some meshes get accepted after I clean them, others
dont. Can someone point me to where I can find the list of criteria that
causes CGAL::Polyhedron_3<Kernel> to reject a certain mesh? It would be
very helpful. I've had to waste a lot of time randomly trying to clean
meshes hoping that it will get accepted without knowing what to look for.
Please help
If you can't load a mesh into a polyhedron, it means that the mesh is
non-manifold. There are a few functions in CGAL to help you:
orient_polygon_soup() [1] will change face orientation to try to turn a polygon soup to a valid
manifold surface. If not possible, it will duplicate vertices to make
the mesh combinatorially manifold (even if some self-intersection are
obviously introduced)
Use polygon_soup_to_polygon_mesh() [2] to turn a manifold polygon soup
into a polyhedron.
In the next release the function is_polygon_soup_a_polygon_mesh() [3]
will indicate if a polygon soup is a valid manifold surface.
Sebastien
[1] http://doc.cgal.org/latest/Polygon_mesh_processing/group__PMP__repairing__grp.html#gab1ea30e030c62bf018afa4578d591f19
[2] http://doc.cgal.org/latest/Polygon_mesh_processing/group__PMP__repairing__grp.html#gac8fe80db9800265922ce469c36d97baa
[3] https://cgal.geometryfactory.com/CGAL/doc/master/Polygon_mesh_processing/group__PMP__repairing__grp.html#ga8b9d12d817b5cc76f5a42d74eac75bf3
