Re: [cgal-discuss] CGAL::intersection on Polygon_2 needs exact constructs kernel?
- To:
- Subject: Re: [cgal-discuss] CGAL::intersection on Polygon_2 needs exact constructs kernel?
- Date: Sat, 13 Aug 2016 10:37:53 +0300
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:YOaWPRLjw74lRxlU39mcpTZWNBhigK39O0sv0rFitYgUL/nxwZ3uMQTl6Ol3ixeRBMOAuqsC0rOd6vq5ESxYuNDa4ShEKMQNHzY+yuwu1zQ6B8CEDUCpZNXLVAcdWPp4aVl+4nugOlJUEsutL3fbo3m18CJAUk6nbVk9GO35F8bogtit0KjqotuIMlwO3WP2OOkrZFXu9EOK55FQ2dMjYo8KiTLx6kNSfOpXwW46bXmypD3bovmKwZh47i5LsOgg/cMTGY/zfqA/UKAKRG9+azN9t4XXskzIQgKLo3cdSW4LiQFgAg7f7Ri8UI2inDH9s79Q1ijSE8r5QLR8DTms7qlsRxLsoCgCPj89tmrQj5oj3+pgvBu9qkknkMbva4aPOa8mcw==
It's not.
An intersection requires the construction of possibly a new point. ____ _ ____ _
/_____/_) o /__________ __ //
(____ ( ( ( (_/ (_/-(-'_(/
_/
_/
On Fri, Aug 12, 2016 at 4:58 PM, Pol Monsó Purtí <> wrote:
Using the fake ones I get a warning and an exception:Using the original ones I get the exception:Attached the ascii polygon's points.Fiddleing I've tried making two simple polygons as well, they too provoke exceptions, thus why I'm starting to suspect the exact constructs are necessary.I've been trying to retrieve the intersection of two polygons.I always get pre_condition exceptions which I can't seem to resolve and I'm starting to wonder wether it's not possible to make polygon_2 intersections without the exact constructs.
precondition violation!_expression_ : (m_traits.compare_y_at_x_2_object()(p, cv1) == EQUAL) && (m_traits.compare_y_at_x_2_object()(p, cv2) == EQUAL)
File : C:\Users\Pol\codeheli\portho\libs\cgal\Arrangement_on_surface_2\include\CGAL/Arr_segment_traits_2.h
Line : 580
The artificial ones are:
Polytype bbox1;
989703.429, 6583768.645
976393.049, 6583768.645
976493.049, 6587550.584
989603.429, 6587550.584
976393.049, 6587650.584
989703.429, 6587650.584
Polytype bbox2;
985000, 6584000
980000, 6584000
980000, 6587000
985000, 6587000
CGAL warning: check violation!_expression_ : valid_orientation
File : C:\Users\Pol\codeheli\portho\libs\cgal\Boolean_set_operations_2\include\CGAL/Boolean_set_operations_2/Gps_polygon_validation.h
Line : 312
CGAL error: precondition violation!
_expression_ : is_valid_unknown_polygon(p, t)
File : C:\Users\Pol\codeheli\portho\libs\cgal\Boolean_set_operations_2\include\CGAL/General_polygon_set_on_surface_2.h
Line : 45
- [cgal-discuss] CGAL::intersection on Polygon_2 needs exact constructs kernel?, Pol Monsó Purtí, 08/12/2016
- Re: [cgal-discuss] CGAL::intersection on Polygon_2 needs exact constructs kernel?, Efi Fogel, 08/13/2016
