cgal-discuss - Re: [cgal-discuss] Question regarding the triangulation of several iso-contours in a single grey level image
  • To:
  • Subject: Re: [cgal-discuss] Question regarding the triangulation of several iso-contours in a single grey level image
  • Date: Wed, 24 Aug 2016 10:32:19 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23:kKr0uRxsCiasdIrXCy+O+j09IxM/srCxBDY+r6Qd0eMWIJqq85mqBkHD//Il1AaPBtSCrakZwLOP7eigATVGusfZ9ihaMdRlbFwssY0uhQsuAcqIWwXQDcXBSGgEJvlET0Jv5HqhMEJYS47UblzWpWCuv3ZJQk2sfTR8Kum9IIPOlcP/j7n0oMyKJV4Vz2PkP/sydEzw9lSJ8JFOwMNLEeUY8lPxuHxGeuBblytDBGm4uFLC3Pq254Np6C9KuvgspIZqWKT+eLkkH/QDVGx1ezN92Mq+vhbKSU6D52AXT34NuhtOGQnMqh/gDbnrtS6v/M50xTOXO9G+d7EyVD2/p+dAZzbMzwgKMDs07HvGpMV7kKVBsVPr70h7ypPObYeJcuB/eK7UYPsRSmNFGMFLWHoSUcuHc4ITAr9Zbq5jpI7nqg5WoA==
Le Monday 22 August 2016 14:04:36 Joan Hensen a écrit :
> Hey guys,
> I'm using the example Surface_mesher/mesh_a_3d_gray_image.cpp in order to
> triangulate a 3D image.
> Currently, I have a grey level image with several objects in it. Larger and
> smaller ones. When I try to apply 'mesh_a_3d_gray_image' on it some of the
> smaller objects near the image border are missing in the resulting mesh. Is
> this example only applicable if the image contains only the iso-contour of
> one single object or can I achive to get meshes for all of them? If yes,
> how :-)?
Hi,
The way the mesh generator engine discovers the mesh domain does not
guarantee
to mesh all the connected components of the mesh domain, even if the meshing
parameters are small enough.
The process can be helped by a custom generation of the initial
triangulation.
In CGAL-4.9-beta1, I have added an example that uses a custom initialization
to ensure that the initial triangulation will have vertices on all connected
components of the input. That example is
CGAL-4.9-beta1/examples/Mesh_3/mesh_3D_image_with_custom_initialization.cpp
As the code of that custom initialization is non-trivial, that code was
extracted to non-documented header files. You can find all the details in the
documentation for CGAL-4.9, section "Domains From Segmented 3D Images, with a
Custom Initialization":
http://doc.cgal.org/4.9/Mesh_3/#title24
and in the the pull-request on Github:
https://github.com/CGAL/cgal/pull/1115
Laurent Rineau, PhD
