cgal-discuss - Re: [cgal-discuss] finding intersection between two 3D convex hull
  • To:
  • Subject: Re: [cgal-discuss] finding intersection between two 3D convex hull
  • Date: Mon, 29 Aug 2016 09:46:24 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23:6cRI8RdU3J6UBMrv5i7YJ3C+lGMj4u6mDksu8pMizoh2WeGdxc6zbB7h7PlgxGXEQZ/co6odzbGH6ua8AidascbJ8ChbNscdD1ld0YRetjdjKfbNMVf8Iv/uYn5yN+V5f3ghwUuGN1NIEt31fVzYry76xzcTHhLiKVg9fbytScbshsi6n9q/54fUK10RwmHsOPUud17s/VWZ9pFPx9AzcuBpklqBi0ALUtwe/XlvK1OXkkS0zeaL17knzR5tvek8/dVLS6TwcvdwZ7VZCDM7LzJ9v5Wz5lH1ZFDQvT5EDi1Wz0IJUED560TxUZ719yf7reFgwzKyPMvsTLlyVy7xwb1sTUqisyoNPiUl8WzRwuh3lqNcvFrhiBF4xoPIepC7PfFiebnMPJlSEXFFWdxQUDAHB4eUYI4GDu5HNuFd+dqu72ASpAezUFH/TNjkzSVF0yKu0A==
If you want to intersect two convex hulls, you can try using
CGAL::halfspace_intersection_3 or CGAL::halfspace_intersection_with_constructions_3, each face of your
input convex hulls being representing as a half-space.
Best,
Sebastien.
http://doc.cgal.org/latest/Convex_hull_3/group__PkgConvexHull3Functions.html#ga6118d2c46934c541669ab871f8e1fd24
http://doc.cgal.org/latest/Convex_hull_3/group__PkgConvexHull3Functions.html#ga5c2ab0e6e63557e65ad7f2bdc3c351fc
On 08/26/2016 08:52 PM, Vahid Azizi wrote:
Hi all,
I am totally a newbie user and i need some tips for finding intersection
between two 3D convex-hull. I explain what i am doing in below:
I have a mesh which i need to find the adjacent triangles which have
same surface normal, i did this part with my self. After this step i
need to create a surface out of these triangles which i used
convex_hull_3 in CGAL. Now i need to find the bounded convex hull
between two of these convex-hulls after some processing. I read "3D
Boolean operation on nef polyhedra" and some arbitrary pages on internet
but i didn't get what i need to do exactly? The issue is i need to have
the vertices of bounded convex-hull and i didn't get is it possible by
CGAL functionality or not? if it is possible I appreciate if you could
provide me some tips or links. Thank you so much in advance.
Best,
/Vahid/
