cgal-discuss - Re: [cgal-discuss] concave hull 3d (Alpha_Shapes_3) by Ihor
  • To:
  • Subject: Re: [cgal-discuss] concave hull 3d (Alpha_Shapes_3) by Ihor
  • Date: Tue, 30 Aug 2016 01:36:56 -0700 (PDT)
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=SoftFail ; spf=None
  • Ironport-phdr: 9a23:h6SoGhBNAeF7w1d6BtlAUyQJP3N1i/DPJgcQr6AfoPdwSP38pMbcNUDSrc9gkEXOFd2CrakV0qyK7uu5AjRIoc7Y9itdINoUD15NoP5VtjJjKfbNMVf8Iv/uYn5yN+V5f3ghwUuGN1NIEt31fVzYry76xzcTHhLiKVg9fbytScaBx/iwguu98pmWbwRTjyemeptzKg+3pEPfrJo4m4xnf4cxzQGB9npHfP4QxWdvPVWNxketve+/+Zdi92JbvPd3pJ0IarnzY6ltFe8QNz8hKW1gvMA=
I did this goal.
#include <CGAL/Delaunay_triangulation_3.h>
#include <CGAL/Triangulation_hierarchy_3.h>
#include <CGAL/Alpha_shape_3.h>
#include <CGAL/IO/io.h>
#include <iostream>
#include <sstream>
#include <string>
#include <fstream>
#include <CGAL/IO/Writer_OFF.h>
#include <CGAL/Simple_cartesian.h>
using namespace std;
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
typedef CGAL::Alpha_shape_vertex_base_3<K>
Vb;
typedef CGAL::Triangulation_hierarchy_vertex_base_3<Vb> Vbh;
typedef CGAL::Alpha_shape_cell_base_3<K>
Fb;
typedef CGAL::Triangulation_data_structure_3<Vbh, Fb> Tds;
typedef CGAL::Delaunay_triangulation_3<K, Tds>
Delaunay;
typedef CGAL::Triangulation_hierarchy_3<Delaunay>
Delaunay_hierarchy;
typedef CGAL::Alpha_shape_3<Delaunay_hierarchy>
Alpha_shape_3;
typedef Alpha_shape_3::Facet
Facet;
typedef Alpha_shape_3::Edge
Edges;
typedef Alpha_shape_3::Vertex
Vertex;
typedef Alpha_shape_3::Vertex_handle
Vertex_handle;
typedef Alpha_shape_3::Alpha_iterator
Alpha_iterator;
typedef Alpha_shape_3::NT
NT;
typedef Alpha_shape_3::Vertex_iterator Vertex_iterator;
typedef CGAL::Simple_cartesian<double>
Kernel;
typedef K::Point_3
Point_3;
int main(int argc, const char* const argv[])
if (argc != 3)
std::cerr << "\n There have to be three parameters (name of
program, file
with coordinates, coefficient )" << std::endl;
exit(1);
int mode = static_cast<int>(atoi(argv[1]));
std::fstream is(argv[1], std::ios::in);
if (!is)
std::cerr << "\n Could not open file " << argv[1] << " for
reading,
exiting \n";
exit(1);
double coefficient = atof(argv[2]);
std::vector<std::vector&lt;Point_3>> points;
std::vector<Point_3> coord;
char szTempString[1024];
std::string str = "----------End of agglomerate----------";
double dPosX, dPosY, dPosZ;
while (is.getline(szTempString, 1024))
if (szTempString == str)
points.push_back(coord);
coord.clear();
else
sscanf_s(szTempString, "%lf %lf %lf", &dPosX, &dPosY,
&dPosZ);
coord.push_back(Point_3(dPosX, dPosY, dPosZ));
is.close();
for (size_t i = 0; i < points.size(); i++)
Alpha_shape_3 as(points[i].begin(), points[i].end(), 0.001,
Alpha_shape_3::GENERAL);
Alpha_iterator opt = as.find_optimal_alpha(1);
std::cout << "Optimal alpha value to get one connected
component is " <<
std::fixed << std::setprecision(12) << *opt * coefficient << std::endl;
as.set_alpha(*opt * coefficient);
assert(as.number_of_solid_components() == 1);
// collect all regular facets
std::vector<Facet> Facets;
as.get_alpha_shape_facets(std::back_inserter(Facets),
Alpha_shape_3::REGULAR);
std::stringstream pts;
std::stringstream ind;
for (size_t i = 0; i < Facets.size(); i++)
Facet f = Facets[i];
//To have a consistent orientation of the facet,
always consider an
exterior cell
if (as.classify(Facets[i].first) !=
Alpha_shape_3::EXTERIOR)
Facets[i] = as.mirror_facet(Facets[i]);
CGAL_assertion(as.classify(Facets[i].first) ==
Alpha_shape_3::EXTERIOR);
int indices[3] = { (Facets[i].second + 1) % 4,
(Facets[i].second + 2) %
4, (Facets[i].second + 3) % 4 };
/// according to the encoding of vertex indices, this
is needed to get a
if (Facets[i].second % 2 == 0)
std::swap(indices[0], indices[1]);
pts << Facets[i].first->vertex(indices[0])->point()
<< "\n" <<
Facets[i].first->vertex(indices[1])->point() << "\n" <<
Facets[i].first->vertex(indices[2])->point() << "\n";
ind << "3 " << 3 * i << " " << 3 * i + 1 << " " << 3
* i + 2 << "\n";
std::ofstream off_file;
std::stringstream ss;
ss << "agglomerate[" << i << "].off";
off_file.open(ss.str(), std::ios::out);
off_file << "OFF " << "\n" << 3 * Facets.size() << "
" << Facets.size()
<< " 0\n";
off_file << pts.str();
off_file << ind.str();
return 0;
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/concave-hull-3d-Alpha-Shapes-3-by-Ihor-tp4662131p4662186.html
