Re: [cgal-discuss] The exact algorithm and references of CGAL's 3DDelaunay function
- To: "" <>
- Subject: Re: [cgal-discuss] The exact algorithm and references of CGAL's 3DDelaunay function
- Date: Thu, 15 Sep 2016 15:42:23 +0300
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Envelope-from:
- Ironport-phdr: 9a23:efS+FxPqlBZ1xhgCOp0l6mtUPXoX/o7sNwtQ0KIMzox0Kfj7rarrMEGX3/hxlliBBdydsKMdzbWL+P27ESxYuNDa4ShEKMQNHzY+yuwu1zQ6B8CEDUCpZNXLVAcdWPp4aVl+4nugOlJUEsutL3fbo3m18CJAUk6nbVk9GO35F8bogtit0KjqotuIMlwO22f2POg6bE3v616A7o9O2coqA51y4yOBmmFPdeVSyDEgDnOotDG42P2N+oV++T9bofMr+p0Ie6z7e6MlUe4QV2x+YChmrPDtrgTJGAuT+mMHACJRiQtNGwGD7RfgX563vDG9rft4wCDdPMv4Svc/Vj2mqqtqUxT1kzxUCzlsumrYg8g1gKNAqw+6vDR+xZTVacebLrA2KqjSdNdfSWtaVdtKTARABJm9Zs0BFbxSE/xfqtwUTrLn5fK37ABFCcmnnj5Mh27/xaQ+2u8hHB/u0wkpHtZIu3PR+oamfJwOWPy4mfGbhQ7IaOlbjG/w
Hi,
That's an interesting thread.
In this article it's said that
The hierachical tessellation makes the asymptopic point location time to be O(() log(n)), which is optimal
Does it mean that using CGAL's
Delaunay_triangulation_3
I can construct 3D dynamic hull for N points, and then locate each new point in time O(log N) ?Are there any asymptotic estimates for the construction of 3d Delaunay triangulation? Is it O(N log N) ?
Thanks,
Ilya Palachev
27.07.2016, 19:32, "Sylvain Pion" <>:
There is also this nice article by Liu and Snoeyink which gives details on several important aspects of implementations of 3D Delaunay triangulations, including the one of CGAL (at the time of 2005 at least) : http://library.msri.org/books/Book52/files/23liu.pdfAlso, for people who want to study the code of CGAL, the "modular view" in git is more organized than the "flat view" that is presented in the releases, so for 3D Delaunay, you can go here : https://github.com/CGAL/cgal/tree/master/Triangulation_32016-07-26 7:58 GMT-07:00 Monique Teillaud <>:The first line shows: #include <CGAL/Delaunay_triangulation_3.h>--Monique Teillaud
https://members.loria.fr/Monique.Teillaud/
INRIA Nancy - Grand Est, LORIA
Institut National de Recherche en Informatique et AutomatiqueHi Monique,
Thank you for your kind advice.I will learn delaunay of CGAL with the references as you mentioned. For CGAL code, I just searched in the CGAL directory about delaunay and find many related files with .h extension. So, can you recommend the target program files that contain the detail of the algorithm implementation of 3d delaunay.
Best wishes!------------------ Original ------------------Date: Tue, Jul 26, 2016 02:43 PMSubject: Re: [cgal-discuss] The exact algorithm and references of CGAL's 3DDelaunay functionHi,Thank you for your nice email.Though the basic incremental algorithm used is very standard (see e.g., Bowyer 1981), the 3d Delaunay triangulation of CGAL is the result of quite a long research process, in particular on robustness issues. You can find a few references here https://members.loria.fr/Monique.Teillaud/biblio/Keyword/CGAL_.html but they are not the only ones.If you want to know more about the details of the implementation, well, the CGAL source code is public…Best regards,--Monique Teillaud
Institut National de Recherche en Informatique et AutomatiqueHi,
I am learning geometric modelling and I want to do some research on 3D
Delaunay. I just tried 3d delaunay function provided by CGAL and was
impressed by its high efficiency. I implemented 3D delaunay myself with
Incremental Insertion Algorithms, but the efficiency was much less than
CGAL.
In addition, it needs to add eight auxiliary bounding points before point
insertion during 3D Delaunay triangulation. In my program, the coordinates
of the eight points was configured with the rules that the bounding box
formed by the eight points can contain the whole point set. But the
triangulation result is a bit different on surface compared with 3D
delaunay of CGAL.
So, I wonder how to find the exact algorithm and references of CGAL's 3D
delaunay function.
Thanks for any help.
View this message in context: http://cgal-discuss.949826.n4.nabble.com/The-exact-algorithm-and-references-of-CGAL-s-3D-Delaunay-function-tp4662096.html
- Re: [cgal-discuss] The exact algorithm and references of CGAL's 3DDelaunay function, Илья Палачев, 09/15/2016
- Re: [cgal-discuss] The exact algorithm and references of CGAL's 3DDelaunay function, Olivier Devillers, 09/15/2016
- Re: [cgal-discuss] The exact algorithm and references of CGAL's 3DDelaunay function, Olivier Devillers, 09/16/2016
