- To: ,
- Subject: [cgal-discuss] CGAL 4.8.2 Released, Computational Geometry Algorithms Library
- Date: Mon, 19 Sep 2016 17:06:43 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
The CGAL Open Source Project is pleased to announce the release 4.8.2
of CGAL, the Computational Geometry Algorithms Library.
Version 4.8.2 is a bug-fix release for version 4.8. The list of fixed bugs
since version 4.8.1 can be seen on Github:
https://github.com/CGAL/cgal/issues?q=milestone%3A4.8.2
The CGAL project is a collaborative effort to develop a robust,
easy-to-use, and efficient C++ software library of geometric data
structures and algorithms, like
- triangulations (2D constrained triangulations, Delaunay triangulations
and periodic triangulations in 2D and 3D),
- Voronoi diagrams (for 2D and 3D points, 2D additively weighted
Voronoi diagrams, and segment Voronoi diagrams),
- Boolean operations on polygons and polyhedra,
- regularized Boolean operations on polygons with curved arcs
- arrangements of curves,
- mesh generation (2D, 3D and surface mesh generation,
surface mesh subdivision and parametrization),
- alpha shapes (in 2D and 3D),
- convex hull algorithms (in 2D, 3D and dD),
- operations on polygons (straight skeleton and offset polygon),
- search structures (kd trees for nearest neighbor search, and
range and segment trees),
- interpolation (natural neighbor interpolation and placement of
streamlines),
- optimization algorithms (smallest enclosing sphere of points or
spheres, smallest enclosing ellipsoid of points, principal
component analysis),
- kinetic data structures
Some modules are distributed under the terms of the LGPL Open Source
license (GNU Lesser General Public License v3 or later versions).
Most modules are distributed under the terms of the GPL Open Source
license (GNU General Public License v3 or later versions).
If your intended usage does not meet the criteria of the
aforementioned licenses, a commercial license can be purchased from
GeometryFactory (http://www.geometryfactory.com/).
For further information and for downloading the library and its
documentation, please visit the CGAL web site: http://www.cgal.org/
Laurent Rineau, PhD
- [cgal-discuss] CGAL 4.8.2 Released, Computational Geometry Algorithms Library, Laurent Rineau (CGAL/GeometryFactory), 09/19/2016
