cgal-discuss - Re: [cgal-discuss] CGAL 4.9 Released, Computational Geometry Algorithms Library
  • To:
  • Subject: Re: [cgal-discuss] CGAL 4.9 Released, Computational Geometry Algorithms Library
  • Date: Wed, 21 Sep 2016 08:15:58 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23:jZ9dgBc7jJUG9yrD5bYchmAUlGMj4u6mDksu8pMizoh2WeGdxc2yZR7h7PlgxGXEQZ/co6odzbGH6ea4ACdZuczJ8ChbNscTB1ld0YRetjdjKfDGIHWzFOTtYS0+EZYKf35e1Fb/D3JoHt3jbUbZuHy44G1aMBz+MQ1oOra9QdaK3Izkn9y1rpbcagENiDumaq5pNz23qx/Qv48Ym9hMMKE0nznOq3BIeuEe/25pLlKem16o5MC5955i9mJKtvMq98NEear/b+I0QOoLX3wdL2kp6Ziz5lH4RgyV6y5EXw==
On 09/19/2016 05:36 PM, Laurent Rineau (CGAL/GeometryFactory) wrote:
> The CGAL Open Source Project is pleased to announce the release 4.9
> of CGAL, the Computational Geometry Algorithms Library.
Debian packages for CGAL 4.9 are now available as well. Simply add
deb http://debian.cgal.org jessie main
deb-src http://debian.cgal.org jessie main
deb http://debian.cgal.org stretch main
deb-src http://debian.cgal.org stretch main
to /etc/apt/sources.list (you only need the pair of lines corresponding
to the release you are using). For sid, packages should be available
from the official Debian repository in a few hours. The packages are called
libcgal12, libcgal-dev, libcgal-qt5-12, libcgal-qt5-dev, libcgal-demo, and
libcgal-ipelets.
In case you want to download the packages manually, have a look at
http://debian.cgal.org/pool/main/c/cgal/ .
See also http://www.cgal.org/FAQ.html#debian_packages .
Best regards,
Joachim
