- To:
- Subject: [cgal-discuss] Problems with CGAL_ImageIO and Homebrew install
- Date: Wed, 28 Sep 2016 12:59:47 -0300
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:05RAvhyITtUnIHvXCy+O+j09IxM/srCxBDY+r6Qd0e4QIJqq85mqBkHD//Il1AaPBtSBrasbwLuN+4nbGkU4qa6bt34DdJEeHzQksu4x2zIaPcieFEfgJ+TrZSFpVO5LVVti4m3peRMNQJW2WVTerzWI4CIIHV2nbEwud76zQ9GZ3p///tvx0qWbWx9Piju5bOE6BzSNhiKViPMrh5B/IL060BrDrygAUe1XwWR1OQDbxE6ktY/jtKJkpi9fsvZk+89bWrjhZIw5S6ZZBXIoKTMb/sru4DjMSwKE53xUcGwIkxdSSy/e6wv7Wd/Ouy/+v+FwkH2bOtbxV7EzcSmu4qwtQxu+23RPDCIw7GyC0p84t6lcuh/0/xE=
Hello everyone,
my name is Ignacio Osorio. I'm doing a (very easy) program that'll extract the surface from a binary volumen saved as inria.
I'm using OSx El Capitan and installing cgal throught macports and homebrew. On an iMac, the macport install works just fine, but the homebrew does not install the libCGAL_ImageIO, therefor, the program can not open the inr file.
On a MacBook pro, the macport install is unable to install cgal, and the homebrew install has the same problems than the iMac.
Is there a way to load and save an .inr and .off (respectively) with out the ImageIO library?
Thx for your time, and kind regards.
Ignacio
- [cgal-discuss] Problems with CGAL_ImageIO and Homebrew install, Ignacio Javier Osorio Wallace, 09/28/2016
