- To:
- Subject: Re: [cgal-discuss] Precondition violation in Delaunay_triangulation_3
- Date: Fri, 30 Sep 2016 08:31:13 +0200
Hi,
If I am not mistaken, your code sample does not contain the definition of Cell_set. It is not defined by CGAL, is it?
Also, it is not clear to me how “conflicts" is constructed by your inserter.
Note that there is an example http://doc.cgal.org/latest/Triangulation_3/index.html#Triangulation_3FindingtheCellsinConflict that seems to do what you need.
Best,
Monique Teillaud
https://members.loria.fr/Monique.Teillaud/
INRIA Nancy - Grand Est, LORIA
Institut National de Recherche en Informatique et Automatique
I am getting an assert on insert_in_hole when inserting a point after removal in Delaunay_triangulation_3:CGAL error: precondition violation!_expression_: c->tds_data().is_in_conflict()File: triangulation_data_structure_3.hLine: 1478The operation is as follows:Delaunay_triangulation_3<Kernel, Data> triangulation;Vertex_handle old_vertex = some_vertex();Point_3 new_point = some_point();triangulation.remove(old_vertex);int li = 0;int lj = 0;Delaunay_triangulation_3::Locate_type locate_type;Cell_handle cell = triangulation.locate(new_point, locate_type, li, lj);if (Tr::VERTEX == locate_type) return;Facet boundary;Cell_set conflicts;triangulation.find_conflicts(new_point,cell,CGAL::Oneset_iterator<Facet>(boundary),std::inserter(conflicts, conflicts.begin()));Vertex_handle new_vertex = triangulation.insert_in_hole(new_point,conflicts.begin(), conflicts.end(),boundary.first, boundary.second);Not quite sure what I am doing wrong, any help is appreciated.
- [cgal-discuss] Precondition violation in Delaunay_triangulation_3, Brown, James 2, 09/29/2016
- Re: [cgal-discuss] Precondition violation in Delaunay_triangulation_3, Monique Teillaud, 09/30/2016
