cgal-discuss - Re: [cgal-discuss] Compiling CGAL 4.9 on MacOs Sierra
  • To:
  • Subject: Re: [cgal-discuss] Compiling CGAL 4.9 on MacOs Sierra
  • Date: Sun, 9 Oct 2016 16:01:11 -0400
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23:EIlIlxYlwPWlEmXgOq6psKX/LSx+4OfEezUN459isYplN5qZpcm8bnLW6fgltlLVR4KTs6sC0LuM9fu/EjVbvN7B6ClEK8McEUddyI0/pE8JPo2sMQXDNvnkbig3ToxpdWRO2DWFC3VTA9v0fFbIo3e/vnY4ExT7MhdpdKyuQtaBx5f/6uap5peGYxlUnCHvJvRpPRCupEPQsNMXiM1sMOEq2x7RqzxJfepRgmhnLFbWkxfn7dqr581f9HFbtPslssJBSq7nZL8QTLpCDT1gPXpmytfssEz7TAaV/HZZdWEXjBtFGUDp5RX+V5brv2OurutwwjOXeMryTK41VC7k465vTBbpkiovKT81/WbLkMt2yqlS9kHy7ydjypLZNdnGfMF1ebnQKIsX
Thanks for catching this !
> On Oct 9, 2016, at 14:58, Marc Glisse
> wrote:
> On Sun, 9 Oct 2016, Pierre-Olivier Dallaire wrote:
>> Hi there,
>> Does anybody have success comping CGAL on the latest macOS Sierra system?
>> I’ve tried many things but always end up with linking problems on GMP:
>> Scanning dependencies of target CGAL_Core
>> [ 50%] Building CXX object
>> src/CGAL_Core/CMakeFiles/CGAL_Core.dir/all_files.cpp.o
>> [ 66%] Linking CXX shared library ../../lib/libCGAL_Core.dylib
>> ld: illegal text-relocation to '___gmp_binvert_limb_table' in
>> /opt/gmp-6.1.1/lib/libgmp.a(mp_minv_tab.o) from '___gmpn_divexact_1' in
>> /opt/gmp-6.1.1/lib/libgmp.a(dive_1.o) for architecture x86_64
>> clang: error: linker command failed with exit code 1 (use -v to see
>> invocation)
>> make[2]: *** [lib/libCGAL_Core.12.0.0.dylib] Error 1
>> make[1]: *** [src/CGAL_Core/CMakeFiles/CGAL_Core.dir/all] Error 2
>> make: *** [all] Error 2
>> Any idea? I have the same issues with versions 4-7 and 4.8.
> It looks like you have only the static version of GMP, but you are trying
> to build the shared version of CGAL.
> Marc Glisse
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://sympa.inria.fr/sympa/info/cgal-discuss
