cgal-discuss - Re: [cgal-discuss] build linking to wrong gmp and mpfr
  • To:
  • Subject: Re: [cgal-discuss] build linking to wrong gmp and mpfr
  • Date: Wed, 26 Oct 2016 08:58:44 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23:DNBywhAGX3JUwN9ZfYrQUyQJP3N1i/DPJgcQr6AfoPdwSP7+p8bcNUDSrc9gkEXOFd2CrakV0ayI4+u5ADNIyK3CmUhKSIZLWR4BhJdetC0bK+nBN3fGKuX3ZTcxBsVIWQwt1Xi6NU9IBJS2PAWK8TWM5DIfUi/yKRBybrysXNWD1YLph6vrosKbSj4LrQL1Wal1IhSyoFeZnegtqqwmFJwMzADUqGBDYeVcyDAgD1uSmxHh+pX4p8Y7oGwD884mosVPWKG/c6UjRqFDFxwnNXo07Yvlr0rtVwyKs0ccU2wZlVJtAgzM6hzmQpC5iSD6suthxC2XJ4WiUbA1UDul6rwwYBDtgSYDcTU+9TeE2YRLkKtHrUf59FREyInObdTNOQ==
I had a similar problem before, I think that it was because cmake may give priority to the system library folders instead of the ones you've given. I don't remember the solution that I used, but I think that you might be able to solve it using the interactive CMake interfaces - either "cmake-gui" or "ccmake" (the latter if you don't have a graphical interface). You can use them to change manually the paths to GMP and MPFR (see section 15.8 of CGAL's installation doc to see which variables must be changed).
Good luck!
Thiago
2016-10-25 21:03 GMT+02:00 Jack Stalnaker <>:
I am trying to build version 4.7. The configuration stage goes well, and finds the updated GMP and MPFR I've installed in non-standard locations. However, at the link stage of the build, the libraries link to the outdated system versions of the library instead.
Why is this happening, and how can I prevent it?
Thanks.
