- To:
- Subject: Re: [cgal-discuss] Inconsistent point/convex hull distance computation values
- Date: Tue, 22 Nov 2016 10:40:23 -0800 (PST)
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=SoftFail ; spf=None
- Ironport-phdr: 9a23:RRkirhBzsRr0iXKSgW+/UyQJP3N1i/DPJgcQr6AfoPdwSP39r8bcNUDSrc9gkEXOFd2CrakV0KyM7uu5ATFIoc7Y9itdINoUD15NoP5VtjJjKfbNMVf8Iv/uYn5yN+V5f3ghwUuGN1NIEt31fVzYry76xzcTHhLiKVg9fbytScaBx/iwguu98pmWbwRTjyemeptzKg+3pEPfrJo4m4xnf50w0D6TkjMcfu1ZxWR1IFO7kBP158P295lmpXcD88k9/tJNBP2pN58zSqZVWWwr
Thanks a lot Sebastien. That was in fact the issue...
Just to confirm, the closest point that /closest_point_and_primitive/ call
gives me is the closest point ON the mesh, right? It's not giving me the
closest vertex or anything is it?
Thanks again
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Inconsistent-point-convex-hull-distance-computation-values-tp4662388p4662393.html
- [cgal-discuss] Inconsistent point/convex hull distance computation values, SirM2X, 11/22/2016
- Re: [cgal-discuss] Inconsistent point/convex hull distance computation values, Sebastien Loriot (GeometryFactory), 11/22/2016
- Re: [cgal-discuss] Inconsistent point/convex hull distance computation values, SirM2X, 11/22/2016
- Re: [cgal-discuss] Inconsistent point/convex hull distance computation values, Sebastien Loriot (GeometryFactory), 11/23/2016
