- To:
- Subject: Re: [cgal-discuss] Converting Tetgen triangulation to CGAL
- Date: Wed, 30 Nov 2016 08:16:22 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=None ; spf=None
- Ironport-phdr: 9a23:zfu88RfZGVvxc98v1nUxDUIqlGMj4u6mDksu8pMizoh2WeGdxc2zYR7h7PlgxGXEQZ/co6odzbGH6Oa7CSdZuczJ8ChbNscTB1ld0YRetjdjKfDGIHWzFOTtYS0+EZYKf35e1Fb/D3JoHt3jbUbZuHy44G1aMBz+MQ1oOra9QdaK3IyB/rvtoNiLP00I2WL8MvtOK0C9ogzV88UXmoB/Mb0Zyx3To3IOdf4F63lvIAevnxH579z43Jln4SFZvfRpo85HVbf/dqI+Zb1TA3I6Lm8v7d+tvAWVHljH3WcVTmhDykkAOAPC9hyvA8/8
So if I additionally add the cell neighbors and the infinite cells, it should work like I did it?
Thanks!
Thomas
On 11/29/2016 05:26 PM, Andreas Fabri wrote:
Not only you are responsible for the neighbor, but CGAL has
also the infinite cells, incident to the infinite vertex,
in case tetgen has no infinite vertex.
andreas
On 29/11/2016 17:23, Thomas Holzmann wrote:
Hi all,
I created a constrained Delaunay triangulation in 3D with Tetgen and
want to convert it now to a CGAL triangulation. As it is no Delaunay
triangulation anymore, I try to create an unrestricted
CGAL::Triangulation_3<CGAL::Exact_predicates_inexact_constructions_kernel,CGAL::Triangulation_data_structure_3<Vbh,
Cb> > wit the data from the CDT.
When I use the "normal" insert function to incrementally create the
triangulation, I cannot directly influence the structure of the
triangulation and therefore, as I want to keep the structure, this is
not an option for me (am I right?).
So I tried to directly add the vertices and cells in the TDS using:
v1 = cgalTriangulation.tds().create_vertex(cgal_pt);
cell = cgalTriangulation.tds().create_cell(v1, v2, v3, v4);
However, it seems as if the cells are not added.
Here are the statistics of the triangulation after adding the data:
number_of_vertices() = 253792
number_of_finite_facets () = 0
number_of_finite_cells () = 0
cgalTriangulation.is_valid(true) says:
valid data structure
valid triangulation
Do I also need to set the cell neighbors and/or facets? Or am I
completely wrong with my approach?
Any help would be appreciated!
Thomas
Dipl.-Ing. Thomas Holzmann
TU Graz - Institut fuer Maschinelles Sehen und Darstellen
Graz University of Technology - Institute for Computer Graphics & Vision
Inffeldgasse 16/II, 8010 Graz, Austria
http://www.icg.tugraz.at/
phone: +43 316 873 5091
- [cgal-discuss] Converting Tetgen triangulation to CGAL, Thomas Holzmann, 11/29/2016
- Re: [cgal-discuss] Converting Tetgen triangulation to CGAL, Andreas Fabri, 11/29/2016
- Re: [cgal-discuss] Converting Tetgen triangulation to CGAL, Thomas Holzmann, 11/30/2016
- Re: [cgal-discuss] Converting Tetgen triangulation to CGAL, Andreas Fabri, 11/30/2016
