- To:
- Subject: Re: [cgal-discuss] Minowski sum for non-polygons?
- Date: Thu, 22 Dec 2016 06:24:28 -0800 (PST)
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=SoftFail ; spf=None
- Ironport-phdr: 9a23:4XSZVxADC5BYqs6FRtthUyQJP3N1i/DPJgcQr6AfoPdwSP39rsbcNUDSrc9gkEXOFd2CrakV0KyG7+u+ByRAuc/H6y9SNsQUFlcssoY/oU8JOIa9E0r1LfrnPWQRPf9pcxtbxUy9KlVfA83kZlff8TWY5D8WHQjjZ0IufrymUt2as8Pi3O+7/9jfYh5DmSGmSbJ0NhS/6wvL5ecMho43CYY40AfMq31OM7BVxWpyOVeamRDU78y1upl5/HID6Loa68dcXPCiLOwDRrtCAWF+Pg==
Hi Efi,
An exception is raised for that type of degenerate polygon.
CGAL_precondition (pgn.is_simple());
The first test in "bool is_simple_polygon(...)" checks for duplicate
vertices.
Which our degenerate polygon fails.
(Then I think it tests for intersecting edges.)
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Minowski-sum-for-non-polygons-tp4662427p4662433.html
- [cgal-discuss] Minowski sum for non-polygons?, KHartmann, 12/20/2016
- Re: [cgal-discuss] Minowski sum for non-polygons?, Efi Fogel, 12/20/2016
- Re: [cgal-discuss] Minowski sum for non-polygons?, KHartmann, 12/21/2016
- Re: [cgal-discuss] Minowski sum for non-polygons?, Efi Fogel, 12/22/2016
- Re: [cgal-discuss] Minowski sum for non-polygons?, KHartmann, 12/22/2016
- Re: [cgal-discuss] Minowski sum for non-polygons?, Efi Fogel, 12/23/2016
