cgal-discuss - Re: [cgal-discuss] access violation in Handle.h (cgal 4.9, apple clang 7.3, C++14)
  • To:
  • Subject: Re: [cgal-discuss] access violation in Handle.h (cgal 4.9, apple clang 7.3, C++14)
  • Date: Thu, 02 Feb 2017 18:15:34 +0100
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23:R36BmBeJHbYYmWUAcSJiJei6lGMj4u6mDksu8pMizoh2WeGdxc66YR7h7PlgxGXEQZ/co6odzbGH7+a+CCdRsd7B6ClEK8McEUddyI0/pE8JPo2sMQXDNvnkbig3ToxpdWRO2DWFC3VTA9v0fFbIo3e/vnY4ExT7MhdpdKyuQtaBx5f/6+fn8JLaZ0BEhSG2fKhpBBSwtwTY8McM0qV4LaNkgD/Av2FFffge/2JuKFuO11bXye6Uu7Fu9CFdp+gw2cdLTaLgbuVyBehcBSk8PmYpotfqsxTKUCOE6XIYFGIMnUwbUED+8BjmU8Kp4WPBve1n1XzCMA==
Le Monday, January 23, 2017 6:34:02 AM CET mistafunk a ?crit :
> hi
> i am seeing an access violation in Handle.h:56. for some reason, the
> returned reference by Lazy::zero() does not seem to be valid. the problem
> is reproducible with cgal 4.9 and apple clang 7.3 (-std=c++14). the
> stacktrace
> <http://cgal-discuss.949826.n4.nabble.com/file/n4662484/stacktrace.txt>
> is attached.
> in Lazy::zero(), the macro CGAL_STATIC_THREAD_LOCAL_VARIABLE is used and
> its definition looks like this (tss.h:34, note that apple clang 7.3 does
> not yet support thread_local):
> # define CGAL_STATIC_THREAD_LOCAL_VARIABLE(TYPE, VAR, ARG1) \
> static boost::thread_specific_ptr<TYPE> VAR##_ptr; \
> if(VAR##_ptr.get() == NULL) {VAR##_ptr.reset(new TYPE(ARG1));} \
> TYPE& VAR = * VAR##_ptr.get()
> so i am basically trying to understand how Lazy::zero() can return an
> invalid reference.
> thanks & best,
> simon
How can you tell that it is `Lazy::zero()` that triggers the error? I do not
see that from the backtrace.
Do you have multiple threads?
It could be that a bad JNI call, or a double-free, or a use-after-free, has
corrupted the heap or stack. You should try to reproduce the same issue in a
standalone C++ file, without Java. Doing that, you will probably find out the
issue by yourself. Otherwise, post your code to an online web service, like
gist.github.com and show us the code.
Laurent Rineau, PhD
  • Re: [cgal-discuss] access violation in Handle.h (cgal 4.9, apple clang 7.3, C++14), Laurent Rineau (CGAL/GeometryFactory), 02/02/2017
