cgal-discuss - Re: [cgal-discuss] Fwd: Barycentric subdivision of n-dimensional simplex using CGAL
  • To:
  • Subject: Re: [cgal-discuss] Fwd: Barycentric subdivision of n-dimensional simplex using CGAL
  • Date: Wed, 15 Feb 2017 12:27:20 +0100 (CET)
On Tue, 14 Feb 2017, Muthukumaran Chandrasekaran wrote:
I am new to CGAL. I have installed CGAL 4.8.2
<http://www.cgal.org/2016/09/19/cgal-482/> on the latest version of Ubuntu
I would like some help with writing the following method
*barycentric_subdivide*:
The method should take in the *n+1* vertices (each vertex for me represents
a probability distribution) that define the convex hull (boundary) of
an *n*-dimensional
simplex as input, partition that simplex using barycentric subdivision, and
return *(n+1)!* sub-simplices (with the same dimensionality) as output.
*Input*: *n+1* vertices that define the convex hull of an n-dimensional
simplex. For eg:
For 1D: {(0,1), (1,0)} for 1D,
For 2D: {(0,0,1),(0,1,0),(1,0,0)}, and so on..
*Output*: *(n+1)!* sub-simplices (i.e *(n+1)!* sets of vertices that define
the convex hull of the (n+1)! sub-simplices). For eg:
For 1D: {{(0,1),(0.5,0.5)} , {(0.5,0.5),(1,0)}},
For 2D: {{(0,0,1),(1/3,1/3,1/3),(0,1/2,1/2)} ,
{(0,1,0),(1/3,1/3,1/3),(0,1/2,1/2)}, {(0,0,1),(1/3,1/3,1/3),(1/2,0,1/2)} ,
{(1,0,0),(1/3,1/3,1/3),(1/2,0,1/2)}, {(1,0,0),(1/3,1/3,1/3),(1/2,1/2,0)} ,
{(0,1,0),(1/3,1/3,1/3),(1/2,1/2,0)}, and so on..
I tried running http://doc.cgal.org/latest/Triangulation/#title11 but it
doesn't provide what I want. Any help is greatly appreciated.
You could build a triangulation of your points, which has just one finite cell, then apply a variant of barycentric_subdivide from the example to it (the example works on the TDS, you would want to work on a full triangulation, with points with coordinates), and iterate on the resulting finite cells.
Otherwise, you'll have to implement it yourself, it isn't hard to do recursively: get the barycentric subdivision of each facet, and append the centroid to them.
Marc Glisse
