- To:
- Subject: Re: [cgal-discuss] Problem when changing from inexact to exact kernel
- Date: Wed, 15 Feb 2017 15:28:02 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:g+6vRhAw8I6FE5cOxZV4UyQJP3N1i/DPJgcQr6AfoPdwSP3yrsbcNUDSrc9gkEXOFd2CrakV1qyO6eu+BCRAuc/H6y9SNsQUFlcssoY/oU8JOIa9E0r1LfrnPWQRPf9pcxtbxUy9KlVfA83kZlff8TWY5D8WHQjjZ0IufrymUt2as8Pi3O+7/9jfYh5DmSGmSbJ0NhS/6wvL5ecMho43YJ08wBLSvnpFfaxywnlpIk7b3znx4cK94IRy3S1bp/U75o8KGfHhe6MiTLtESjEiG28w7czv8xLESF3ctTMnTmwKn08QUED+5xbgU8Kpvw==
On 02/15/2017 03:15 PM, Thomas Holzmann wrote:
Hi,Check that the vertex is not the infinite vertex.
I have a CGAL::Triangulation_3, which I manually created (just converted
a given triangulation to a CGAL data structure) and which is valid (
checked with triangulation.is_valid()). I'm currently using
Exact_predicates_inexact_constructions_kernel, but I'm having problems
when making various geometric operation afterwards. Therefore, I want to
change to Exact_predicates_exact_constructions_kernel.
However, after changing the kernel, the conversion back to a double
representation doesn't work anymore, ie.
double x = CGAL::to_double(vertex->point().x());
results in a segmentation fault sometimes. It doesn't happen for all
vertices, just for some.
The same part of the code with inexact constructions kernel works
without problems.
Does someone have an idea what the problem could be?
Thomas
- [cgal-discuss] Problem when changing from inexact to exact kernel, Thomas Holzmann, 02/15/2017
- Re: [cgal-discuss] Problem when changing from inexact to exact kernel, Sebastien Loriot (GeometryFactory), 02/15/2017
- Re: [cgal-discuss] Problem when changing from inexact to exact kernel, Thomas Holzmann, 02/15/2017
- Re: [cgal-discuss] Problem when changing from inexact to exact kernel, Laurent Rineau (CGAL/GeometryFactory), 02/15/2017
- Re: [cgal-discuss] Problem when changing from inexact to exact kernel, Thomas Holzmann, 02/16/2017
