- To:
- Subject: Re: [cgal-discuss] About how to calculate intersection of three planes
- Date: Fri, 17 Feb 2017 05:17:54 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:NU6Ecx0MNAh8wYmdsmDT+DRfVm0co7zxezQtwd8ZsegTKPad9pjvdHbS+e9qxAeQG96KtrQc1qGJ6eigATVGusnR9ihaMdRlbFwst4Y/p0QYGsmLCEn2frbBThcRO4B8bmJj5GyxKkNPGczzNBX4q3y26iMOSF2kbVImbre9J4jJks7i1/yu44aBJEJTlT+laPVzKg+3pEPfrI4NkI56I+EwzBXO5XBHcuATyWJzLk+IhEXA4ZK785dntihRoPk87NVoUKPgfq1+Q6YLIi4hNjV/38DhvALfTAaJrl8bSGQRjlIILAXC6RzmRIbfuyDmsfBsmWPSadbySqo1Xijk6qNDRxrhiSNBPDk8pjKEwvdshb5W9Ury7yd0xJTZNdmY
On 02/10/2017 03:46 PM, Iván otero wrote:
Hi Sebastien!
Thank you for your help.
I have now this.
Plane_3suelo(Point_3(0,0,0),Vector_3(0,0,-1));//Suelo
Plane_3principal(Point_3(0,0,0),Vector_3(0,1,0));//Principal
Plane_3lateral3(Point_3(0,5,0),Vector_3(-1,0,0));//Lateral3
boost::optional<boost::variant<Point_3,Line_3,Plane_3>>res=CGAL::intersection(suelo,principal,lateral3);
if(res!=boost::none)
if(constPlane_3*pl=boost::get<Plane_3>(&(*res)))
elseif(constLine_3*l=boost::get<Line_3>(&(*res)))
assert(l!=NULL);
elseif(constPoint_3*p=boost::get<Point_3>(&(*res)))
std::cout<<"elpuntoes:"<<p<<std::endl;
*What do you think about store this points an after access to this
structure?*
*In my case I want to iterate with all surface of one space and get this
points.*
Some other beginner question.
How to show or view values of vector and plane?
You can access the plane coefficients, see
http://doc.cgal.org/latest/Kernel_23/classCGAL_1_1Plane__3.html
I use debugger of Qt and try to view this information but I cant see
them like you can see in this image (view cgal_001.png)
But p i can't see it.
p is a pointer, so you need to print *p.
Sebastien.
Could you help me?
*Thanks and best regards.*
2017-02-10 8:05 GMT+01:00 Sebastien Loriot (GeometryFactory)
<mailto:>>:
On 02/09/2017 05:26 PM, Iván otero wrote:
Could you recomend any post link about cgal and about how to
calculate
intersection of 3 planes.
In my case I have normal vector of plane and centroide.
I need to know the know how of cgal to calculate this point
I know mathematics to calculate it but I would like to get this
point
with cgal.
On the other hand If I have a group of data with normal vector and
centroide that are part of a space.
I define space like a bedroom.
I mean a group of six vectors with its six centroids.
Then I would like to calculate all the eight edges of this space.
There is a dedicated intersection function:
http://doc.cgal.org/latest/Kernel_23/group__intersection__linear__grp.html
<http://doc.cgal.org/latest/Kernel_23/group__intersection__linear__grp.html>
you can do something like this:
typedef CGAL:Exact_predicates_exact_construtions_kernel K;
typedef K::Plane_3 Plane_3;
typedef K::Point_3 Point_3;
typedef K::Vector_3 Vector_3;
Plane_3 p1(Vector_3(x,y,x), Point_3(a,b,c));
Plane_3 p2(.....);
Plane_3 p3(.....);
boost::optional< boost::variant< Point_3, Line_3, Plane_3 > > res =
CGAL::intersection(p1, p2, p3);
if (res!=boost::none)
if (const Point_3* pt = boost::get<Point_3>(&(*res)))
// pt is the intersection point of the 3 planes
else
if (const Plane_3* pl = boost::get<Plane_3>(&(*res)))
else
const Line_3* l = boost::get<Line_3>(&(*res));
assert(l!=NULL);
Sebastien.
<https://sympa.inria.fr/sympa/info/cgal-discuss>
Iván Otero González
Skype: ivanoterouvigo
Tlf. Lab. 222: 813499
Tlf. Lab. 218: 813998
Research Line : ARCHITECTURE AND BUILDING
GeoTech
/Applied Geotechnologies Research Group | Geotech__/
Universidade de Vigo
E.E. Minas
36310 Vigo (Spain)
- [cgal-discuss] About how to calculate intersection of three planes, Iván otero, 02/09/2017
- Re: [cgal-discuss] About how to calculate intersection of three planes, Sebastien Loriot (GeometryFactory), 02/10/2017
- Re: [cgal-discuss] About how to calculate intersection of three planes, Iván otero, 02/10/2017
- Re: [cgal-discuss] About how to calculate intersection of three planes, ivanotero76, 02/16/2017
- Re: [cgal-discuss] About how to calculate intersection of three planes, Sebastien Loriot (GeometryFactory), 02/17/2017
