Re: [cgal-discuss] Constrained delaunay triangulation and boost's graph minimum spanning tree
- To:
- Subject: Re: [cgal-discuss] Constrained delaunay triangulation and boost's graph minimum spanning tree
- Date: Wed, 22 Mar 2017 08:26:22 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
On 03/21/2017 02:16 PM, Ch'Gans wrote:
On 21 March 2017 at 15:34, Ch'Gans
wrote:
Hi there,[...]
Actually it looks like i cannot use graph_traits_Triangulation_2.h or
graph_traits_Delaunay_Triangulation_2.h, i would need to write my own
version for CDT, do I?
Indeed, I had to copy and adapt
graph_traits_Delaunay_Triangulation_2.h, first to add support for the
Constrained_Delaunay_Triangulation, and as well for the intersection
tag. On top of that I've modified the weight_map to return 0 for
constrained weight. Surprisingly, it was quite easy.
I just wondered why there's no generic graph_traits that could be used
for the whole (or part of) the triangulation family.
As well, I have the feeling that the weight map is sub-optimal in term
of CPU usage, it doesn't cache the weight value, tho I haven't
verified if the operator[] get called more than once for a given
edge... One might argue that caching is user choice, a decision that
should be based on trade off b/w time and space requirement.
I guess you only have to make the specialization of graph_traits inherit from the one from Delaunay and leave it empty, right?
Sebastien.
Chris
Any clarification or point out are very welcome,
Chris
- [cgal-discuss] Constrained delaunay triangulation and boost's graph minimum spanning tree, Ch'Gans, 03/21/2017
- Re: [cgal-discuss] Constrained delaunay triangulation and boost's graph minimum spanning tree, Ch'Gans, 03/21/2017
- Re: [cgal-discuss] Constrained delaunay triangulation and boost's graph minimum spanning tree, Sebastien Loriot (GeometryFactory), 03/22/2017
- Re: [cgal-discuss] Constrained delaunay triangulation and boost's graph minimum spanning tree, Andreas Fabri, 03/23/2017
- Re: [cgal-discuss] Constrained delaunay triangulation and boost's graph minimum spanning tree, Ch'Gans, 03/24/2017
- Re: [cgal-discuss] Constrained delaunay triangulation and boost's graph minimum spanning tree, Andreas Fabri, 03/24/2017
