- To:
- Subject: Re: [cgal-discuss] Splitting (and simplifying) complex polygon with holes
- Date: Thu, 30 Mar 2017 19:37:43 +0300
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
Check out vertical decomposition; see http://doc.cgal.org/latest/Minkowski_sum_2/classCGAL_1_1Polygon__vertical__decomposition__2.html.
____ _ ____ _
/_____/_) o /__________ __ //
(____ ( ( ( (_/ (_/-(-'_(/
_/
_/
On 30 March 2017 at 17:13, Ch'Gans <> wrote:
Hi there,
I am using an R-Tree (Boost.Geometry) to do spatial queries, my
geomtric items range from small rectangle to long "thick" lines and
complex polygon with holes.
Some of my polygons have a bounding box that nearly covers the whole
set of items my rtree have to deal with, and I need to efficiently do
collision detection b/w the small items and the big polygons. Since
the rtree works with bounding box, I gain nothing when inserting such
"huge" items (their bounding box collides with everyone else's
bounding box).
See attached picture showing a layer of 254 polygons with holes for a
total of ca 70000 points: green are polygon outer boundaries, yellow
are inner boundaries, blue are outer boundary bounding box and magenta
inner boundary bounding box.
I would first like to split these big polygons into a set of smaller
polygons (or rectangles), so that i can take advantage of my rtree. I
don't care about how optimal the partitioning is, my definition of
optimum is: generate quickly sub-polygons that have a small-enough
bounding box.
I looked at CGAL polygon partitioning algos, and the optimal convex
partition looks sexy, but with complexity such as O(n^4) I think it is
no-go for me. The approximate convex partitioning has better
performance, but it seems that in my case it will produce sub-polygons
which will potentially have "big" bounding boxes.
Then there's the triangulation, but given the (very) detailed
"coast-line" of my polygon, it might not be efficient and will
certainly produce a massive amount of triangles. Maybe if i combine
this with multi-polyline simplification it might work... But this
sounds like requiring lot of CPU ...
A simple algo I had in mind is spliting a polygon according to a
coarse grid: lay out a polygon on a grid, then insert a grid cell in
the rtree, iff the cells overlaps the polygon. I thing it's a classic
approach in graphics toolkit (Qt has QRegion for this if i'm not
wrong). this could potentially be refined using a dichotomy
approach... Maybe i could use a CGAL arrangement and monitor face
splitting as i insert horizontal/vertical grid lines...
Anyhow, I thought i would send a word to this mailing list, and see is
someone has an opinion about these sort of problem, maybe i've missed
an awesome CGAL super-weapon, or maybe i'm trying to be too
clever/complicated.
Thanks,
Chris
- [cgal-discuss] Splitting (and simplifying) complex polygon with holes, Ch'Gans, 03/30/2017
- Re: [cgal-discuss] Splitting (and simplifying) complex polygon with holes, Efi Fogel, 03/30/2017
- Re: [cgal-discuss] Splitting (and simplifying) complex polygon with holes, Ch'Gans, 03/31/2017
