[cgal-discuss] How to constrain edge in refine function in Polygon Mesh Processing Package
- To:
- Subject: [cgal-discuss] How to constrain edge in refine function in Polygon Mesh Processing Package
- Date: Tue, 4 Apr 2017 22:54:54 -0500
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Neutral ; spf=None
- Ironport-phdr: 9a23:dqN/TBUsXTqfe1AgRg4L+8FfBb/V8LGtZVwlr6E/grcLSJyIuqrYYhOBt8tkgFKBZ4jH8fUM07OQ6PG8HzRYqb+681k6OKRWUBEEjchE1ycBO+WiTXPBEfjxciYhF95DXlI2t1uyMExSBdqsLwaK+i764jEdAAjwOhRoLerpBIHSk9631+ev8JHPfglEnjSwbLd9IRmssQndqtQdjJd/JKo21hbHuGZDdf5MxWNvK1KTnhL86dm18ZV+7SleuO8v+tBZX6nicKs2UbJXDDI9M2Ao/8LrrgXMTRGO5nQHTGoblAdDDhXf4xH7WpfxtTb6tvZ41SKHM8D6Uaw4VDK/5KptVRTmijoINyQh/W/XhMJ+j79Vrgy9qBFk2YHYfJuYOeBicq/Bf94XQ3dKUMZLVyxGB4Oxd4kAD+0HPeZXroj9p1wOrQajDgetGePk1zhFh3/53aA4yOkhEAXG3AghH9IIt3TUrc71OL0MXu+o0anF1DPOZO5V1zfl8IXEbAwtrPWWUb9zccfd01cjGx7Fg1mKqIHoPjWY3fkXvWeB9epvT+evhnYnqw5vpjivwd8hiozTiYIUzlDI7CF5wIgpKdGhRk52YN+pHIFftyGdMIt2TcciTH9ytCkmzb0GvIa3fCkMyJs52x7Sc+KLf5SM7x75V+ucIS10iGx4dL+/nRq/8EmtxvX5Vsau0VZKqiRFksPLtnAIzxHS6seHR/lm80eg3TaP0wHT6udDIUA1jqrXMYAuzaMtlpYLq0TMAjf2mFnqjK+Rbkgr5ueo5P7jYrn/u5CcNpR0hR3jMqQ1gcyyGv84MwgLX2iD4+uwzrzj/UvjQLVLlPI6iKfZsIqJbfgc86W2CgsQ3oc44AukFB+n1s4ZlD8JNgFrYhWC2rnuPV7cIPflRdiiywC9n2hDxvTCP7vmA46LI3TexuSyNY1h4lJRnVJghetU4IhZX+kM
Subject: How to constrain edge in refine function in Polygon Mesh Processing Package
Hi,
I want to use the refine function in Polygon Mesh Processing Package to refine a triangulation mesh. During the mesh, I want to constrain some edges from being deleted. I found that the refine function can add a "edge_is_constrained_map" as parameter, but I don't know how to create a edge map. (I don't know how to get edge_descripter from a polyhedron)
Here is my code:
Here is my code:
#include <CGAL/Polyhedron_3.h>
#include <CGAL/boost/graph/graph_traits_Polyhedron_3.h>
#include <CGAL/IO/Polyhedron_iostream.h>
#include <CGAL/Polygon_mesh_processing/refine.h>
//#include <CGAL/Polygon_mesh_processing/fair.h>
#include <boost/graph/graph_traits.hpp>
#include <fstream>
#include <map>
using namespace std;
typedef CGAL::Exact_predicates_inexact_constructions_kernel Kernel;
typedef CGAL::Polyhedron_3<Kernel> Polyhedron;
typedef Polyhedron::Vertex_handle Vertex_handle;
typedef boost::graph_traits<Polyhedron>::edge_descriptor ED;
typedef boost::graph_traits<Polyhedron>::vertex_descriptor VD;
typedef Polyhedron::Halfedge edge;
// extract vertices which are at most k (inclusive)
// far from vertex v in the graph of edges
void extract_k_ring(Vertex_handle v,
int k,
std::vector<Vertex_handle>& qv)
std::map<Vertex_handle, int> D;
qv.push_back(v);
D[v] = 0;
std::size_t current_index = 0;
int dist_v;
while (current_index < qv.size() && (dist_v = D[qv[current_index]]) < k)
v = qv[current_index++];
Polyhedron::Halfedge_around_vertex_circulator e(v->vertex_begin()), e_end(e);
do {
Vertex_handle new_v = e->opposite()->vertex();
if (D.insert(std::make_pair(new_v, dist_v + 1)).second) {
qv.push_back(new_v);
} while (++e != e_end);
class RMap{
private:
map<ED, bool> mymap;
public:
bool get(ED& ed){
return mymap[ed];
void put(ED ed, bool v){
mymap[ed] = v;
class VMap{
private:
map<VD, bool> mymap;
public:
bool get(VD& ed){
return mymap[ed];
void put(VD ed, bool v){
mymap[ed] = v;
int main(int argc, char* argv[])
const char* filename = (argc > 1) ? argv[1] : "data/OFF.off";
std::ifstream input(filename);
Polyhedron poly;
if ( !input || !(input >> poly) || poly.empty() ) {
std::cerr << "Not a valid off file." << std::endl;
return 1;
std::vector<Polyhedron::Facet_handle> new_facets;
std::vector<Vertex_handle> new_vertices;
RMap mymap;
VMap imap;
ED e1,e2;
//auto it = poly.vertices_begin();
//auto it = poly.halfedges_begin();
//mymap.put(*it, true);
auto a = add_edge(poly);
mymap.put(a, true);
//imap.put(a, true);
//cout << *it << endl;
CGAL::Polygon_mesh_processing::refine(poly,
faces(poly),
std::back_inserter(new_facets),
std::back_inserter(new_vertices),
CGAL::Polygon_mesh_processing::parameters::density_control_factor(100.).
protect_constraints(true).
edge_is_constrained_map(mymap));//.
//vertex_is_constrained_map(imap));
std::ofstream refined_off("refined.off");
refined_off << poly;
refined_off.close();
std::cout << "Refinement added " << new_vertices.size() << " vertices." << std::endl;
Polyhedron::Vertex_iterator v = poly.vertices_begin();
std::advance(v, 82);
std::vector<Vertex_handle> region;
extract_k_ring(v, 12, region);
//bool success = CGAL::Polygon_mesh_processing::fair(poly, region);
//std::cout << "Fairing : " << (success ? "succeeded" : "failed") << std::endl;
//std::ofstream faired_off("faired.off");
//faired_off << poly;
//faired_off.close();
return 0;
- [cgal-discuss] How to constrain edge in refine function in Polygon Mesh Processing Package, Yongzhou Gu, 04/05/2017
- Re: [cgal-discuss] How to constrain edge in refine function in Polygon Mesh Processing Package, Andreas Fabri, 04/05/2017
- Re: [cgal-discuss] How to constrain edge in refine function in Polygon Mesh Processing Package, Yongzhou Gu, 04/06/2017
