cgal-discuss - Re: [cgal-discuss] Segmentation fault at neighbor access
  • To:
  • Subject: Re: [cgal-discuss] Segmentation fault at neighbor access
  • Date: Fri, 7 Apr 2017 09:27:21 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=None ; spf=None
  • Ironport-phdr: 9a23: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
Did you check that the triangulation as a whole is valid?
andreas
On 07/04/2017 09:03, Thomas Holzmann wrote:
Hi,
I get a weird segmentation fault and I really don't know why. Here is my
code:
if (triangulation_.is_valid(currCell))
for (int k = 0; k < 4; k++)
cellsToProcess.push(currCell->neighbor(k)); // when accessing
neighbor -> segfault
where triangulation_ is a
CGAL::Triangulation_3<CGAL::Exact_predicates_exact_constructions_kernel,
Tds_info>. and currCell is a Cell_handle.
I'm checking the validity of currCell, so the neighbors should exist,
right?
Does someone have an idea why that could happen or how to check the
validity of the neighbors before accessing it in another way?
Thomas
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912 skype: andreas.fabri
