- To: <>
- Subject: [cgal-discuss] Set an initial guess x0 for the quadratic programming program
- Date: Wed, 12 Apr 2017 17:44:09 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=None ; spf=None
- Ironport-phdr: 9a23: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
Hi everyone,
I want to solve an overdetermined system of the form Ax=b and in the same
time bound the x vector.
For this I’ve used the quadratic programming library of CGAL, however, I
wonder if there is a way to give to the solver
an initial guess for the solution, since I have a working set and I want to
optimize it.
Thanks,
Yazid.
- [cgal-discuss] Set an initial guess x0 for the quadratic programming program, yazid, 04/12/2017
