- To:
- Subject: [cgal-discuss] Getting the 3D facets of a 4D Triangulation
- Date: Fri, 21 Apr 2017 20:05:42 -0700 (PDT)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=SoftFail ; spf=None
- Ironport-phdr: 9a23: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
I apologize if the question is obvious, but I am a beginner to CGAL.
Given a 3d cube with vertices 1 to 8, I would obtain a shape made of 6
squares, each of which would define a face of the cube.
If I wanted render this cube, then it would improve my performance if I
transformed all the square faces into triangles.
I would like to take this logic and increase one dimension on it. That means
that, given the 16 vertices of a hypercube, I'd like to find the pyramids
that divide its 3d faces.
I've looked at CGAL and it looks like it would be able to do what I want
with its dD Triangulations, by first triangulating it into 4D pyramids and
finding the 3d faces of those.
For testing, the code below does the triangulation with a 4d pyramid, a
5-cell.
---CODE---
#include <CGAL/Epick_d.h>
#include <CGAL/Triangulation.h>
#include <CGAL/algorithm.h>
#include <CGAL/assertions.h>
#include <CGAL/Kernel_d/Point_d.h>
#include <CGAL/Delaunay_triangulation.h>
#include <iostream>
#include <iterator>
#include <vector>
#include <fstream>
const int D = 4; // we work in Euclidean 4-space
typedef CGAL::Dimension_tag< D > Dim_tag;
typedef CGAL::Epick_d< Dim_tag > Kernel;
typedef CGAL::Epick_d< Dim_tag >::Point_d Point_4;
typedef CGAL::Triangulation< Kernel > Triangulation;
typedef CGAL::Delaunay_triangulation<Kernel> DenTriangulation;
int main()
std::vector<std::vector<double>> coords = {
{ 0.0, 0.0, 0.0, 0.0 },
{ 0.0, 0.0, 0.0, 1.0 },
{ 0.0, 0.0, 1.0, 0.0 },
{ 0.0, 1.0, 0.0, 0.0 },
{ 1.0, 0.0, 0.0, 0.0 },
std::vector<Point_4> points;
for (int i = 0; i < coords.size(); i++) {
Point_4 p = Point_4(D, coords[i].begin(), coords[i].end());
points.push_back(p);
Triangulation t(D); // create triangulation
CGAL_assertion(t.empty());
t.insert(points.begin(), points.end()); // compute triangulation
CGAL_assertion(t.is_valid());
std::cout << "Tn " << t.number_of_finite_full_cells() << std::endl;
int i = 0;
typedef Triangulation::Full_cell_iterator Full_cell_iterator;
typedef Triangulation::Facet Facet;
for (Full_cell_iterator cit = t.full_cells_begin();
cit != t.full_cells_end(); ++cit){
if (!t.is_infinite(cit))
continue;
Facet ft(cit, cit->index(t.infinite_vertex()));
std::cout << "V " << std::endl;
std::cout << ft.full_cell()->vertex(0)->point() << std::endl;
std::cout << ft.full_cell()->vertex(1)->point() << std::endl;
std::cout << ft.full_cell()->vertex(2)->point() << std::endl;
std::cout << ft.full_cell()->vertex(3)->point() << std::endl;
std::cout << ft.full_cell()->vertex(4)->point() << std::endl;
++i;// |ft| is a facet of the convex hull
std::cout << "There are " << i << " facets on the convex hull." <<
std::endl;
i = 0;
for (auto cit = t.finite_full_cells_begin();
cit != t.finite_full_cells_end(); ++cit)
std::cout << cit->vertex(0)->point() << std::endl;
std::cout << cit->vertex(1)->point() << std::endl;
std::cout << cit->vertex(2)->point() << std::endl;
std::cout << cit->vertex(3)->point() << std::endl;
std::cout << cit->vertex(4)->point() << std::endl;
std::cout << "There are " << i << " full_cells on the convex hull." <<
std::endl;
return 0;
It produces the following output:
---OUTPUT---
Tn 1
V
4 0 0 1 0
4 0 0 0 0
4 1 0 0 0
4 0 0 1 0
4 0 1 0 0
V
4 0 0 1 0
4 0 0 0 1
4 0 0 0 0
4 0 0 1 0
4 0 1 0 0
V
4 0 0 1 0
4 1 0 0 0
4 0 0 0 1
4 0 0 1 0
4 0 1 0 0
V
4 0 0 1 0
4 0 0 0 1
4 1 0 0 0
4 0 0 1 0
4 0 0 0 0
V
4 0 0 1 0
4 0 0 0 1
4 1 0 0 0
4 0 0 0 0
4 0 1 0 0
There are 5 facets on the convex hull.
V
4 0 0 0 1
4 1 0 0 0
4 0 0 0 0
4 0 0 1 0
4 0 1 0 0
There are 1 full_cells on the convex hull.
As I understand, it should print the vertexes of 5 pyramids, which it indeed
does, however these pyramids make no sense. They should have 4 vertexes, but
have 5. On the first four, one of the vertex is repeated. On the fifth, it
is the same vertexes of the original pyramid!
I believe that the error may be on the "ft.full_cell()", which I use to get
the vertexes. This seems to get me the full_cell the facet belongs to, which
would be wrong. However, I see not other way to access any information
regarding the facet.
The number of full_cells appears to be right, but since the previous result,
which I made following the tutorial, didn't work out, I am hesitant to trust
that it would work correctly for larger numbers.
Am I going at this the wrong way? Am I not accessing the vertexes of the
facet correctly? Or have I misundertood what the dDTriangulation does?
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Getting-the-3D-facets-of-a-4D-Triangulation-tp4662690.html
- [cgal-discuss] Getting the 3D facets of a 4D Triangulation, GSBicalho, 04/22/2017
- Re: [cgal-discuss] Getting the 3D facets of a 4D Triangulation, Marc Glisse, 04/22/2017
