- To:
- Subject: Re: [cgal-discuss] Why does number of segments==number of faces ?
- Date: Thu, 27 Apr 2017 08:50:00 -0700 (PDT)
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=SoftFail ; spf=None
- Ironport-phdr: 9a23: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
std::cout << "is polygon soup polygon mesh:"
CGAL::Polygon_mesh_processing::is_polygon_soup_a_polygon_mesh(
polygons)
<< std::endl;
Prints is polygon soup polygon mesh:1
and also if it was a polygon soup and not a polygon mesh wouldn't the
following function remove that problem?
CGAL::Polygon_mesh_processing::polygon_soup_to_polygon_mesh(points,
polygons, M);
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Why-does-number-of-segments-number-of-faces-tp4662701p4662703.html
- [cgal-discuss] Why does number of segments==number of faces ?, Iasonm, 04/27/2017
- Re: [cgal-discuss] Why does number of segments==number of faces ?, Sebastien Loriot (GeometryFactory), 04/27/2017
- Re: [cgal-discuss] Why does number of segments==number of faces ?, Iasonm, 04/27/2017
