cgal-discuss - [cgal-discuss] convex hull of points with info
  • To: Cgal-discuss <>
  • Subject: [cgal-discuss] convex hull of points with info
  • Date: Sat, 29 Apr 2017 08:52:11 +0000 (UTC)
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
Hello,
I have a vector of 2D points (N elements) in the plane. I want to make the convex hull of these points. After that, I want to retrieve the vector index of each vertex in the convex hull.
I know that, there is such possibility for triangulation by making use of vector<pair<Point_2, unsigned> >, but when I use paired point in making convex hull, it produces a bunch of errors. how can I do this?
Thanks,
  • [cgal-discuss] convex hull of points with info, parisa rahmani, 04/29/2017
