[cgal-discuss] Fwd: Re: [Gmsh] storing elementary entities of physical group in a variable/list
- To: cgal-discuss <>
- Subject: [cgal-discuss] Fwd: Re: [Gmsh] storing elementary entities of physical group in a variable/list
- Date: Tue, 02 May 2017 11:43:01 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
Sent from Meizu M2 Note
-------- Original message --------
Sender: Julia Fischer
Time: Mon 5/1 23:25
To: "Boehm, Christian Hermann Kurt"
Subject: Re: [Gmsh] storing elementary entities of physical group in a
variable/list
On 1 May 2017 at 10:01, Boehm, Christian Hermann Kurt
wrote:
Hello everybody,
i wonder if something like this is possible, because whatever i try, it just
doesn't work :( :
SetFactory("OpenCASCADE");
Physical Surface("BasePlate", 1) = {1:6};
Physical Surface("Hole1", 2) = {7};
Physical Surface("Hole2", 3) = {8};
Physical Surface(1) += { BooleanDifference{ Surface{ 1:6 }; Delete; }{
Surface{ 7 }; Delete; } };
tmp[ ] = Physical Surface{1}; % I think here is the problem???
Physical Surface(1) += { BooleanDifference{ Surface{ tmp[ ] }; Delete; }{
Surface{ 8 }; Delete; } };
Or is there a better/smarter way to store the elementary entities making up a
physical group,
so that i can reference to them by using the physical group id ?
I hope you can unterstand my issue :).
Help is really appreciated!
Christian B.
Munich University of Applied Sciences
_______________________________________________
gmsh mailing list
http://onelab.info/mailman/listinfo/gmsh
signature.txt
Description: Binary data
- [cgal-discuss] Fwd: Re: [Gmsh] storing elementary entities of physical group in a variable/list, julia.ute.fischer, 05/02/2017
