- To:
- Subject: Re: [cgal-discuss] Qt on alonside with Cgal
- Date: Sat, 10 Jun 2017 10:23:48 +0530
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
Continuing the discussion.
I found AABB_tree easy to use, as it had a QT UI file and looked simple../AABB_demo: /home/sukhraj/Qt5.6.2/5.6/gcc_64/lib/libQt5Core.so.5: version `Qt_5.7' not found (required by /usr/lib/x86_64-linux-gnu/libQt5Svg.so.5)
Attached is the snapshot of CMAKE config.
On Mon, Feb 27, 2017 at 8:15 PM, Laurent Rineau (CGAL/GeometryFactory) <> wrote:
Le Monday, February 27, 2017 3:27:32 PM CET Andreas Fabri a écrit :
> Have a look at CGAL/demo/Polyhedron
The code pointed out by Andreas is rather complex. You might have a look at a
simpler demo, with 2D polygons, in CGAL-x.y/demo/Polygon/.
> On 27/02/2017 14:55, Aswanth Kumar wrote:
> > Hello,
> > Where can I find the examples of cgal with Qt? I worked with CGAL
> > but not with Qt. Where do I need to begin Qt alongside with CGAL?
> > I need to use UI in such a way that we give input polygon or
> > polygon_with_holes via cursor. And how do we get the visibility
> > regions etc.. as an output on Qt. Please suggest what should I
> > refer regarding this.>
> > Regards,
> > Aswanth.
Laurent Rineau, PhD
Sukhraj Singh
Description: PNG image
- Re: [cgal-discuss] Qt on alonside with Cgal, Sukhraj Singh, 06/10/2017
- Re: [cgal-discuss] Qt on alonside with Cgal, Laurent Rineau (CGAL/GeometryFactory), 06/19/2017
