[cgal-discuss] Question regarding the parameter selection for 3D surface mesh generation
- To:
- Subject: [cgal-discuss] Question regarding the parameter selection for 3D surface mesh generation
- Date: Sun, 11 Jun 2017 03:08:26 -0700 (PDT)
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=SoftFail ; spf=None
- Ironport-phdr: 9a23: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
Hello community,
I have given an implicit function. Now I would like to use CGAL in order to
extract a surface mesh. There exists an corresponding example (
http://doc.cgal.org/4.7/Surface_mesher/Surface_mesher_2mesh_an_implicit_function_8cpp-example.html#a5
My aim is to get a accurate mesh with preferably triangles of equal size.
How do I have to choose the parameters (angular bound, radius bound and
distance bound) of the surface mesh default criteria to achieve this? Are
there some rules how to choose these parameters? Right now I only set radius
bound and distance bound to the same value to control the maximal size of
the resulting triangles.
Kind regards,
Joan
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Question-regarding-the-parameter-selection-for-3D-surface-mesh-generation-tp4662760.html
- [cgal-discuss] Question regarding the parameter selection for 3D surface mesh generation, aerodynamic, 06/11/2017
- Re: [cgal-discuss] Question regarding the parameter selection for 3D surface mesh generation, Sebastien Loriot (GeometryFactory), 06/12/2017
