- To:
- Subject: Re: [cgal-discuss] Surface Mesh
- Date: Thu, 29 Jun 2017 15:15:00 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
Le Thursday, June 29, 2017 2:37:18 PM CEST satishs.kamath a ?crit :
> Hello Laurent,
> I'm using CGAL for a similar purpose to generate surface meshes. I see that
> the implicit_surface_3 always takes a bounding sphere. Is it possible to
> pass a bounding box instead of a sphere?
> Thank you
> Satish Kamath
Hi,
No, you have to compute the minimal sphere containing the box, and pass that
sphere as bounding sphere.
Laurent Rineau, PhD
- Re: [cgal-discuss] Surface Mesh, satishs.kamath, 06/29/2017
- Re: [cgal-discuss] Surface Mesh, Laurent Rineau (CGAL/GeometryFactory), 06/29/2017
