- To:
- Subject: Re: [cgal-discuss] Property Maps
- Date: Thu, 13 Jul 2017 13:50:57 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:u0tLRBX0oSMH3K0mdEChsEj/NhjV8LGtZVwlr6E/grcLSJyIuqrYbBCCt8tkgFKBZ4jH8fUM07OQ6PG/HzRYqb+681k6OKRWUBEEjchE1ycBO+WiTXPBEfjxciYhF95DXlI2t1uyMExSBdqsLwaK+i764jEdAAjwOhRoLerpBIHSk9631+ev8JHPfglEnjSwbLdwIRmssQndqtQdjJd/JKo21hbHuGZDdf5MxWNvK1KTnhL86dm18ZV+7SleuO8v+tBZX6nicKs2UbJXDDI9M2Ao/8LrrgXMTRGO5nQHTGoblAdDDhXf4xH7WpfxtTb6tvZ41SKHM8D6Uaw4VDK/5KptVRTmijoINyQh/W/KlMJwgqJVoBWiqRJxzYHbb4OaO+ZxcK7GYdMXR3BMUtpNWyFPAo6xaZYEAeobPeZfqonwv1UCowagCga3Huzv0SNIhn7o0q08zu8vFwbG3BYhH9IJrHTfsdH5OqYMXuCyyanH0ynDb+lW2Dn98ofHbgwhofaWXbNwdMbdx1QkGgTejlWUrozlJTKV1uMRs2SB6upgUfmii2Eiqw5rozivwt0ghZXOhoIQ013J8zhyzogyJd29UkF7YNikHYNWty6ALIR5WcciTH9ytCkmzb0GvJi2dzUJxpQ/3xPSafOKf5KV7h79VOudOzR1iGx/dL+whhu+6Uqtx+7mWsWq31tHrzBJnsTIu30DzRDe6MiKR/1g9Um7wzmPzRrc6uRcLEA0i6XbL5khz6Y1lpUJsETDGjb6mUvzjKOKb0kk9Oel5uX9brXpoZ+cMIB0igXgPag0hsO/BuE4PhAPX2id5+u8yKXu8E/2TblQk/E6jKnUvIrZKMgFvKK0DA5Y3p4m6xmlDjem1NoYnWMALFJAYB+HlIzpO1bUIPD5Cve/n06gkDJvx/3dMb3hB4/CLnnHkLv7Ybl97EtcxBIpzd9D/5JUFq0BIPXrV0Dtu9zXFBs5PxWpzObmE9Vyyp4eWXmUAqKCK6PTsVqI5vo1LOWWZY8Vviz9K/k/6PL0g385gwxVQa781pQebDW0H+9tPl6CSXvqmNYIV2kQ7SQkS+m/wmaPWzdIe3e/WeoY4Ss6D57uTajOQYWgnKaQ8i6wAppMdyEMQgSXFXDydoKYHfIIQC2XK85l1DcDUO7yGMcayRiyuVqimPJcJe3O93hAuA==
On 07/13/2017 01:10 PM, Iasonm wrote:
But that would be inefficient in cases where the mesh is big since as a user
I might I want to find the laplace operator of only one segment and not
every..
Is it possible to use something like region growing? (Beginning on a vertex
within the segment of interest and expanding until the boarder of the
segment is reached)
If you only need one segment, then only collect the faces of the segment.
Of course you can use region growing as soon as you have found a face
of the segment of interest but the gain might be negligible if you
take the runtime of the segmentation algorithm into account.
Sebastien
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Using-CGAL-SurfaceMesh-Property-map-tp4662825p4662827.html
- [cgal-discuss] Property Maps, Iasonm, 07/12/2017
- Re: [cgal-discuss] Property Maps, Sebastien Loriot (GeometryFactory), 07/13/2017
- Re: [cgal-discuss] Property Maps, Iasonm, 07/13/2017
- Re: [cgal-discuss] Property Maps, Iasonm, 07/14/2017
