- To:
- Subject: [cgal-discuss] CGAL without boost
- Date: Sat, 15 Jul 2017 18:30:13 -0400
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
Hi,
Considering that modern C++ has threading, and a lot of system utilities,
would it be possible to have CGAL only use the standard C++ library and
remove the boost dependency?
thanks
- [cgal-discuss] CGAL without boost, Andy Somogyi, 07/16/2017
- Re: [cgal-discuss] CGAL without boost, Andreas Fabri, 07/16/2017
