RE: [cgal-discuss] Determining normals and Poisson surface reconstruction or: convert <Point, Vector> pair to Point_with_normal_3?
- To: <>
- Subject: RE: [cgal-discuss] Determining normals and Poisson surface reconstruction or: convert <Point, Vector> pair to Point_with_normal_3?
- Date: Thu, 20 Jul 2017 16:49:45 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
> > I couldn't get it to work with the jet normals, but with
> You mean the example in the gist didn't work?
> What went wrong? The compilation, the execution crashed. The normals look
wrong?....
Never mind, I had simply forgotten the Eigen library in the CMakeLists.txt
file when I created a separate project for your example code.
I'm using g++ on Linux Mint.
Thanks again
Oliver
- [cgal-discuss] Determining normals and Poisson surface reconstruction or: convert <Point, Vector> pair to Point_with_normal_3?, Oliver Arend, 07/14/2017
- Re: [cgal-discuss] Determining normals and Poisson surface reconstruction or: convert <Point, Vector> pair to Point_with_normal_3?, Andreas Fabri, 07/16/2017
- RE: [cgal-discuss] Determining normals and Poisson surface reconstruction or: convert <Point, Vector> pair to Point_with_normal_3?, Oliver Arend, 07/18/2017
- Re: [cgal-discuss] Determining normals and Poisson surface reconstruction or: convert <Point, Vector> pair to Point_with_normal_3?, Andreas Fabri, 07/18/2017
- RE: [cgal-discuss] Determining normals and Poisson surface reconstruction or: convert <Point, Vector> pair to Point_with_normal_3?, Oliver Arend, 07/20/2017
- Re: [cgal-discuss] Determining normals and Poisson surface reconstruction or: convert <Point, Vector> pair to Point_with_normal_3?, Andreas Fabri, 07/20/2017
- <Possible follow-up(s)>
- RE: [cgal-discuss] Determining normals and Poisson surface reconstruction or: convert <Point, Vector> pair to Point_with_normal_3?, Brian Rupasinghe, 07/20/2017
