cgal-discuss - Re: [cgal-discuss] Periodic regular triangulation?
  • To:
  • Subject: Re: [cgal-discuss] Periodic regular triangulation?
  • Date: Wed, 26 Jul 2017 17:30:43 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=None ; spf=None
  • Ironport-phdr: 9a23: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
Hello,
I'm extremely glad to hear that, thank you very much!
I will have a look at it.
Regards
Bruno Chareyre
On 07/25/2017 01:46 PM, Sebastien Loriot (GeometryFactory) wrote:
On 11/08/2016 05:11 PM, Bruno Chareyre wrote:
Dear CGAL devs, dear all,
We are looking for a way to generate periodic regular triangulations
(3D) for use in yade-dem.
We already have a quick & dirty way to achieve it on the top of the
current regular triangulation class (by inserting periodic replicates of
some of the points), but we are now considering a possible
reimplementation to overcome some limitations.
We are thinking of getting inspiration by comparing the codes
RegularDelaunayTriangulation vs. DelaunayTriangulation then to reproduce
the same logic to extend RegularTriangulation to
PeriodicRegularTriangulation.
Does it sound realistic? or should we expect major differences in the
regular case?
Thanks
Bruno Chareyre
Note that the PR #2212 has been integrated in the master branch of CGAL.
3D periodic triangulations will be also available in the upcoming
release of CGAL.
See https://github.com/CGAL/cgal/pull/2212
Sebastien.
