- To:
- Subject: Re: [cgal-discuss] Undefined symbol while linking against Cgal
- Date: Fri, 4 Aug 2017 15:52:45 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
Did you recompile the CGAL library with GCC?
On 08/04/2017 03:41 PM, bebe0705 wrote:
After investigating further, it appears that it's a compiler issue.
The example were compiled with the default Clang compiler.
My application though has to compile with GCC 7 built from source, since
OpenMP which I need is not supported by Clang.
As you will notice hereunder, GCC was retrieved through homebrew via
*brew install gcc --without-multilib
I switch compilers by adding the following two lines before project() in my
CMakeLists.txt:
set(CMAKE_C_COMPILER /usr/local/Cellar/gcc/7.1.0/bin/gcc-7 CACHE STRING "C
Compiler" FORCE)
set(CMAKE_CXX_COMPILER /usr/local/Cellar/gcc/7.1.0/bin/g++-7 CACHE STRING
"C++ Compiler" FORCE)
If I do so in the Poisson_surface_reconstruction_example, then I am getting
the same undefined symbol errors. However removing them and letting the
system use Clang allows the build to proceed.
Any thoughts?
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Undefined-symbol-while-linking-against-Cgal-tp4662876p4662877.html
- Re: [cgal-discuss] Undefined symbol while linking against Cgal, bebe0705, 08/04/2017
- Re: [cgal-discuss] Undefined symbol while linking against Cgal, Sebastien Loriot (GeometryFactory), 08/04/2017
