- To:
- Subject: Re: [cgal-discuss] Vertices are not outputting with this point cloud data
- Date: Wed, 9 Aug 2017 21:09:41 +0530
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
It should be better if saved file opened by Graphite or Geomesh GUI. You can see vertices as well as attribute of edges information of mesh....
On Wed, Aug 9, 2017 at 7:52 AM, etaylork <> wrote:
I am using the code given from the CGAL library in the demo folder called
triangulation_3 program. The program is saving the vertices and I am using
Qt software to display the image but the vertices are not being displayed
when I run the program. It saves to an array list but won't show on the
window. Every other file i put in builds a triangulation but this one.
https://searchcode.com/codesearch/view/22112677/
this is the link to part of my code that i have been using for this project
Thank You,
View this message in context: http://cgal-discuss.949826.n4.nabble.com/Vertices-are-not-outputting-with-this-point-cloud-data-tp4662888p4662913.html
thanks and regards
mobile:9163016823
- [cgal-discuss] Vertices are not outputting with this point cloud data, etaylork, 08/08/2017
- Re: [cgal-discuss] Vertices are not outputting with this point cloud data, Sebastien Loriot (GeometryFactory), 08/08/2017
- Re: [cgal-discuss] Vertices are not outputting with this point cloud data, etaylork, 08/09/2017
- Re: [cgal-discuss] Vertices are not outputting with this point cloud data, Biswajit Biswas, 08/09/2017
- Re: [cgal-discuss] Vertices are not outputting with this point cloud data, Sebastien Loriot (GeometryFactory), 08/17/2017
- Re: [cgal-discuss] Vertices are not outputting with this point cloud data, etaylork, 08/21/2017
