cgal-discuss - Re: [cgal-discuss] how i solve no member named error
  • To:
  • Subject: Re: [cgal-discuss] how i solve no member named error
  • Date: Fri, 18 Aug 2017 08:27:06 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23:EwMixxBNN48zpHFfKAaBUyQJP3N1i/DPJgcQr6AfoPdwSP3zo8bcNUDSrc9gkEXOFd2Crakb26yL6+jJYi8p39WoiDg6aptCVhsI2409vjcLJ4q7M3D9N+PgdCcgHc5PBxdP9nC/NlVJSo6lPwWB6i760TlHERr2MU95J//+B5XJp8WxzeG7vZPJMCtSgz/oK4h/JhytsQTcsIEyhpFjLbp5ijTEpX5FZ/5H62pjOVWJjle2rpOr+Jl58iNM/fcl38FFWKT+Oa8/SOoLX3wdL2kp6Ziz5lH4RgyV6y5EXw==
I'm clueless here. The only thing I see is that the Qt version you are
using is not the one you expect (Can you check that in the CMakeCache.txt?)
Sebastien
On 08/17/2017 12:34 PM, Servenaz wrote:
cmake output :
-- Build type: Release
-- USING CXXFLAGS = ' -frounding-math -O3 -DNDEBUG'
-- USING EXEFLAGS = ' '
-- Targetting Unix Makefiles
-- Using /usr/bin/c++ compiler.
-- Code taken from Git branch: CGAL4_10
-- Requested component: Qt5
-- Requested component: MPFR
-- Requested component: GMP
-- Found QGLViewer:
/home/pc/Downloads/libQGLViewer-2.6.4/QGLViewer/libQGLViewer-qt5.so.2
-- Configuring done
-- Generating done
-- Build files have been written to:
/home/pc/Projects/cgal/AABB_tree/demo/AABB_tree
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/how-i-solve-no-member-named-error-tp4662922p4662939.html
