[cgal-discuss] Easiest way to extract an edge_to_face vector from a surface mesh
- To:
- Subject: [cgal-discuss] Easiest way to extract an edge_to_face vector from a surface mesh
- Date: Fri, 15 Sep 2017 09:53:24 -0700 (MST)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
- Ironport-phdr: 9a23:zmIC3RKzkARPVjqjR9mcpTZWNBhigK39O0sv0rFitYgXLPTxwZ3uMQTl6Ol3ixeRBMOAtKIC1rKempujcFJDyK7JiGoFfp1IWk1NouQttCtkPvS4D1bmJuXhdS0wEZcKflZk+3amLRodQ56mNBXkiybsvHtLQl2/blItZ7e9JomHhMu+06W++obYfh5TrDu7e7J7ahus/ivLscxDoIJ5LaA0gk/Qu2dPf+lQyEtnIFuSm1D34cLmr80ryDhZp/90rp0Iaq79ZaltFuQAAQ==
Hello,
given a CGAL::Surface_Mesh<SomeKernel> what is the easiest way to extract
mesh "connectivity" vectors like for example an edge_to_face vector of which
the ith position holds another vector which holds the indices of all the
faces that are adjacent to the ith edge?
I tried:
for (CGALSurfaceMesh::edge_index ei : m_M.edges()) {
CGALSurfaceMesh::face_index f0(m_M.halfedge(ei, 0));
CGALSurfaceMesh::face_index f1(m_M.halfedge(ei, 1));
std::vector<size_t> facesOfEdge{size_t(f0), size_t(f1)};
edge_to_face[size_t(ei)] = facesOfEdge;
the above gives face indices that are as big as twice the number of faces in
the mesh. For example when the mesh has 90 faces I would get using the above
indices up to 179. Why does the above not work and could you suggest me
another way to get the needed connectivity vector?
- [cgal-discuss] Easiest way to extract an edge_to_face vector from a surface mesh, Iasonm, 09/15/2017
- Re: [cgal-discuss] Easiest way to extract an edge_to_face vector from a surface mesh, Sebastien Loriot (GeometryFactory), 09/18/2017
