cgal-discuss - Re: [cgal-discuss] 3D Mesh: Strange result when using a field for size
  • To:
  • Subject: Re: [cgal-discuss] 3D Mesh: Strange result when using a field for size
  • Date: Fri, 29 Sep 2017 18:00:55 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23:KoPJsRFe7yw8mZQjgJU9dJ1GYnF86YWxBRYc798ds5kLTJ76rsywAkXT6L1XgUPTWs2DsrQf1LqQ7viocFdDyKjCmUhKSIZLWR4BhJdetC0bK+nBN3fGKuX3ZTcxBsVIWQwt1Xi6NU9IBJS2PAWK8TXhpQIVTx7wPA4wKuXuEZPJlOy20fqz8tvdeVZmnj24NPlWJQisoAPN/vMXh4ZrN+5x4TTghjxnduNTyH9yNHyalAr7/NbxttY39y1Nof8n64haUKP3drkQRrNRCHIhKW9jt56jjgXKUQbavihUaW4RiBcdWwU=
Le Friday, September 29, 2017 5:32:04 PM CEST Michael Bieri a écrit :
> Hi,
> I attached an image of a mesh. It's a screenshot where you see the top of a
> block containing two cylinders and another material at the top and bottom.
> The data is given as a segmented image. I do protect features of the image
> as given below.
> I over and over again observe those relatively large, flat triangles around
> the phase boundaries as well as along the outer edges. I tried around for
> hours, but I don't get any grasp where they come from.
> I tried all sorts of mesh criteria, combing various of those options:
> Mesh_criteria
> criteria(facet_angle=30, facet_size=cell_size_fct,
> facet_distance=cell_size_fct, cell_radius_edge_ratio=3,
> cell_size=cell_size_fct);
> The cell_size_fct gives a value that seems to correspond to the elements
> inside the phase, but seems to be ignored in the elements at the boundary.
> Where does this strange behavior around the phase and outer boundary come
> from?
It probably comes from the mesh of 1d features. Try to add:
edge_size=cell_size_fc
to the Mesh_criteria constructor.
Laurent Rineau, PhD
