- To:
- Subject: [cgal-discuss] Initial Guess for Sparse Quadratic Problem
- Date: Mon, 2 Oct 2017 11:12:40 +0300
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=None ; spf=None
- Ironport-phdr: 9a23:GIuUMh1zBwvmEQwxsmDT+DRfVm0co7zxezQtwd8ZsesQKfad9pjvdHbS+e9qxAeQG96Eu7QZ06L/iOPJZy8p2d65qncMcZhBBVcuqP49uEgeOvODElDxN/XwbiY3T4xoXV5h+GynYwAOQJ6tLw6annrn5jEbHlDzNBF+O//uMo/UlcW+ke6oqLPJZAAdoyCwZ/tYIRPzjgTSt4FCioRrLuM20BbPinFFfaFVxGBpY1WJkECvtY+L4Jd//nEI6Loa/MlaXPCicg==
I am writing a program that needs to solve many related quadratic
minimization problems with linear constraints. Essentially the program
constructs an initial (sparse) problem and incrementally adds new variables and
constraints to it, calling CGAL::solve_quadratic_program at each step.
The expected number of steps is large (thousands of solver calls).
If it matters, my problem is of the form minimize(sum w_i * x_i^2), where w_i >= 0, subject to x_i >= 0, and some linear constraints A * X </<=/=/>/>= B (where A is very sparse). The size of the problem starts small and scales up to hundreds, possibly thousands of variables and constraints.
I'm still at early stages of implementing the program so I don't have reliable profiling data yet, but I expect it to spend most of its time in the solver, so speeding it up would be crucial for performance.
Each next step's solution values for most of the variables shared with the previous step, would be identical or very close to the previous solution's values. It would therefore seems useful to provide an initial guess for these variables, to speed up computing the new solution.
Looking at the API I don't see a way to provide such an initial guess. Searching found https://stackoverflow.com/questions/43380565/give-an-initial-guess-to-the-quadratic-programming-solver-of-cgal which has gone unanswered for 5 years, which doesn't look promising...
So, I guess there is no way to provide such an initial guess? Is this something that can be faked somehow? Is there some alternative approach I could use?
In addition - I love the fact CGAL
allows me to specify iterators to provide the very sparse matrix A,
since writing my own iterator makes it easy to describe an A' =
extension of A without copying all the data of A.
However...
does the internal solver benefit at all from sparseness? The iterator
API hints that the solver treats the problem as dense (that is, the
iterators return every element, even the zero ones, instead of returning
the next non-zero element). Unless the solver does something smart with
the returned zero values?
So, would I be better off using a sparse solver instead?
Looking
around I saw IPOPT which is a more general NPL solver, but seems to
benefit directly from sparseness, and allows for an initial guess. But
it seems there's no easy way to "extend" an existing problem with
additional variables and constraints. Also, being a general NPL solver,
it probably will be less efficient for simple QP problems than a
dedicated QP solver...?
A. Dedicated QP solver,
B. Which allows providing one's own iterators (to allow extending problem instances),
C. Benefits from sparseness,
E. Is open-source...
Thanks,
Oren Ben-Kiki
- [cgal-discuss] Initial Guess for Sparse Quadratic Problem, Oren Ben-Kiki, 10/02/2017
- Re: [cgal-discuss] Initial Guess for Sparse Quadratic Problem, Hoffmann Michael, 10/02/2017
- Re: [cgal-discuss] Initial Guess for Sparse Quadratic Problem, Oren Ben-Kiki, 10/02/2017
