- To:
- Subject: Re: [cgal-discuss] 3D Mesh creates extremely small elements
- Date: Thu, 05 Oct 2017 13:03:05 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:0v8Hnh93zbVgXf9uRHKM819IXTAuvvDOBiVQ1KB90uocTK2v8tzYMVDF4r011RmSAtWdtqoMotGVmp6jcFRI2YyGvnEGfc4EfD4+ouJSoTYdBtWYA1bwNv/gYn9yNs1DUFh44yPzahANS47IXEDJunC58RIVHxz+M0I1erW0ScbuiJG82Om2vpHSeA5VnyGVYLVoLRzwox+CmNMRhN4oDq8s0BbPvjNyeuJbzH4gZXm8tjK7ycq3+ZN/6TV+svk98NRREO+yK6AxUKZVCihgKWEz6cT2nRLMRA/J4WETBDZF2iFUChTIuUmpFqz6tTH347Ys1Q==
Le Thursday, October 5, 2017 11:46:16 AM CEST Michael Bieri a écrit :
> I just uploaded the files to the Dropbox folder:
> https://www.dropbox.com/sh/lz8xmwhr3fg23qu/AAAZEpWnKzJyrjhNB006_-fVa?dl=0
> I further simplified it a bit, there's now just one region wit the
> ellipses. But the effect remains the same.
> There are the following files:
> - 01 - 04.png: The old images
> - dist.png, region.png: 2D view of the distance field and region supplied
> to the meser
> - img_elem_size.inr, img_regions.inr: 3D images for CGAL mesher
> - mesh: The mesh
> - Screenshot***: A screenshot of the mesh.
> - Furthermore, the source code. It's a bit of a mess because it was written
> and edited very quickly...
There is nothing unexpected in the result you got.
I propose a tiny patch, that uses a non-documented feature... Can `make_mesh_3` that way:
CGAL::parameters::internal::Mesh_3_options options;
options.nonlinear_growth_of_balls = true;
C3t3 c3t3 = CGAL::make_mesh_3<C3t3>(domain, criteria, options);
Then the 1D-meshing of curves will be dense were it is supposed to be.
Laurent Rineau, PhD
- [cgal-discuss] 3D Mesh creates extremely small elements, Michael Bieri, 10/03/2017
- Re: [cgal-discuss] 3D Mesh creates extremely small elements, Laurent Rineau (CGAL/GeometryFactory), 10/04/2017
- Re: [cgal-discuss] 3D Mesh creates extremely small elements, Michael Bieri, 10/04/2017
- Re: [cgal-discuss] 3D Mesh creates extremely small elements, Laurent Rineau (CGAL/GeometryFactory), 10/05/2017
- Re: [cgal-discuss] 3D Mesh creates extremely small elements, Michael Bieri, 10/05/2017
- Re: [cgal-discuss] 3D Mesh creates extremely small elements, Michael Bieri, 10/10/2017
