cgal-discuss - [cgal-discuss] Surface mesh boolean op and UV coordinates
  • To:
  • Subject: [cgal-discuss] Surface mesh boolean op and UV coordinates
  • Date: Tue, 17 Oct 2017 16:44:39 +0100
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23:CMFwshGWSltSc+b4D6nb0Z1GYnF86YWxBRYc798ds5kLTJ76osSwAkXT6L1XgUPTWs2DsrQf1LqQ7viocFdDyKjCmUhKSIZLWR4BhJdetC0bK+nBN3fGKuX3ZTcxBsVIWQwt1Xi6NU9IBJS2PAWK8TXhpQIVTx7wPA4wKuXuEZPJlOy20fqz8tvdeVZmnj24NI91KV2ToBnNv8xe1ZdlL446wwDRr2FUdu9Wg2hvY0+QyUWvrvys9YJupnwD88kq8NRNBP33
Hi all
I've successfully used PMP::corefine_and_compute_difference to perform a mesh boolean operation on surface mesh data.
However, I have a need to preserve/calculate UV texture coordinates on the resulting mesh. I've tried feeding in an STOFF rather than an OFF but it seem the library can't handle that.
Is there any way to accomplish this, or must I resort to manually calculating the UV offsets for each vertex?
Thanks
Tom
This email and any attachments to it may be confidential and are intended solely for the use of the individual to whom it is addressed. Any views or opinions expressed are solely those of the author and do not necessarily represent those of CasperTech Ltd.
If you are not the intended recipient of this email, you must neither take any action based upon its contents, nor copy or show it to anyone.
Please contact the sender if you believe you have received this email in error.
  • [cgal-discuss] Surface mesh boolean op and UV coordinates, Tom Mettam, 10/17/2017
