- To:
- Subject: Re: [cgal-discuss] How to check that a general polygon is simple?
- Date: Sun, 29 Oct 2017 13:48:21 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:CIgCoRD9P3y7dBHPMFXAUyQJP3N1i/DPJgcQr6AfoPdwSP77r8bcNUDSrc9gkEXOFd2Crakb26yL6+jJYi8p39WoiDg6aptCVhsI2409vjcLJ4q7M3D9N+PgdCcgHc5PBxdP9nC/NlVJSo6lPwWB6i760DgJBx+qNRZpPv+nXcnJnsGv3qaz/YfSakNGnn2mcLZqJVK3qwvW8cIZiI8nJqcqwQbSuSh0fLFdympsYF6ShB3h/dyY/Zh58i0Wtehy2dRHVPDXcaVwY7tXATBuZ2075cPsuhTHZQSK73oYFG4Rl0wbUED+8BjmU8Kp4WPBve1n1XzCMA==
Hi Jason,
The is_simple() function comes from the Polygon package.These functions are overloads of is_valid_unknown_polygon() and they are defined in Gps_polygon_validation.h.
However, you can call them explicitly.
____ _ ____ _
/_____/_) o /__________ __ //
(____ ( ( ( (_/ (_/-(-'_(/
_/
_/
On 25 October 2017 at 08:26, jason320 <> wrote:
For the linear polygon, there is a "is_simple" function.
I haven't found a corresponding function for general polygon(with arc
segment).
any clues?
- [cgal-discuss] How to check that a general polygon is simple?, jason320, 10/25/2017
- Re: [cgal-discuss] How to check that a general polygon is simple?, Efi Fogel, 10/29/2017
