cgal-discuss - Re:[cgal-discuss] A problem about Delaunay Triangulation
  • To:
  • Subject: Re:[cgal-discuss] A problem about Delaunay Triangulation
  • Date: Tue, 31 Oct 2017 19:04:49 +0800 (GMT+08:00)
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23:pqarqRPmooSwKVTJD60l6mtUPXoX/o7sNwtQ0KIMzox0K/n4rarrMEGX3/hxlliBBdydsK0UzbeO+4nbGkU+or+5+EgYd5JNUxJXwe43pCcHRPC/NEvgMfTxZDY7FskRHHVs/nW8LFQHUJ2mPw6a8TWO6msZFRz7cAZ0Pe/oAZX6jsKt1un09YeATR9PgW9FmUs6eAq/qwrAq8QWnIJkAroz113ErmYOcOIAljAgHk6agxupvpT4x5Vk6SkF4/8=
Thank you very much for the answer.
And is the following one also correctly? (I use the x,y coordinate of a 3D rabbit points)
I want to draw the terrain using the terrain points data set (x, y, z coordinate of every point). I don't know how to handle the relationship of 2D and 3D (how to display the terrain surface after the 3D delaunay triangulation)?
在 2017-10-31 17:17:54,Olivier Devillers <> 写道:
Obviously, the result is wrong, there are some redundant triangles.
On the picture I see 6 finite triangles and it looks perfect.
The Voronoi is strange.
PNG image
