- To:
- Subject: Re: [cgal-discuss] Problem compiling kinetic data structure demo
- Date: Fri, 3 Nov 2017 22:41:11 -0700 (MST)
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
- Ironport-phdr: 9a23:bTQNNRTzsIITHt3t1HVkEQJ9adpsv+yvbD5Q0YIujvd0So/mwa64ZRWN2/xhgRfzUJnB7Loc0qyN7PCmBDRIyK3CmU5BWaQEbwUCh8QSkl5oK+++Imq/EsTXaTcnFt9JTl5v8iLzG0FUHMHjew+a+SXqvnZBUij5Lhd/c+TpBpbJ3YPwzPG345SVYgNShTP7b6k1NwSztQyWt88YhsxpJa81jxfIuXBVYP8F+WQ9Ll2am1Pw59y74YV42yVWofMoscBaAovgeKFtZLpaBTAne0Iy/8Cj4RDFTxbJ5GNFDU0ZlxNJB07O6xSsDcS5iTfzqucogHrSBsbxV71hATk=
Thanks for the reply! I installed Qt3 in my system. But I am getting the
following error while executing the make command. What should I do now?
Thanks again.
anjali@anjali-HP-Notebook:~/Desktop/project/CGAL
Install/CGAL-4.6.3/demo/Kinetic_data_structures$ cmake .
-- Build type: Release
-- USING CXXFLAGS = ' -frounding-math -O3 -DNDEBUG'
-- USING EXEFLAGS = ' '
-- Targetting Unix Makefiles
-- Using /usr/bin/c++ compiler.
-- Requested component: Qt3
-- Requested component: Core
-- Requested component: MPFR
-- Requested component: GMP
-- Boost version: 1.54.0
-- Found the following Boost libraries:
-- program_options
-- Configuring done
-- Generating done
-- Build files have been written to: /home/anjali/Desktop/project/CGAL
Install/CGAL-4.6.3/demo/Kinetic_data_structures$ make
Linking CXX executable KDS_Delaunay_triangulation_2
CMakeFiles/KDS_Delaunay_triangulation_2.dir/KDS_Delaunay_triangulation_2.cpp.o:
In function
`CGAL::Kinetic::Qt_widget_2<CGAL::Kinetic::Default_simulator<CGAL::Kinetic::Exact_simulation_traits::Simulator_function_kernel,
CGAL::Kinetic::Two_list_pointer_event_queue<CGAL::POLYNOMIAL::Kernel<CGAL::POLYNOMIAL::Polynomial<CGAL::Lazy_exact_nt<CGAL::Gmpq>
CGAL::POLYNOMIAL::Sturm_root_stack<CGAL::POLYNOMIAL::Sturm_root_stack_traits<CGAL::POLYNOMIAL::Polynomial<CGAL::Lazy_exact_nt<CGAL::Gmpq>
> > >, CGAL::Lazy_exact_nt<CGAL::Gmpq> >, false, 8u> >
>::Graphical_base_listener::new_notification(CGAL::Kinetic::Gui_base<CGAL::Kinetic::Default_simulator<CGAL::Kinetic::Exact_simulation_traits::Simulator_function_kernel,
> > >, CGAL::Lazy_exact_nt<CGAL::Gmpq> >, false, 8u> >,
CGAL::Kinetic::internal::Qt_timer>::Listener_core::Notification_type)':
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGAL7Kinetic11Qt_widget_2INS0_17Default_simulatorINS0_23Exact_simulation_traits25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS6_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS6_16Sturm_root_stackINS6_23Sturm_root_stack_traitsISC_EEEESB_EELb0ELj8EEEEEE23Graphical_base_listener16new_notificationENS0_8Gui_baseISJ_NS0_8internal8Qt_timerEE13Listener_core17Notification_typeE[_ZN4CGAL7Kinetic11Qt_widget_2INS0_17Default_simulatorINS0_23Exact_simulation_traits25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS6_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS6_16Sturm_root_stackINS6_23Sturm_root_stack_traitsISC_EEEESB_EELb0ELj8EEEEEE23Graphical_base_listener16new_notificationENS0_8Gui_baseISJ_NS0_8internal8Qt_timerEE13Listener_core17Notification_typeE]+0xe):
undefined reference to `QApplication::main_widget'
In function `QString::~QString()':
KDS_Delaunay_triangulation_2.cpp:(.text._ZN7QStringD2Ev[_ZN7QStringD5Ev]+0xb):
undefined reference to `QString::shared_null'
KDS_Delaunay_triangulation_2.cpp:(.text._ZN7QStringD2Ev[_ZN7QStringD5Ev]+0x12):
undefined reference to `QStringData::deleteSelf()'
In function
> > >, CGAL::Lazy_exact_nt<CGAL::Gmpq> >, false, 8u> > >::Qt_widget_2(int,
char**,
boost::intrusive_ptr<CGAL::Kinetic::Default_simulator<CGAL::Kinetic::Exact_simulation_traits::Simulator_function_kernel,
> > >, CGAL::Lazy_exact_nt<CGAL::Gmpq> >, false, 8u> > >, double, double,
double, double)':
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGAL7Kinetic11Qt_widget_2INS0_17Default_simulatorINS0_23Exact_simulation_traits25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS6_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS6_16Sturm_root_stackINS6_23Sturm_root_stack_traitsISC_EEEESB_EELb0ELj8EEEEEEC2EiPPcN5boost13intrusive_ptrISJ_EEdddd[_ZN4CGAL7Kinetic11Qt_widget_2INS0_17Default_simulatorINS0_23Exact_simulation_traits25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS6_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS6_16Sturm_root_stackINS6_23Sturm_root_stack_traitsISC_EEEESB_EELb0ELj8EEEEEEC5EiPPcN5boost13intrusive_ptrISJ_EEdddd]+0xa0):
undefined reference to `QApplication::QApplication(int&, char**)'
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGAL7Kinetic11Qt_widget_2INS0_17Default_simulatorINS0_23Exact_simulation_traits25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS6_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS6_16Sturm_root_stackINS6_23Sturm_root_stack_traitsISC_EEEESB_EELb0ELj8EEEEEEC2EiPPcN5boost13intrusive_ptrISJ_EEdddd[_ZN4CGAL7Kinetic11Qt_widget_2INS0_17Default_simulatorINS0_23Exact_simulation_traits25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS6_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS6_16Sturm_root_stackINS6_23Sturm_root_stack_traitsISC_EEEESB_EELb0ELj8EEEEEEC5EiPPcN5boost13intrusive_ptrISJ_EEdddd]+0x135):
undefined reference to `CGAL::Kinetic::internal::Qt_timer::Qt_timer()'
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGAL7Kinetic11Qt_widget_2INS0_17Default_simulatorINS0_23Exact_simulation_traits25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS6_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS6_16Sturm_root_stackINS6_23Sturm_root_stack_traitsISC_EEEESB_EELb0ELj8EEEEEEC2EiPPcN5boost13intrusive_ptrISJ_EEdddd[_ZN4CGAL7Kinetic11Qt_widget_2INS0_17Default_simulatorINS0_23Exact_simulation_traits25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS6_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS6_16Sturm_root_stackINS6_23Sturm_root_stack_traitsISC_EEEESB_EELb0ELj8EEEEEEC5EiPPcN5boost13intrusive_ptrISJ_EEdddd]+0x267):
`CGAL::Kinetic::internal::Qt_window_2::Qt_window_2(int, int, int, int)'
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGAL7Kinetic11Qt_widget_2INS0_17Default_simulatorINS0_23Exact_simulation_traits25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS6_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS6_16Sturm_root_stackINS6_23Sturm_root_stack_traitsISC_EEEESB_EELb0ELj8EEEEEEC2EiPPcN5boost13intrusive_ptrISJ_EEdddd[_ZN4CGAL7Kinetic11Qt_widget_2INS0_17Default_simulatorINS0_23Exact_simulation_traits25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS6_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS6_16Sturm_root_stackINS6_23Sturm_root_stack_traitsISC_EEEESB_EELb0ELj8EEEEEEC5EiPPcN5boost13intrusive_ptrISJ_EEdddd]+0x277):
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGAL7Kinetic11Qt_widget_2INS0_17Default_simulatorINS0_23Exact_simulation_traits25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS6_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS6_16Sturm_root_stackINS6_23Sturm_root_stack_traitsISC_EEEESB_EELb0ELj8EEEEEEC2EiPPcN5boost13intrusive_ptrISJ_EEdddd[_ZN4CGAL7Kinetic11Qt_widget_2INS0_17Default_simulatorINS0_23Exact_simulation_traits25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS6_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS6_16Sturm_root_stackINS6_23Sturm_root_stack_traitsISC_EEEESB_EELb0ELj8EEEEEEC5EiPPcN5boost13intrusive_ptrISJ_EEdddd]+0x291):
undefined reference to `QString::QString(char const*)'
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGAL7Kinetic11Qt_widget_2INS0_17Default_simulatorINS0_23Exact_simulation_traits25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS6_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS6_16Sturm_root_stackINS6_23Sturm_root_stack_traitsISC_EEEESB_EELb0ELj8EEEEEEC2EiPPcN5boost13intrusive_ptrISJ_EEdddd[_ZN4CGAL7Kinetic11Qt_widget_2INS0_17Default_simulatorINS0_23Exact_simulation_traits25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS6_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS6_16Sturm_root_stackINS6_23Sturm_root_stack_traitsISC_EEEESB_EELb0ELj8EEEEEEC5EiPPcN5boost13intrusive_ptrISJ_EEdddd]+0x2ad):
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGAL7Kinetic11Qt_widget_2INS0_17Default_simulatorINS0_23Exact_simulation_traits25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS6_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS6_16Sturm_root_stackINS6_23Sturm_root_stack_traitsISC_EEEESB_EELb0ELj8EEEEEEC2EiPPcN5boost13intrusive_ptrISJ_EEdddd[_ZN4CGAL7Kinetic11Qt_widget_2INS0_17Default_simulatorINS0_23Exact_simulation_traits25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS6_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS6_16Sturm_root_stackINS6_23Sturm_root_stack_traitsISC_EEEESB_EELb0ELj8EEEEEEC5EiPPcN5boost13intrusive_ptrISJ_EEdddd]+0x2b8):
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGAL7Kinetic11Qt_widget_2INS0_17Default_simulatorINS0_23Exact_simulation_traits25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS6_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS6_16Sturm_root_stackINS6_23Sturm_root_stack_traitsISC_EEEESB_EELb0ELj8EEEEEEC2EiPPcN5boost13intrusive_ptrISJ_EEdddd[_ZN4CGAL7Kinetic11Qt_widget_2INS0_17Default_simulatorINS0_23Exact_simulation_traits25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS6_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS6_16Sturm_root_stackINS6_23Sturm_root_stack_traitsISC_EEEESB_EELb0ELj8EEEEEEC5EiPPcN5boost13intrusive_ptrISJ_EEdddd]+0x2bf):
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGAL7Kinetic11Qt_widget_2INS0_17Default_simulatorINS0_23Exact_simulation_traits25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS6_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS6_16Sturm_root_stackINS6_23Sturm_root_stack_traitsISC_EEEESB_EELb0ELj8EEEEEEC2EiPPcN5boost13intrusive_ptrISJ_EEdddd[_ZN4CGAL7Kinetic11Qt_widget_2INS0_17Default_simulatorINS0_23Exact_simulation_traits25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS6_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS6_16Sturm_root_stackINS6_23Sturm_root_stack_traitsISC_EEEESB_EELb0ELj8EEEEEEC5EiPPcN5boost13intrusive_ptrISJ_EEdddd]+0x2d7):
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGAL7Kinetic11Qt_widget_2INS0_17Default_simulatorINS0_23Exact_simulation_traits25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS6_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS6_16Sturm_root_stackINS6_23Sturm_root_stack_traitsISC_EEEESB_EELb0ELj8EEEEEEC2EiPPcN5boost13intrusive_ptrISJ_EEdddd[_ZN4CGAL7Kinetic11Qt_widget_2INS0_17Default_simulatorINS0_23Exact_simulation_traits25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS6_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS6_16Sturm_root_stackINS6_23Sturm_root_stack_traitsISC_EEEESB_EELb0ELj8EEEEEEC5EiPPcN5boost13intrusive_ptrISJ_EEdddd]+0x362):
In function `int run<CGAL::Kinetic::Exact_simulation_traits>(int, char**,
int, int, int, std::string)':
KDS_Delaunay_triangulation_2.cpp:(.text._Z3runIN4CGAL7Kinetic23Exact_simulation_traitsEEiiPPciiiSs[_Z3runIN4CGAL7Kinetic23Exact_simulation_traitsEEiiPPciiiSs]+0xdff):
KDS_Delaunay_triangulation_2.cpp:(.text._Z3runIN4CGAL7Kinetic23Exact_simulation_traitsEEiiPPciiiSs[_Z3runIN4CGAL7Kinetic23Exact_simulation_traitsEEiiPPciiiSs]+0xe1d):
undefined reference to `QApplication::exec()'
In function
`CGAL::Kinetic::Gui_base<CGAL::Kinetic::Default_simulator<CGAL::Kinetic::Exact_simulation_traits::Simulator_function_kernel,
CGAL::Kinetic::internal::Qt_timer>::set_mode(CGAL::Kinetic::Gui_base<CGAL::Kinetic::Default_simulator<CGAL::Kinetic::Exact_simulation_traits::Simulator_function_kernel,
CGAL::Kinetic::internal::Qt_timer>::Mode)':
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGAL7Kinetic8Gui_baseINS0_17Default_simulatorINS0_23Exact_simulation_traits25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS6_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS6_16Sturm_root_stackINS6_23Sturm_root_stack_traitsISC_EEEESB_EELb0ELj8EEEEENS0_8internal8Qt_timerEE8set_modeENSM_4ModeE[_ZN4CGAL7Kinetic8Gui_baseINS0_17Default_simulatorINS0_23Exact_simulation_traits25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS6_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS6_16Sturm_root_stackINS6_23Sturm_root_stack_traitsISC_EEEESB_EELb0ELj8EEEEENS0_8internal8Qt_timerEE8set_modeENSM_4ModeE]+0xa4):
undefined reference to `QObject::killTimer(int)'
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGAL7Kinetic8Gui_baseINS0_17Default_simulatorINS0_23Exact_simulation_traits25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS6_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS6_16Sturm_root_stackINS6_23Sturm_root_stack_traitsISC_EEEESB_EELb0ELj8EEEEENS0_8internal8Qt_timerEE8set_modeENSM_4ModeE[_ZN4CGAL7Kinetic8Gui_baseINS0_17Default_simulatorINS0_23Exact_simulation_traits25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS6_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS6_16Sturm_root_stackINS6_23Sturm_root_stack_traitsISC_EEEESB_EELb0ELj8EEEEENS0_8internal8Qt_timerEE8set_modeENSM_4ModeE]+0x11e):
undefined reference to `CGAL::Kinetic::internal::Qt_timer::run(double)'
In function
CGAL::Kinetic::internal::Qt_timer>::Timer_listener::new_notification(CGAL::Kinetic::internal::Qt_timer::Listener_core::Notification_type)':
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGAL7Kinetic8Gui_baseINS0_17Default_simulatorINS0_23Exact_simulation_traits25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS6_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS6_16Sturm_root_stackINS6_23Sturm_root_stack_traitsISC_EEEESB_EELb0ELj8EEEEENS0_8internal8Qt_timerEE14Timer_listener16new_notificationENSL_13Listener_core17Notification_typeE[_ZN4CGAL7Kinetic8Gui_baseINS0_17Default_simulatorINS0_23Exact_simulation_traits25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS6_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS6_16Sturm_root_stackINS6_23Sturm_root_stack_traitsISC_EEEESB_EELb0ELj8EEEEENS0_8internal8Qt_timerEE14Timer_listener16new_notificationENSL_13Listener_core17Notification_typeE]+0x33):
In function `CGAL::Qt_widget& CGAL::operator<<
<CGAL::Simple_cartesian<double> >(CGAL::Qt_widget&,
CGAL::Point_2<CGAL::Simple_cartesian<double> > const&)':
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_16Simple_cartesianIdEEEERNS_9Qt_widgetES4_RKNS_7Point_2IT_EE[_ZN4CGALlsINS_16Simple_cartesianIdEEEERNS_9Qt_widgetES4_RKNS_7Point_2IT_EE]+0x19):
undefined reference to `CGAL::Qt_widget::x_pixel(double) const'
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_16Simple_cartesianIdEEEERNS_9Qt_widgetES4_RKNS_7Point_2IT_EE[_ZN4CGALlsINS_16Simple_cartesianIdEEEERNS_9Qt_widgetES4_RKNS_7Point_2IT_EE]+0x29):
undefined reference to `CGAL::Qt_widget::y_pixel(double) const'
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_16Simple_cartesianIdEEEERNS_9Qt_widgetES4_RKNS_7Point_2IT_EE[_ZN4CGALlsINS_16Simple_cartesianIdEEEERNS_9Qt_widgetES4_RKNS_7Point_2IT_EE]+0x67):
undefined reference to `QBrush::QBrush(QBrush const&)'
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_16Simple_cartesianIdEEEERNS_9Qt_widgetES4_RKNS_7Point_2IT_EE[_ZN4CGALlsINS_16Simple_cartesianIdEEEERNS_9Qt_widgetES4_RKNS_7Point_2IT_EE]+0x6f):
undefined reference to `QBrush::QBrush()'
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_16Simple_cartesianIdEEEERNS_9Qt_widgetES4_RKNS_7Point_2IT_EE[_ZN4CGALlsINS_16Simple_cartesianIdEEEERNS_9Qt_widgetES4_RKNS_7Point_2IT_EE]+0x7e):
undefined reference to `QPainter::setBrush(QBrush const&)'
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_16Simple_cartesianIdEEEERNS_9Qt_widgetES4_RKNS_7Point_2IT_EE[_ZN4CGALlsINS_16Simple_cartesianIdEEEERNS_9Qt_widgetES4_RKNS_7Point_2IT_EE]+0x86):
undefined reference to `QBrush::~QBrush()'
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_16Simple_cartesianIdEEEERNS_9Qt_widgetES4_RKNS_7Point_2IT_EE[_ZN4CGALlsINS_16Simple_cartesianIdEEEERNS_9Qt_widgetES4_RKNS_7Point_2IT_EE]+0xa5):
undefined reference to `QPainter::drawRect(int, int, int, int)'
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_16Simple_cartesianIdEEEERNS_9Qt_widgetES4_RKNS_7Point_2IT_EE[_ZN4CGALlsINS_16Simple_cartesianIdEEEERNS_9Qt_widgetES4_RKNS_7Point_2IT_EE]+0xb4):
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_16Simple_cartesianIdEEEERNS_9Qt_widgetES4_RKNS_7Point_2IT_EE[_ZN4CGALlsINS_16Simple_cartesianIdEEEERNS_9Qt_widgetES4_RKNS_7Point_2IT_EE]+0xbc):
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_16Simple_cartesianIdEEEERNS_9Qt_widgetES4_RKNS_7Point_2IT_EE[_ZN4CGALlsINS_16Simple_cartesianIdEEEERNS_9Qt_widgetES4_RKNS_7Point_2IT_EE]+0xd0):
undefined reference to `QWidget::repaint(bool)'
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_16Simple_cartesianIdEEEERNS_9Qt_widgetES4_RKNS_7Point_2IT_EE[_ZN4CGALlsINS_16Simple_cartesianIdEEEERNS_9Qt_widgetES4_RKNS_7Point_2IT_EE]+0x104):
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_16Simple_cartesianIdEEEERNS_9Qt_widgetES4_RKNS_7Point_2IT_EE[_ZN4CGALlsINS_16Simple_cartesianIdEEEERNS_9Qt_widgetES4_RKNS_7Point_2IT_EE]+0x118):
undefined reference to `QPainter::setBrush(QColor const&)'
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_16Simple_cartesianIdEEEERNS_9Qt_widgetES4_RKNS_7Point_2IT_EE[_ZN4CGALlsINS_16Simple_cartesianIdEEEERNS_9Qt_widgetES4_RKNS_7Point_2IT_EE]+0x137):
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_16Simple_cartesianIdEEEERNS_9Qt_widgetES4_RKNS_7Point_2IT_EE[_ZN4CGALlsINS_16Simple_cartesianIdEEEERNS_9Qt_widgetES4_RKNS_7Point_2IT_EE]+0x146):
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_16Simple_cartesianIdEEEERNS_9Qt_widgetES4_RKNS_7Point_2IT_EE[_ZN4CGALlsINS_16Simple_cartesianIdEEEERNS_9Qt_widgetES4_RKNS_7Point_2IT_EE]+0x14e):
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_16Simple_cartesianIdEEEERNS_9Qt_widgetES4_RKNS_7Point_2IT_EE[_ZN4CGALlsINS_16Simple_cartesianIdEEEERNS_9Qt_widgetES4_RKNS_7Point_2IT_EE]+0x16e):
undefined reference to `QPainter::drawPoint(int, int)'
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_16Simple_cartesianIdEEEERNS_9Qt_widgetES4_RKNS_7Point_2IT_EE[_ZN4CGALlsINS_16Simple_cartesianIdEEEERNS_9Qt_widgetES4_RKNS_7Point_2IT_EE]+0x1a5):
undefined reference to `QPainter::drawLine(int, int, int, int)'
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_16Simple_cartesianIdEEEERNS_9Qt_widgetES4_RKNS_7Point_2IT_EE[_ZN4CGALlsINS_16Simple_cartesianIdEEEERNS_9Qt_widgetES4_RKNS_7Point_2IT_EE]+0x1bd):
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_16Simple_cartesianIdEEEERNS_9Qt_widgetES4_RKNS_7Point_2IT_EE[_ZN4CGALlsINS_16Simple_cartesianIdEEEERNS_9Qt_widgetES4_RKNS_7Point_2IT_EE]+0x1ea):
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_16Simple_cartesianIdEEEERNS_9Qt_widgetES4_RKNS_7Point_2IT_EE[_ZN4CGALlsINS_16Simple_cartesianIdEEEERNS_9Qt_widgetES4_RKNS_7Point_2IT_EE]+0x205):
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_16Simple_cartesianIdEEEERNS_9Qt_widgetES4_RKNS_7Point_2IT_EE[_ZN4CGALlsINS_16Simple_cartesianIdEEEERNS_9Qt_widgetES4_RKNS_7Point_2IT_EE]+0x227):
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_16Simple_cartesianIdEEEERNS_9Qt_widgetES4_RKNS_7Point_2IT_EE[_ZN4CGALlsINS_16Simple_cartesianIdEEEERNS_9Qt_widgetES4_RKNS_7Point_2IT_EE]+0x22f):
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_16Simple_cartesianIdEEEERNS_9Qt_widgetES4_RKNS_7Point_2IT_EE[_ZN4CGALlsINS_16Simple_cartesianIdEEEERNS_9Qt_widgetES4_RKNS_7Point_2IT_EE]+0x23e):
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_16Simple_cartesianIdEEEERNS_9Qt_widgetES4_RKNS_7Point_2IT_EE[_ZN4CGALlsINS_16Simple_cartesianIdEEEERNS_9Qt_widgetES4_RKNS_7Point_2IT_EE]+0x246):
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_16Simple_cartesianIdEEEERNS_9Qt_widgetES4_RKNS_7Point_2IT_EE[_ZN4CGALlsINS_16Simple_cartesianIdEEEERNS_9Qt_widgetES4_RKNS_7Point_2IT_EE]+0x265):
undefined reference to `QPainter::drawEllipse(int, int, int, int)'
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_16Simple_cartesianIdEEEERNS_9Qt_widgetES4_RKNS_7Point_2IT_EE[_ZN4CGALlsINS_16Simple_cartesianIdEEEERNS_9Qt_widgetES4_RKNS_7Point_2IT_EE]+0x274):
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_16Simple_cartesianIdEEEERNS_9Qt_widgetES4_RKNS_7Point_2IT_EE[_ZN4CGALlsINS_16Simple_cartesianIdEEEERNS_9Qt_widgetES4_RKNS_7Point_2IT_EE]+0x294):
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_16Simple_cartesianIdEEEERNS_9Qt_widgetES4_RKNS_7Point_2IT_EE[_ZN4CGALlsINS_16Simple_cartesianIdEEEERNS_9Qt_widgetES4_RKNS_7Point_2IT_EE]+0x2a8):
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_16Simple_cartesianIdEEEERNS_9Qt_widgetES4_RKNS_7Point_2IT_EE[_ZN4CGALlsINS_16Simple_cartesianIdEEEERNS_9Qt_widgetES4_RKNS_7Point_2IT_EE]+0x2c7):
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_16Simple_cartesianIdEEEERNS_9Qt_widgetES4_RKNS_7Point_2IT_EE[_ZN4CGALlsINS_16Simple_cartesianIdEEEERNS_9Qt_widgetES4_RKNS_7Point_2IT_EE]+0x2d6):
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_16Simple_cartesianIdEEEERNS_9Qt_widgetES4_RKNS_7Point_2IT_EE[_ZN4CGALlsINS_16Simple_cartesianIdEEEERNS_9Qt_widgetES4_RKNS_7Point_2IT_EE]+0x2e6):
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_16Simple_cartesianIdEEEERNS_9Qt_widgetES4_RKNS_7Point_2IT_EE[_ZN4CGALlsINS_16Simple_cartesianIdEEEERNS_9Qt_widgetES4_RKNS_7Point_2IT_EE]+0x2f9):
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_16Simple_cartesianIdEEEERNS_9Qt_widgetES4_RKNS_7Point_2IT_EE[_ZN4CGALlsINS_16Simple_cartesianIdEEEERNS_9Qt_widgetES4_RKNS_7Point_2IT_EE]+0x30c):
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_16Simple_cartesianIdEEEERNS_9Qt_widgetES4_RKNS_7Point_2IT_EE[_ZN4CGALlsINS_16Simple_cartesianIdEEEERNS_9Qt_widgetES4_RKNS_7Point_2IT_EE]+0x314):
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_16Simple_cartesianIdEEEERNS_9Qt_widgetES4_RKNS_7Point_2IT_EE[_ZN4CGALlsINS_16Simple_cartesianIdEEEERNS_9Qt_widgetES4_RKNS_7Point_2IT_EE]+0x32c):
CMakeFiles/KDS_Delaunay_triangulation_2.dir/KDS_Delaunay_triangulation_2.cpp.o:KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_16Simple_cartesianIdEEEERNS_9Qt_widgetES4_RKNS_7Point_2IT_EE[_ZN4CGALlsINS_16Simple_cartesianIdEEEERNS_9Qt_widgetES4_RKNS_7Point_2IT_EE]+0x33f):
more undefined references to `QBrush::~QBrush()' follow
<CGAL::Epeck>(CGAL::Qt_widget&, CGAL::Point_2<CGAL::Epeck> const&)':
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_7Point_2IT_EE[_ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_7Point_2IT_EE]+0x32):
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_7Point_2IT_EE[_ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_7Point_2IT_EE]+0x61):
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_7Point_2IT_EE[_ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_7Point_2IT_EE]+0x9f):
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_7Point_2IT_EE[_ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_7Point_2IT_EE]+0xa9):
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_7Point_2IT_EE[_ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_7Point_2IT_EE]+0xba):
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_7Point_2IT_EE[_ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_7Point_2IT_EE]+0xc4):
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_7Point_2IT_EE[_ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_7Point_2IT_EE]+0xe3):
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_7Point_2IT_EE[_ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_7Point_2IT_EE]+0xf2):
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_7Point_2IT_EE[_ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_7Point_2IT_EE]+0xfa):
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_7Point_2IT_EE[_ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_7Point_2IT_EE]+0x10e):
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_7Point_2IT_EE[_ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_7Point_2IT_EE]+0x139):
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_7Point_2IT_EE[_ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_7Point_2IT_EE]+0x14d):
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_7Point_2IT_EE[_ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_7Point_2IT_EE]+0x16c):
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_7Point_2IT_EE[_ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_7Point_2IT_EE]+0x17d):
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_7Point_2IT_EE[_ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_7Point_2IT_EE]+0x187):
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_7Point_2IT_EE[_ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_7Point_2IT_EE]+0x19e):
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_7Point_2IT_EE[_ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_7Point_2IT_EE]+0x1d5):
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_7Point_2IT_EE[_ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_7Point_2IT_EE]+0x1ed):
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_7Point_2IT_EE[_ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_7Point_2IT_EE]+0x21a):
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_7Point_2IT_EE[_ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_7Point_2IT_EE]+0x235):
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_7Point_2IT_EE[_ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_7Point_2IT_EE]+0x24f):
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_7Point_2IT_EE[_ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_7Point_2IT_EE]+0x259):
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_7Point_2IT_EE[_ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_7Point_2IT_EE]+0x26a):
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_7Point_2IT_EE[_ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_7Point_2IT_EE]+0x274):
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_7Point_2IT_EE[_ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_7Point_2IT_EE]+0x293):
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_7Point_2IT_EE[_ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_7Point_2IT_EE]+0x2a2):
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_7Point_2IT_EE[_ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_7Point_2IT_EE]+0x2c1):
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_7Point_2IT_EE[_ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_7Point_2IT_EE]+0x2d5):
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_7Point_2IT_EE[_ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_7Point_2IT_EE]+0x2f4):
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_7Point_2IT_EE[_ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_7Point_2IT_EE]+0x305):
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_7Point_2IT_EE[_ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_7Point_2IT_EE]+0x315):
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_7Point_2IT_EE[_ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_7Point_2IT_EE]+0x354):
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_7Point_2IT_EE[_ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_7Point_2IT_EE]+0x369):
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_7Point_2IT_EE[_ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_7Point_2IT_EE]+0x371):
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_7Point_2IT_EE[_ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_7Point_2IT_EE]+0x38b):
CMakeFiles/KDS_Delaunay_triangulation_2.dir/KDS_Delaunay_triangulation_2.cpp.o:KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_7Point_2IT_EE[_ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_7Point_2IT_EE]+0x3a0):
<CGAL::Epeck>(CGAL::Qt_widget&, CGAL::Circle_2<CGAL::Epeck> const&)':
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_8Circle_2IT_EE[_ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_8Circle_2IT_EE]+0x44):
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_8Circle_2IT_EE[_ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_8Circle_2IT_EE]+0x91):
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_8Circle_2IT_EE[_ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_8Circle_2IT_EE]+0xde):
undefined reference to `CGAL::Qt_widget::x_pixel_dist(double) const'
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_8Circle_2IT_EE[_ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_8Circle_2IT_EE]+0x11d):
undefined reference to `CGAL::Qt_widget::y_pixel_dist(double) const'
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_8Circle_2IT_EE[_ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_8Circle_2IT_EE]+0x149):
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_8Circle_2IT_EE[_ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_8Circle_2IT_EE]+0x15d):
In function
`CGAL::Kinetic::Qt_moving_points_2<CGAL::Kinetic::Exact_simulation_traits,
> > >, CGAL::Lazy_exact_nt<CGAL::Gmpq> >, false, 8u> > > >::draw() const':
KDS_Delaunay_triangulation_2.cpp:(.text._ZNK4CGAL7Kinetic18Qt_moving_points_2INS0_23Exact_simulation_traitsENS0_11Qt_widget_2INS0_17Default_simulatorINS2_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS7_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS7_16Sturm_root_stackINS7_23Sturm_root_stack_traitsISD_EEEESC_EELb0ELj8EEEEEEEE4drawEv[_ZNK4CGAL7Kinetic18Qt_moving_points_2INS0_23Exact_simulation_traitsENS0_11Qt_widget_2INS0_17Default_simulatorINS2_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS7_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS7_16Sturm_root_stackINS7_23Sturm_root_stack_traitsISD_EEEESC_EELb0ELj8EEEEEEEE4drawEv]+0x44):
KDS_Delaunay_triangulation_2.cpp:(.text._ZNK4CGAL7Kinetic18Qt_moving_points_2INS0_23Exact_simulation_traitsENS0_11Qt_widget_2INS0_17Default_simulatorINS2_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS7_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS7_16Sturm_root_stackINS7_23Sturm_root_stack_traitsISD_EEEESC_EELb0ELj8EEEEEEEE4drawEv[_ZNK4CGAL7Kinetic18Qt_moving_points_2INS0_23Exact_simulation_traitsENS0_11Qt_widget_2INS0_17Default_simulatorINS2_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS7_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS7_16Sturm_root_stackINS7_23Sturm_root_stack_traitsISD_EEEESC_EELb0ELj8EEEEEEEE4drawEv]+0x15f):
undefined reference to `QPen::QPen(QPen const&)'
KDS_Delaunay_triangulation_2.cpp:(.text._ZNK4CGAL7Kinetic18Qt_moving_points_2INS0_23Exact_simulation_traitsENS0_11Qt_widget_2INS0_17Default_simulatorINS2_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS7_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS7_16Sturm_root_stackINS7_23Sturm_root_stack_traitsISD_EEEESC_EELb0ELj8EEEEEEEE4drawEv[_ZNK4CGAL7Kinetic18Qt_moving_points_2INS0_23Exact_simulation_traitsENS0_11Qt_widget_2INS0_17Default_simulatorINS2_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS7_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS7_16Sturm_root_stackINS7_23Sturm_root_stack_traitsISD_EEEESC_EELb0ELj8EEEEEEEE4drawEv]+0x171):
undefined reference to `QPen::setWidth(unsigned int)'
KDS_Delaunay_triangulation_2.cpp:(.text._ZNK4CGAL7Kinetic18Qt_moving_points_2INS0_23Exact_simulation_traitsENS0_11Qt_widget_2INS0_17Default_simulatorINS2_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS7_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS7_16Sturm_root_stackINS7_23Sturm_root_stack_traitsISD_EEEESC_EELb0ELj8EEEEEEEE4drawEv[_ZNK4CGAL7Kinetic18Qt_moving_points_2INS0_23Exact_simulation_traitsENS0_11Qt_widget_2INS0_17Default_simulatorINS2_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS7_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS7_16Sturm_root_stackINS7_23Sturm_root_stack_traitsISD_EEEESC_EELb0ELj8EEEEEEEE4drawEv]+0x185):
undefined reference to `QPainter::setPen(QPen const&)'
KDS_Delaunay_triangulation_2.cpp:(.text._ZNK4CGAL7Kinetic18Qt_moving_points_2INS0_23Exact_simulation_traitsENS0_11Qt_widget_2INS0_17Default_simulatorINS2_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS7_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS7_16Sturm_root_stackINS7_23Sturm_root_stack_traitsISD_EEEESC_EELb0ELj8EEEEEEEE4drawEv[_ZNK4CGAL7Kinetic18Qt_moving_points_2INS0_23Exact_simulation_traitsENS0_11Qt_widget_2INS0_17Default_simulatorINS2_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS7_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS7_16Sturm_root_stackINS7_23Sturm_root_stack_traitsISD_EEEESC_EELb0ELj8EEEEEEEE4drawEv]+0x192):
undefined reference to `QPen::~QPen()'
KDS_Delaunay_triangulation_2.cpp:(.text._ZNK4CGAL7Kinetic18Qt_moving_points_2INS0_23Exact_simulation_traitsENS0_11Qt_widget_2INS0_17Default_simulatorINS2_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS7_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS7_16Sturm_root_stackINS7_23Sturm_root_stack_traitsISD_EEEESC_EELb0ELj8EEEEEEEE4drawEv[_ZNK4CGAL7Kinetic18Qt_moving_points_2INS0_23Exact_simulation_traitsENS0_11Qt_widget_2INS0_17Default_simulatorINS2_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS7_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS7_16Sturm_root_stackINS7_23Sturm_root_stack_traitsISD_EEEESC_EELb0ELj8EEEEEEEE4drawEv]+0x1e5):
undefined reference to `QColor::setRgb(int, int, int)'
KDS_Delaunay_triangulation_2.cpp:(.text._ZNK4CGAL7Kinetic18Qt_moving_points_2INS0_23Exact_simulation_traitsENS0_11Qt_widget_2INS0_17Default_simulatorINS2_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS7_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS7_16Sturm_root_stackINS7_23Sturm_root_stack_traitsISD_EEEESC_EELb0ELj8EEEEEEEE4drawEv[_ZNK4CGAL7Kinetic18Qt_moving_points_2INS0_23Exact_simulation_traitsENS0_11Qt_widget_2INS0_17Default_simulatorINS2_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS7_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS7_16Sturm_root_stackINS7_23Sturm_root_stack_traitsISD_EEEESC_EELb0ELj8EEEEEEEE4drawEv]+0x1f8):
KDS_Delaunay_triangulation_2.cpp:(.text._ZNK4CGAL7Kinetic18Qt_moving_points_2INS0_23Exact_simulation_traitsENS0_11Qt_widget_2INS0_17Default_simulatorINS2_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS7_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS7_16Sturm_root_stackINS7_23Sturm_root_stack_traitsISD_EEEESC_EELb0ELj8EEEEEEEE4drawEv[_ZNK4CGAL7Kinetic18Qt_moving_points_2INS0_23Exact_simulation_traitsENS0_11Qt_widget_2INS0_17Default_simulatorINS2_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS7_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS7_16Sturm_root_stackINS7_23Sturm_root_stack_traitsISD_EEEESC_EELb0ELj8EEEEEEEE4drawEv]+0x20c):
KDS_Delaunay_triangulation_2.cpp:(.text._ZNK4CGAL7Kinetic18Qt_moving_points_2INS0_23Exact_simulation_traitsENS0_11Qt_widget_2INS0_17Default_simulatorINS2_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS7_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS7_16Sturm_root_stackINS7_23Sturm_root_stack_traitsISD_EEEESC_EELb0ELj8EEEEEEEE4drawEv[_ZNK4CGAL7Kinetic18Qt_moving_points_2INS0_23Exact_simulation_traitsENS0_11Qt_widget_2INS0_17Default_simulatorINS2_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS7_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS7_16Sturm_root_stackINS7_23Sturm_root_stack_traitsISD_EEEESC_EELb0ELj8EEEEEEEE4drawEv]+0x23c):
undefined reference to `CGAL::Qt_widget::operator<<(CGAL::Color const&)'
KDS_Delaunay_triangulation_2.cpp:(.text._ZNK4CGAL7Kinetic18Qt_moving_points_2INS0_23Exact_simulation_traitsENS0_11Qt_widget_2INS0_17Default_simulatorINS2_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS7_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS7_16Sturm_root_stackINS7_23Sturm_root_stack_traitsISD_EEEESC_EELb0ELj8EEEEEEEE4drawEv[_ZNK4CGAL7Kinetic18Qt_moving_points_2INS0_23Exact_simulation_traitsENS0_11Qt_widget_2INS0_17Default_simulatorINS2_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS7_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS7_16Sturm_root_stackINS7_23Sturm_root_stack_traitsISD_EEEESC_EELb0ELj8EEEEEEEE4drawEv]+0x402):
KDS_Delaunay_triangulation_2.cpp:(.text._ZNK4CGAL7Kinetic18Qt_moving_points_2INS0_23Exact_simulation_traitsENS0_11Qt_widget_2INS0_17Default_simulatorINS2_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS7_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS7_16Sturm_root_stackINS7_23Sturm_root_stack_traitsISD_EEEESC_EELb0ELj8EEEEEEEE4drawEv[_ZNK4CGAL7Kinetic18Qt_moving_points_2INS0_23Exact_simulation_traitsENS0_11Qt_widget_2INS0_17Default_simulatorINS2_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS7_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS7_16Sturm_root_stackINS7_23Sturm_root_stack_traitsISD_EEEESC_EELb0ELj8EEEEEEEE4drawEv]+0x431):
KDS_Delaunay_triangulation_2.cpp:(.text._ZNK4CGAL7Kinetic18Qt_moving_points_2INS0_23Exact_simulation_traitsENS0_11Qt_widget_2INS0_17Default_simulatorINS2_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS7_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS7_16Sturm_root_stackINS7_23Sturm_root_stack_traitsISD_EEEESC_EELb0ELj8EEEEEEEE4drawEv[_ZNK4CGAL7Kinetic18Qt_moving_points_2INS0_23Exact_simulation_traitsENS0_11Qt_widget_2INS0_17Default_simulatorINS2_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS7_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS7_16Sturm_root_stackINS7_23Sturm_root_stack_traitsISD_EEEESC_EELb0ELj8EEEEEEEE4drawEv]+0x46a):
KDS_Delaunay_triangulation_2.cpp:(.text._ZNK4CGAL7Kinetic18Qt_moving_points_2INS0_23Exact_simulation_traitsENS0_11Qt_widget_2INS0_17Default_simulatorINS2_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS7_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS7_16Sturm_root_stackINS7_23Sturm_root_stack_traitsISD_EEEESC_EELb0ELj8EEEEEEEE4drawEv[_ZNK4CGAL7Kinetic18Qt_moving_points_2INS0_23Exact_simulation_traitsENS0_11Qt_widget_2INS0_17Default_simulatorINS2_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS7_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS7_16Sturm_root_stackINS7_23Sturm_root_stack_traitsISD_EEEESC_EELb0ELj8EEEEEEEE4drawEv]+0x48b):
undefined reference to `QPainter::drawText(int, int, QString const&, int,
QPainter::TextDirection)'
KDS_Delaunay_triangulation_2.cpp:(.text._ZNK4CGAL7Kinetic18Qt_moving_points_2INS0_23Exact_simulation_traitsENS0_11Qt_widget_2INS0_17Default_simulatorINS2_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS7_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS7_16Sturm_root_stackINS7_23Sturm_root_stack_traitsISD_EEEESC_EELb0ELj8EEEEEEEE4drawEv[_ZNK4CGAL7Kinetic18Qt_moving_points_2INS0_23Exact_simulation_traitsENS0_11Qt_widget_2INS0_17Default_simulatorINS2_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS7_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS7_16Sturm_root_stackINS7_23Sturm_root_stack_traitsISD_EEEESC_EELb0ELj8EEEEEEEE4drawEv]+0x4b6):
KDS_Delaunay_triangulation_2.cpp:(.text._ZNK4CGAL7Kinetic18Qt_moving_points_2INS0_23Exact_simulation_traitsENS0_11Qt_widget_2INS0_17Default_simulatorINS2_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS7_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS7_16Sturm_root_stackINS7_23Sturm_root_stack_traitsISD_EEEESC_EELb0ELj8EEEEEEEE4drawEv[_ZNK4CGAL7Kinetic18Qt_moving_points_2INS0_23Exact_simulation_traitsENS0_11Qt_widget_2INS0_17Default_simulatorINS2_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS7_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS7_16Sturm_root_stackINS7_23Sturm_root_stack_traitsISD_EEEESC_EELb0ELj8EEEEEEEE4drawEv]+0x4bd):
KDS_Delaunay_triangulation_2.cpp:(.text._ZNK4CGAL7Kinetic18Qt_moving_points_2INS0_23Exact_simulation_traitsENS0_11Qt_widget_2INS0_17Default_simulatorINS2_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS7_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS7_16Sturm_root_stackINS7_23Sturm_root_stack_traitsISD_EEEESC_EELb0ELj8EEEEEEEE4drawEv[_ZNK4CGAL7Kinetic18Qt_moving_points_2INS0_23Exact_simulation_traitsENS0_11Qt_widget_2INS0_17Default_simulatorINS2_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS7_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS7_16Sturm_root_stackINS7_23Sturm_root_stack_traitsISD_EEEESC_EELb0ELj8EEEEEEEE4drawEv]+0x603):
KDS_Delaunay_triangulation_2.cpp:(.text._ZNK4CGAL7Kinetic18Qt_moving_points_2INS0_23Exact_simulation_traitsENS0_11Qt_widget_2INS0_17Default_simulatorINS2_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS7_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS7_16Sturm_root_stackINS7_23Sturm_root_stack_traitsISD_EEEESC_EELb0ELj8EEEEEEEE4drawEv[_ZNK4CGAL7Kinetic18Qt_moving_points_2INS0_23Exact_simulation_traitsENS0_11Qt_widget_2INS0_17Default_simulatorINS2_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS7_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS7_16Sturm_root_stackINS7_23Sturm_root_stack_traitsISD_EEEESC_EELb0ELj8EEEEEEEE4drawEv]+0x616):
KDS_Delaunay_triangulation_2.cpp:(.text._ZNK4CGAL7Kinetic18Qt_moving_points_2INS0_23Exact_simulation_traitsENS0_11Qt_widget_2INS0_17Default_simulatorINS2_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS7_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS7_16Sturm_root_stackINS7_23Sturm_root_stack_traitsISD_EEEESC_EELb0ELj8EEEEEEEE4drawEv[_ZNK4CGAL7Kinetic18Qt_moving_points_2INS0_23Exact_simulation_traitsENS0_11Qt_widget_2INS0_17Default_simulatorINS2_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS7_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS7_16Sturm_root_stackINS7_23Sturm_root_stack_traitsISD_EEEESC_EELb0ELj8EEEEEEEE4drawEv]+0x62a):
KDS_Delaunay_triangulation_2.cpp:(.text._ZNK4CGAL7Kinetic18Qt_moving_points_2INS0_23Exact_simulation_traitsENS0_11Qt_widget_2INS0_17Default_simulatorINS2_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS7_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS7_16Sturm_root_stackINS7_23Sturm_root_stack_traitsISD_EEEESC_EELb0ELj8EEEEEEEE4drawEv[_ZNK4CGAL7Kinetic18Qt_moving_points_2INS0_23Exact_simulation_traitsENS0_11Qt_widget_2INS0_17Default_simulatorINS2_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS7_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS7_16Sturm_root_stackINS7_23Sturm_root_stack_traitsISD_EEEESC_EELb0ELj8EEEEEEEE4drawEv]+0x65a):
KDS_Delaunay_triangulation_2.cpp:(.text._ZNK4CGAL7Kinetic18Qt_moving_points_2INS0_23Exact_simulation_traitsENS0_11Qt_widget_2INS0_17Default_simulatorINS2_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS7_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS7_16Sturm_root_stackINS7_23Sturm_root_stack_traitsISD_EEEESC_EELb0ELj8EEEEEEEE4drawEv[_ZNK4CGAL7Kinetic18Qt_moving_points_2INS0_23Exact_simulation_traitsENS0_11Qt_widget_2INS0_17Default_simulatorINS2_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS7_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS7_16Sturm_root_stackINS7_23Sturm_root_stack_traitsISD_EEEESC_EELb0ELj8EEEEEEEE4drawEv]+0x690):
KDS_Delaunay_triangulation_2.cpp:(.text._ZNK4CGAL7Kinetic18Qt_moving_points_2INS0_23Exact_simulation_traitsENS0_11Qt_widget_2INS0_17Default_simulatorINS2_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS7_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS7_16Sturm_root_stackINS7_23Sturm_root_stack_traitsISD_EEEESC_EELb0ELj8EEEEEEEE4drawEv[_ZNK4CGAL7Kinetic18Qt_moving_points_2INS0_23Exact_simulation_traitsENS0_11Qt_widget_2INS0_17Default_simulatorINS2_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS7_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS7_16Sturm_root_stackINS7_23Sturm_root_stack_traitsISD_EEEESC_EELb0ELj8EEEEEEEE4drawEv]+0x6a2):
KDS_Delaunay_triangulation_2.cpp:(.text._ZNK4CGAL7Kinetic18Qt_moving_points_2INS0_23Exact_simulation_traitsENS0_11Qt_widget_2INS0_17Default_simulatorINS2_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS7_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS7_16Sturm_root_stackINS7_23Sturm_root_stack_traitsISD_EEEESC_EELb0ELj8EEEEEEEE4drawEv[_ZNK4CGAL7Kinetic18Qt_moving_points_2INS0_23Exact_simulation_traitsENS0_11Qt_widget_2INS0_17Default_simulatorINS2_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS7_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS7_16Sturm_root_stackINS7_23Sturm_root_stack_traitsISD_EEEESC_EELb0ELj8EEEEEEEE4drawEv]+0x6b6):
KDS_Delaunay_triangulation_2.cpp:(.text._ZNK4CGAL7Kinetic18Qt_moving_points_2INS0_23Exact_simulation_traitsENS0_11Qt_widget_2INS0_17Default_simulatorINS2_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS7_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS7_16Sturm_root_stackINS7_23Sturm_root_stack_traitsISD_EEEESC_EELb0ELj8EEEEEEEE4drawEv[_ZNK4CGAL7Kinetic18Qt_moving_points_2INS0_23Exact_simulation_traitsENS0_11Qt_widget_2INS0_17Default_simulatorINS2_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS7_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS7_16Sturm_root_stackINS7_23Sturm_root_stack_traitsISD_EEEESC_EELb0ELj8EEEEEEEE4drawEv]+0x6c3):
KDS_Delaunay_triangulation_2.cpp:(.text._ZNK4CGAL7Kinetic18Qt_moving_points_2INS0_23Exact_simulation_traitsENS0_11Qt_widget_2INS0_17Default_simulatorINS2_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS7_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS7_16Sturm_root_stackINS7_23Sturm_root_stack_traitsISD_EEEESC_EELb0ELj8EEEEEEEE4drawEv[_ZNK4CGAL7Kinetic18Qt_moving_points_2INS0_23Exact_simulation_traitsENS0_11Qt_widget_2INS0_17Default_simulatorINS2_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS7_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS7_16Sturm_root_stackINS7_23Sturm_root_stack_traitsISD_EEEESC_EELb0ELj8EEEEEEEE4drawEv]+0x7cd):
KDS_Delaunay_triangulation_2.cpp:(.text._ZNK4CGAL7Kinetic18Qt_moving_points_2INS0_23Exact_simulation_traitsENS0_11Qt_widget_2INS0_17Default_simulatorINS2_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS7_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS7_16Sturm_root_stackINS7_23Sturm_root_stack_traitsISD_EEEESC_EELb0ELj8EEEEEEEE4drawEv[_ZNK4CGAL7Kinetic18Qt_moving_points_2INS0_23Exact_simulation_traitsENS0_11Qt_widget_2INS0_17Default_simulatorINS2_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS7_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS7_16Sturm_root_stackINS7_23Sturm_root_stack_traitsISD_EEEESC_EELb0ELj8EEEEEEEE4drawEv]+0x7dc):
KDS_Delaunay_triangulation_2.cpp:(.text._ZNK4CGAL7Kinetic18Qt_moving_points_2INS0_23Exact_simulation_traitsENS0_11Qt_widget_2INS0_17Default_simulatorINS2_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS7_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS7_16Sturm_root_stackINS7_23Sturm_root_stack_traitsISD_EEEESC_EELb0ELj8EEEEEEEE4drawEv[_ZNK4CGAL7Kinetic18Qt_moving_points_2INS0_23Exact_simulation_traitsENS0_11Qt_widget_2INS0_17Default_simulatorINS2_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS7_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS7_16Sturm_root_stackINS7_23Sturm_root_stack_traitsISD_EEEESC_EELb0ELj8EEEEEEEE4drawEv]+0x7ed):
KDS_Delaunay_triangulation_2.cpp:(.text._ZNK4CGAL7Kinetic18Qt_moving_points_2INS0_23Exact_simulation_traitsENS0_11Qt_widget_2INS0_17Default_simulatorINS2_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS7_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS7_16Sturm_root_stackINS7_23Sturm_root_stack_traitsISD_EEEESC_EELb0ELj8EEEEEEEE4drawEv[_ZNK4CGAL7Kinetic18Qt_moving_points_2INS0_23Exact_simulation_traitsENS0_11Qt_widget_2INS0_17Default_simulatorINS2_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS7_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS7_16Sturm_root_stackINS7_23Sturm_root_stack_traitsISD_EEEESC_EELb0ELj8EEEEEEEE4drawEv]+0x7f7):
KDS_Delaunay_triangulation_2.cpp:(.text._ZNK4CGAL7Kinetic18Qt_moving_points_2INS0_23Exact_simulation_traitsENS0_11Qt_widget_2INS0_17Default_simulatorINS2_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS7_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS7_16Sturm_root_stackINS7_23Sturm_root_stack_traitsISD_EEEESC_EELb0ELj8EEEEEEEE4drawEv[_ZNK4CGAL7Kinetic18Qt_moving_points_2INS0_23Exact_simulation_traitsENS0_11Qt_widget_2INS0_17Default_simulatorINS2_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS7_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS7_16Sturm_root_stackINS7_23Sturm_root_stack_traitsISD_EEEESC_EELb0ELj8EEEEEEEE4drawEv]+0x82f):
KDS_Delaunay_triangulation_2.cpp:(.text._ZNK4CGAL7Kinetic18Qt_moving_points_2INS0_23Exact_simulation_traitsENS0_11Qt_widget_2INS0_17Default_simulatorINS2_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS7_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS7_16Sturm_root_stackINS7_23Sturm_root_stack_traitsISD_EEEESC_EELb0ELj8EEEEEEEE4drawEv[_ZNK4CGAL7Kinetic18Qt_moving_points_2INS0_23Exact_simulation_traitsENS0_11Qt_widget_2INS0_17Default_simulatorINS2_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS7_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS7_16Sturm_root_stackINS7_23Sturm_root_stack_traitsISD_EEEESC_EELb0ELj8EEEEEEEE4drawEv]+0x841):
KDS_Delaunay_triangulation_2.cpp:(.text._ZNK4CGAL7Kinetic18Qt_moving_points_2INS0_23Exact_simulation_traitsENS0_11Qt_widget_2INS0_17Default_simulatorINS2_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS7_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS7_16Sturm_root_stackINS7_23Sturm_root_stack_traitsISD_EEEESC_EELb0ELj8EEEEEEEE4drawEv[_ZNK4CGAL7Kinetic18Qt_moving_points_2INS0_23Exact_simulation_traitsENS0_11Qt_widget_2INS0_17Default_simulatorINS2_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS7_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS7_16Sturm_root_stackINS7_23Sturm_root_stack_traitsISD_EEEESC_EELb0ELj8EEEEEEEE4drawEv]+0x855):
KDS_Delaunay_triangulation_2.cpp:(.text._ZNK4CGAL7Kinetic18Qt_moving_points_2INS0_23Exact_simulation_traitsENS0_11Qt_widget_2INS0_17Default_simulatorINS2_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS7_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS7_16Sturm_root_stackINS7_23Sturm_root_stack_traitsISD_EEEESC_EELb0ELj8EEEEEEEE4drawEv[_ZNK4CGAL7Kinetic18Qt_moving_points_2INS0_23Exact_simulation_traitsENS0_11Qt_widget_2INS0_17Default_simulatorINS2_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS7_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS7_16Sturm_root_stackINS7_23Sturm_root_stack_traitsISD_EEEESC_EELb0ELj8EEEEEEEE4drawEv]+0x862):
KDS_Delaunay_triangulation_2.cpp:(.text._ZNK4CGAL7Kinetic18Qt_moving_points_2INS0_23Exact_simulation_traitsENS0_11Qt_widget_2INS0_17Default_simulatorINS2_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS7_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS7_16Sturm_root_stackINS7_23Sturm_root_stack_traitsISD_EEEESC_EELb0ELj8EEEEEEEE4drawEv[_ZNK4CGAL7Kinetic18Qt_moving_points_2INS0_23Exact_simulation_traitsENS0_11Qt_widget_2INS0_17Default_simulatorINS2_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS7_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS7_16Sturm_root_stackINS7_23Sturm_root_stack_traitsISD_EEEESC_EELb0ELj8EEEEEEEE4drawEv]+0x877):
KDS_Delaunay_triangulation_2.cpp:(.text._ZNK4CGAL7Kinetic18Qt_moving_points_2INS0_23Exact_simulation_traitsENS0_11Qt_widget_2INS0_17Default_simulatorINS2_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS7_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS7_16Sturm_root_stackINS7_23Sturm_root_stack_traitsISD_EEEESC_EELb0ELj8EEEEEEEE4drawEv[_ZNK4CGAL7Kinetic18Qt_moving_points_2INS0_23Exact_simulation_traitsENS0_11Qt_widget_2INS0_17Default_simulatorINS2_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS7_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS7_16Sturm_root_stackINS7_23Sturm_root_stack_traitsISD_EEEESC_EELb0ELj8EEEEEEEE4drawEv]+0x8e9):
KDS_Delaunay_triangulation_2.cpp:(.text._ZNK4CGAL7Kinetic18Qt_moving_points_2INS0_23Exact_simulation_traitsENS0_11Qt_widget_2INS0_17Default_simulatorINS2_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS7_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS7_16Sturm_root_stackINS7_23Sturm_root_stack_traitsISD_EEEESC_EELb0ELj8EEEEEEEE4drawEv[_ZNK4CGAL7Kinetic18Qt_moving_points_2INS0_23Exact_simulation_traitsENS0_11Qt_widget_2INS0_17Default_simulatorINS2_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS7_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS7_16Sturm_root_stackINS7_23Sturm_root_stack_traitsISD_EEEESC_EELb0ELj8EEEEEEEE4drawEv]+0x8f8):
KDS_Delaunay_triangulation_2.cpp:(.text._ZNK4CGAL7Kinetic18Qt_moving_points_2INS0_23Exact_simulation_traitsENS0_11Qt_widget_2INS0_17Default_simulatorINS2_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS7_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS7_16Sturm_root_stackINS7_23Sturm_root_stack_traitsISD_EEEESC_EELb0ELj8EEEEEEEE4drawEv[_ZNK4CGAL7Kinetic18Qt_moving_points_2INS0_23Exact_simulation_traitsENS0_11Qt_widget_2INS0_17Default_simulatorINS2_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINS7_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENS7_16Sturm_root_stackINS7_23Sturm_root_stack_traitsISD_EEEESC_EELb0ELj8EEEEEEEE4drawEv]+0x93e):
<CGAL::Epeck>(CGAL::Qt_widget&, CGAL::Segment_2<CGAL::Epeck> const&)':
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_9Segment_2IT_EE[_ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_9Segment_2IT_EE]+0x154):
undefined reference to `CGAL::Qt_widget::x_real(int) const'
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_9Segment_2IT_EE[_ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_9Segment_2IT_EE]+0x171):
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_9Segment_2IT_EE[_ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_9Segment_2IT_EE]+0x1c1):
undefined reference to `CGAL::Qt_widget::y_real(int) const'
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_9Segment_2IT_EE[_ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_9Segment_2IT_EE]+0x1de):
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_9Segment_2IT_EE[_ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_9Segment_2IT_EE]+0x2b4):
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_9Segment_2IT_EE[_ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_9Segment_2IT_EE]+0x2c4):
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_9Segment_2IT_EE[_ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_9Segment_2IT_EE]+0x2d5):
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_9Segment_2IT_EE[_ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_9Segment_2IT_EE]+0x2e6):
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_9Segment_2IT_EE[_ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_9Segment_2IT_EE]+0x2fd):
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_9Segment_2IT_EE[_ZN4CGALlsINS_5EpeckEEERNS_9Qt_widgetES3_RKNS_9Segment_2IT_EE]+0x311):
In function
`CGAL::Kinetic::Qt_triangulation_2<CGAL::Kinetic::Delaunay_triangulation_2<CGAL::Kinetic::Exact_simulation_traits,
CGAL::Kinetic::Delaunay_triangulation_recent_edges_visitor_2<CGAL::Delaunay_triangulation_2<CGAL::Kinetic::Default_instantaneous_kernel<CGAL::Kinetic::Exact_simulation_traits>,
CGAL::Triangulation_data_structure_2<CGAL::Kinetic::Delaunay_triangulation_vertex_base_2<CGAL::Kinetic::Default_instantaneous_kernel<CGAL::Kinetic::Exact_simulation_traits>,
CGAL::Triangulation_vertex_base_2<CGAL::Kinetic::Default_instantaneous_kernel<CGAL::Kinetic::Exact_simulation_traits>,
CGAL::Triangulation_ds_vertex_base_2<void> > >,
CGAL::Kinetic::Delaunay_triangulation_face_base_2<CGAL::Kinetic::Exact_simulation_traits,
CGAL::Triangulation_face_base_2<CGAL::Kinetic::Default_instantaneous_kernel<CGAL::Kinetic::Exact_simulation_traits>,
CGAL::Triangulation_ds_face_base_2<void> > > > > >,
CGAL::Triangulation_ds_face_base_2<void> > > > >,
CGAL::Kinetic::Delaunay_triangulation_default_traits_2<CGAL::Kinetic::Exact_simulation_traits,
CGAL::Triangulation_ds_face_base_2<void> > > > > > >,
>::draw(CGAL::Qt_widget&, double) const':
KDS_Delaunay_triangulation_2.cpp:(.text._ZNK4CGAL7Kinetic18Qt_triangulation_2INS0_24Delaunay_triangulation_2INS0_23Exact_simulation_traitsENS0_45Delaunay_triangulation_recent_edges_visitor_2INS_24Delaunay_triangulation_2INS0_28Default_instantaneous_kernelIS3_EENS_30Triangulation_data_structure_2INS0_36Delaunay_triangulation_vertex_base_2IS7_NS_27Triangulation_vertex_base_2IS7_NS_30Triangulation_ds_vertex_base_2IvEEEEEENS0_34Delaunay_triangulation_face_base_2IS3_NS_25Triangulation_face_base_2IS7_NS_28Triangulation_ds_face_base_2IvEEEEEEEEEEEESM_NS0_39Delaunay_triangulation_default_traits_2IS3_SM_EEEES7_NS0_11Qt_widget_2INS0_17Default_simulatorINS3_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINSV_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENSV_16Sturm_root_stackINSV_23Sturm_root_stack_traitsIS11_EEEES10_EELb0ELj8EEEEEEEE4drawERNS_9Qt_widgetEd[_ZNK4CGAL7Kinetic18Qt_triangulation_2INS0_24Delaunay_triangulation_2INS0_23Exact_simulation_traitsENS0_45Delaunay_triangulation_recent_edges_visitor_2INS_24Delaunay_triangulation_2INS0_28Default_instantaneous_kernelIS3_EENS_30Triangulation_data_structure_2INS0_36Delaunay_triangulation_vertex_base_2IS7_NS_27Triangulation_vertex_base_2IS7_NS_30Triangulation_ds_vertex_base_2IvEEEEEENS0_34Delaunay_triangulation_face_base_2IS3_NS_25Triangulation_face_base_2IS7_NS_28Triangulation_ds_face_base_2IvEEEEEEEEEEEESM_NS0_39Delaunay_triangulation_default_traits_2IS3_SM_EEEES7_NS0_11Qt_widget_2INS0_17Default_simulatorINS3_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINSV_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENSV_16Sturm_root_stackINSV_23Sturm_root_stack_traitsIS11_EEEES10_EELb0ELj8EEEEEEEE4drawERNS_9Qt_widgetEd]+0x125):
KDS_Delaunay_triangulation_2.cpp:(.text._ZNK4CGAL7Kinetic18Qt_triangulation_2INS0_24Delaunay_triangulation_2INS0_23Exact_simulation_traitsENS0_45Delaunay_triangulation_recent_edges_visitor_2INS_24Delaunay_triangulation_2INS0_28Default_instantaneous_kernelIS3_EENS_30Triangulation_data_structure_2INS0_36Delaunay_triangulation_vertex_base_2IS7_NS_27Triangulation_vertex_base_2IS7_NS_30Triangulation_ds_vertex_base_2IvEEEEEENS0_34Delaunay_triangulation_face_base_2IS3_NS_25Triangulation_face_base_2IS7_NS_28Triangulation_ds_face_base_2IvEEEEEEEEEEEESM_NS0_39Delaunay_triangulation_default_traits_2IS3_SM_EEEES7_NS0_11Qt_widget_2INS0_17Default_simulatorINS3_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINSV_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENSV_16Sturm_root_stackINSV_23Sturm_root_stack_traitsIS11_EEEES10_EELb0ELj8EEEEEEEE4drawERNS_9Qt_widgetEd[_ZNK4CGAL7Kinetic18Qt_triangulation_2INS0_24Delaunay_triangulation_2INS0_23Exact_simulation_traitsENS0_45Delaunay_triangulation_recent_edges_visitor_2INS_24Delaunay_triangulation_2INS0_28Default_instantaneous_kernelIS3_EENS_30Triangulation_data_structure_2INS0_36Delaunay_triangulation_vertex_base_2IS7_NS_27Triangulation_vertex_base_2IS7_NS_30Triangulation_ds_vertex_base_2IvEEEEEENS0_34Delaunay_triangulation_face_base_2IS3_NS_25Triangulation_face_base_2IS7_NS_28Triangulation_ds_face_base_2IvEEEEEEEEEEEESM_NS0_39Delaunay_triangulation_default_traits_2IS3_SM_EEEES7_NS0_11Qt_widget_2INS0_17Default_simulatorINS3_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINSV_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENSV_16Sturm_root_stackINSV_23Sturm_root_stack_traitsIS11_EEEES10_EELb0ELj8EEEEEEEE4drawERNS_9Qt_widgetEd]+0x137):
KDS_Delaunay_triangulation_2.cpp:(.text._ZNK4CGAL7Kinetic18Qt_triangulation_2INS0_24Delaunay_triangulation_2INS0_23Exact_simulation_traitsENS0_45Delaunay_triangulation_recent_edges_visitor_2INS_24Delaunay_triangulation_2INS0_28Default_instantaneous_kernelIS3_EENS_30Triangulation_data_structure_2INS0_36Delaunay_triangulation_vertex_base_2IS7_NS_27Triangulation_vertex_base_2IS7_NS_30Triangulation_ds_vertex_base_2IvEEEEEENS0_34Delaunay_triangulation_face_base_2IS3_NS_25Triangulation_face_base_2IS7_NS_28Triangulation_ds_face_base_2IvEEEEEEEEEEEESM_NS0_39Delaunay_triangulation_default_traits_2IS3_SM_EEEES7_NS0_11Qt_widget_2INS0_17Default_simulatorINS3_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINSV_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENSV_16Sturm_root_stackINSV_23Sturm_root_stack_traitsIS11_EEEES10_EELb0ELj8EEEEEEEE4drawERNS_9Qt_widgetEd[_ZNK4CGAL7Kinetic18Qt_triangulation_2INS0_24Delaunay_triangulation_2INS0_23Exact_simulation_traitsENS0_45Delaunay_triangulation_recent_edges_visitor_2INS_24Delaunay_triangulation_2INS0_28Default_instantaneous_kernelIS3_EENS_30Triangulation_data_structure_2INS0_36Delaunay_triangulation_vertex_base_2IS7_NS_27Triangulation_vertex_base_2IS7_NS_30Triangulation_ds_vertex_base_2IvEEEEEENS0_34Delaunay_triangulation_face_base_2IS3_NS_25Triangulation_face_base_2IS7_NS_28Triangulation_ds_face_base_2IvEEEEEEEEEEEESM_NS0_39Delaunay_triangulation_default_traits_2IS3_SM_EEEES7_NS0_11Qt_widget_2INS0_17Default_simulatorINS3_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINSV_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENSV_16Sturm_root_stackINSV_23Sturm_root_stack_traitsIS11_EEEES10_EELb0ELj8EEEEEEEE4drawERNS_9Qt_widgetEd]+0x14b):
KDS_Delaunay_triangulation_2.cpp:(.text._ZNK4CGAL7Kinetic18Qt_triangulation_2INS0_24Delaunay_triangulation_2INS0_23Exact_simulation_traitsENS0_45Delaunay_triangulation_recent_edges_visitor_2INS_24Delaunay_triangulation_2INS0_28Default_instantaneous_kernelIS3_EENS_30Triangulation_data_structure_2INS0_36Delaunay_triangulation_vertex_base_2IS7_NS_27Triangulation_vertex_base_2IS7_NS_30Triangulation_ds_vertex_base_2IvEEEEEENS0_34Delaunay_triangulation_face_base_2IS3_NS_25Triangulation_face_base_2IS7_NS_28Triangulation_ds_face_base_2IvEEEEEEEEEEEESM_NS0_39Delaunay_triangulation_default_traits_2IS3_SM_EEEES7_NS0_11Qt_widget_2INS0_17Default_simulatorINS3_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINSV_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENSV_16Sturm_root_stackINSV_23Sturm_root_stack_traitsIS11_EEEES10_EELb0ELj8EEEEEEEE4drawERNS_9Qt_widgetEd[_ZNK4CGAL7Kinetic18Qt_triangulation_2INS0_24Delaunay_triangulation_2INS0_23Exact_simulation_traitsENS0_45Delaunay_triangulation_recent_edges_visitor_2INS_24Delaunay_triangulation_2INS0_28Default_instantaneous_kernelIS3_EENS_30Triangulation_data_structure_2INS0_36Delaunay_triangulation_vertex_base_2IS7_NS_27Triangulation_vertex_base_2IS7_NS_30Triangulation_ds_vertex_base_2IvEEEEEENS0_34Delaunay_triangulation_face_base_2IS3_NS_25Triangulation_face_base_2IS7_NS_28Triangulation_ds_face_base_2IvEEEEEEEEEEEESM_NS0_39Delaunay_triangulation_default_traits_2IS3_SM_EEEES7_NS0_11Qt_widget_2INS0_17Default_simulatorINS3_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINSV_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENSV_16Sturm_root_stackINSV_23Sturm_root_stack_traitsIS11_EEEES10_EELb0ELj8EEEEEEEE4drawERNS_9Qt_widgetEd]+0x158):
KDS_Delaunay_triangulation_2.cpp:(.text._ZNK4CGAL7Kinetic18Qt_triangulation_2INS0_24Delaunay_triangulation_2INS0_23Exact_simulation_traitsENS0_45Delaunay_triangulation_recent_edges_visitor_2INS_24Delaunay_triangulation_2INS0_28Default_instantaneous_kernelIS3_EENS_30Triangulation_data_structure_2INS0_36Delaunay_triangulation_vertex_base_2IS7_NS_27Triangulation_vertex_base_2IS7_NS_30Triangulation_ds_vertex_base_2IvEEEEEENS0_34Delaunay_triangulation_face_base_2IS3_NS_25Triangulation_face_base_2IS7_NS_28Triangulation_ds_face_base_2IvEEEEEEEEEEEESM_NS0_39Delaunay_triangulation_default_traits_2IS3_SM_EEEES7_NS0_11Qt_widget_2INS0_17Default_simulatorINS3_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINSV_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENSV_16Sturm_root_stackINSV_23Sturm_root_stack_traitsIS11_EEEES10_EELb0ELj8EEEEEEEE4drawERNS_9Qt_widgetEd[_ZNK4CGAL7Kinetic18Qt_triangulation_2INS0_24Delaunay_triangulation_2INS0_23Exact_simulation_traitsENS0_45Delaunay_triangulation_recent_edges_visitor_2INS_24Delaunay_triangulation_2INS0_28Default_instantaneous_kernelIS3_EENS_30Triangulation_data_structure_2INS0_36Delaunay_triangulation_vertex_base_2IS7_NS_27Triangulation_vertex_base_2IS7_NS_30Triangulation_ds_vertex_base_2IvEEEEEENS0_34Delaunay_triangulation_face_base_2IS3_NS_25Triangulation_face_base_2IS7_NS_28Triangulation_ds_face_base_2IvEEEEEEEEEEEESM_NS0_39Delaunay_triangulation_default_traits_2IS3_SM_EEEES7_NS0_11Qt_widget_2INS0_17Default_simulatorINS3_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINSV_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENSV_16Sturm_root_stackINSV_23Sturm_root_stack_traitsIS11_EEEES10_EELb0ELj8EEEEEEEE4drawERNS_9Qt_widgetEd]+0x377):
KDS_Delaunay_triangulation_2.cpp:(.text._ZNK4CGAL7Kinetic18Qt_triangulation_2INS0_24Delaunay_triangulation_2INS0_23Exact_simulation_traitsENS0_45Delaunay_triangulation_recent_edges_visitor_2INS_24Delaunay_triangulation_2INS0_28Default_instantaneous_kernelIS3_EENS_30Triangulation_data_structure_2INS0_36Delaunay_triangulation_vertex_base_2IS7_NS_27Triangulation_vertex_base_2IS7_NS_30Triangulation_ds_vertex_base_2IvEEEEEENS0_34Delaunay_triangulation_face_base_2IS3_NS_25Triangulation_face_base_2IS7_NS_28Triangulation_ds_face_base_2IvEEEEEEEEEEEESM_NS0_39Delaunay_triangulation_default_traits_2IS3_SM_EEEES7_NS0_11Qt_widget_2INS0_17Default_simulatorINS3_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINSV_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENSV_16Sturm_root_stackINSV_23Sturm_root_stack_traitsIS11_EEEES10_EELb0ELj8EEEEEEEE4drawERNS_9Qt_widgetEd[_ZNK4CGAL7Kinetic18Qt_triangulation_2INS0_24Delaunay_triangulation_2INS0_23Exact_simulation_traitsENS0_45Delaunay_triangulation_recent_edges_visitor_2INS_24Delaunay_triangulation_2INS0_28Default_instantaneous_kernelIS3_EENS_30Triangulation_data_structure_2INS0_36Delaunay_triangulation_vertex_base_2IS7_NS_27Triangulation_vertex_base_2IS7_NS_30Triangulation_ds_vertex_base_2IvEEEEEENS0_34Delaunay_triangulation_face_base_2IS3_NS_25Triangulation_face_base_2IS7_NS_28Triangulation_ds_face_base_2IvEEEEEEEEEEEESM_NS0_39Delaunay_triangulation_default_traits_2IS3_SM_EEEES7_NS0_11Qt_widget_2INS0_17Default_simulatorINS3_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINSV_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENSV_16Sturm_root_stackINSV_23Sturm_root_stack_traitsIS11_EEEES10_EELb0ELj8EEEEEEEE4drawERNS_9Qt_widgetEd]+0x389):
KDS_Delaunay_triangulation_2.cpp:(.text._ZNK4CGAL7Kinetic18Qt_triangulation_2INS0_24Delaunay_triangulation_2INS0_23Exact_simulation_traitsENS0_45Delaunay_triangulation_recent_edges_visitor_2INS_24Delaunay_triangulation_2INS0_28Default_instantaneous_kernelIS3_EENS_30Triangulation_data_structure_2INS0_36Delaunay_triangulation_vertex_base_2IS7_NS_27Triangulation_vertex_base_2IS7_NS_30Triangulation_ds_vertex_base_2IvEEEEEENS0_34Delaunay_triangulation_face_base_2IS3_NS_25Triangulation_face_base_2IS7_NS_28Triangulation_ds_face_base_2IvEEEEEEEEEEEESM_NS0_39Delaunay_triangulation_default_traits_2IS3_SM_EEEES7_NS0_11Qt_widget_2INS0_17Default_simulatorINS3_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINSV_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENSV_16Sturm_root_stackINSV_23Sturm_root_stack_traitsIS11_EEEES10_EELb0ELj8EEEEEEEE4drawERNS_9Qt_widgetEd[_ZNK4CGAL7Kinetic18Qt_triangulation_2INS0_24Delaunay_triangulation_2INS0_23Exact_simulation_traitsENS0_45Delaunay_triangulation_recent_edges_visitor_2INS_24Delaunay_triangulation_2INS0_28Default_instantaneous_kernelIS3_EENS_30Triangulation_data_structure_2INS0_36Delaunay_triangulation_vertex_base_2IS7_NS_27Triangulation_vertex_base_2IS7_NS_30Triangulation_ds_vertex_base_2IvEEEEEENS0_34Delaunay_triangulation_face_base_2IS3_NS_25Triangulation_face_base_2IS7_NS_28Triangulation_ds_face_base_2IvEEEEEEEEEEEESM_NS0_39Delaunay_triangulation_default_traits_2IS3_SM_EEEES7_NS0_11Qt_widget_2INS0_17Default_simulatorINS3_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINSV_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENSV_16Sturm_root_stackINSV_23Sturm_root_stack_traitsIS11_EEEES10_EELb0ELj8EEEEEEEE4drawERNS_9Qt_widgetEd]+0x39d):
KDS_Delaunay_triangulation_2.cpp:(.text._ZNK4CGAL7Kinetic18Qt_triangulation_2INS0_24Delaunay_triangulation_2INS0_23Exact_simulation_traitsENS0_45Delaunay_triangulation_recent_edges_visitor_2INS_24Delaunay_triangulation_2INS0_28Default_instantaneous_kernelIS3_EENS_30Triangulation_data_structure_2INS0_36Delaunay_triangulation_vertex_base_2IS7_NS_27Triangulation_vertex_base_2IS7_NS_30Triangulation_ds_vertex_base_2IvEEEEEENS0_34Delaunay_triangulation_face_base_2IS3_NS_25Triangulation_face_base_2IS7_NS_28Triangulation_ds_face_base_2IvEEEEEEEEEEEESM_NS0_39Delaunay_triangulation_default_traits_2IS3_SM_EEEES7_NS0_11Qt_widget_2INS0_17Default_simulatorINS3_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINSV_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENSV_16Sturm_root_stackINSV_23Sturm_root_stack_traitsIS11_EEEES10_EELb0ELj8EEEEEEEE4drawERNS_9Qt_widgetEd[_ZNK4CGAL7Kinetic18Qt_triangulation_2INS0_24Delaunay_triangulation_2INS0_23Exact_simulation_traitsENS0_45Delaunay_triangulation_recent_edges_visitor_2INS_24Delaunay_triangulation_2INS0_28Default_instantaneous_kernelIS3_EENS_30Triangulation_data_structure_2INS0_36Delaunay_triangulation_vertex_base_2IS7_NS_27Triangulation_vertex_base_2IS7_NS_30Triangulation_ds_vertex_base_2IvEEEEEENS0_34Delaunay_triangulation_face_base_2IS3_NS_25Triangulation_face_base_2IS7_NS_28Triangulation_ds_face_base_2IvEEEEEEEEEEEESM_NS0_39Delaunay_triangulation_default_traits_2IS3_SM_EEEES7_NS0_11Qt_widget_2INS0_17Default_simulatorINS3_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINSV_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENSV_16Sturm_root_stackINSV_23Sturm_root_stack_traitsIS11_EEEES10_EELb0ELj8EEEEEEEE4drawERNS_9Qt_widgetEd]+0x3b2):
KDS_Delaunay_triangulation_2.cpp:(.text._ZNK4CGAL7Kinetic18Qt_triangulation_2INS0_24Delaunay_triangulation_2INS0_23Exact_simulation_traitsENS0_45Delaunay_triangulation_recent_edges_visitor_2INS_24Delaunay_triangulation_2INS0_28Default_instantaneous_kernelIS3_EENS_30Triangulation_data_structure_2INS0_36Delaunay_triangulation_vertex_base_2IS7_NS_27Triangulation_vertex_base_2IS7_NS_30Triangulation_ds_vertex_base_2IvEEEEEENS0_34Delaunay_triangulation_face_base_2IS3_NS_25Triangulation_face_base_2IS7_NS_28Triangulation_ds_face_base_2IvEEEEEEEEEEEESM_NS0_39Delaunay_triangulation_default_traits_2IS3_SM_EEEES7_NS0_11Qt_widget_2INS0_17Default_simulatorINS3_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINSV_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENSV_16Sturm_root_stackINSV_23Sturm_root_stack_traitsIS11_EEEES10_EELb0ELj8EEEEEEEE4drawERNS_9Qt_widgetEd[_ZNK4CGAL7Kinetic18Qt_triangulation_2INS0_24Delaunay_triangulation_2INS0_23Exact_simulation_traitsENS0_45Delaunay_triangulation_recent_edges_visitor_2INS_24Delaunay_triangulation_2INS0_28Default_instantaneous_kernelIS3_EENS_30Triangulation_data_structure_2INS0_36Delaunay_triangulation_vertex_base_2IS7_NS_27Triangulation_vertex_base_2IS7_NS_30Triangulation_ds_vertex_base_2IvEEEEEENS0_34Delaunay_triangulation_face_base_2IS3_NS_25Triangulation_face_base_2IS7_NS_28Triangulation_ds_face_base_2IvEEEEEEEEEEEESM_NS0_39Delaunay_triangulation_default_traits_2IS3_SM_EEEES7_NS0_11Qt_widget_2INS0_17Default_simulatorINS3_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINSV_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENSV_16Sturm_root_stackINSV_23Sturm_root_stack_traitsIS11_EEEES10_EELb0ELj8EEEEEEEE4drawERNS_9Qt_widgetEd]+0x44a):
KDS_Delaunay_triangulation_2.cpp:(.text._ZNK4CGAL7Kinetic18Qt_triangulation_2INS0_24Delaunay_triangulation_2INS0_23Exact_simulation_traitsENS0_45Delaunay_triangulation_recent_edges_visitor_2INS_24Delaunay_triangulation_2INS0_28Default_instantaneous_kernelIS3_EENS_30Triangulation_data_structure_2INS0_36Delaunay_triangulation_vertex_base_2IS7_NS_27Triangulation_vertex_base_2IS7_NS_30Triangulation_ds_vertex_base_2IvEEEEEENS0_34Delaunay_triangulation_face_base_2IS3_NS_25Triangulation_face_base_2IS7_NS_28Triangulation_ds_face_base_2IvEEEEEEEEEEEESM_NS0_39Delaunay_triangulation_default_traits_2IS3_SM_EEEES7_NS0_11Qt_widget_2INS0_17Default_simulatorINS3_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINSV_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENSV_16Sturm_root_stackINSV_23Sturm_root_stack_traitsIS11_EEEES10_EELb0ELj8EEEEEEEE4drawERNS_9Qt_widgetEd[_ZNK4CGAL7Kinetic18Qt_triangulation_2INS0_24Delaunay_triangulation_2INS0_23Exact_simulation_traitsENS0_45Delaunay_triangulation_recent_edges_visitor_2INS_24Delaunay_triangulation_2INS0_28Default_instantaneous_kernelIS3_EENS_30Triangulation_data_structure_2INS0_36Delaunay_triangulation_vertex_base_2IS7_NS_27Triangulation_vertex_base_2IS7_NS_30Triangulation_ds_vertex_base_2IvEEEEEENS0_34Delaunay_triangulation_face_base_2IS3_NS_25Triangulation_face_base_2IS7_NS_28Triangulation_ds_face_base_2IvEEEEEEEEEEEESM_NS0_39Delaunay_triangulation_default_traits_2IS3_SM_EEEES7_NS0_11Qt_widget_2INS0_17Default_simulatorINS3_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINSV_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENSV_16Sturm_root_stackINSV_23Sturm_root_stack_traitsIS11_EEEES10_EELb0ELj8EEEEEEEE4drawERNS_9Qt_widgetEd]+0x524):
KDS_Delaunay_triangulation_2.cpp:(.text._ZNK4CGAL7Kinetic18Qt_triangulation_2INS0_24Delaunay_triangulation_2INS0_23Exact_simulation_traitsENS0_45Delaunay_triangulation_recent_edges_visitor_2INS_24Delaunay_triangulation_2INS0_28Default_instantaneous_kernelIS3_EENS_30Triangulation_data_structure_2INS0_36Delaunay_triangulation_vertex_base_2IS7_NS_27Triangulation_vertex_base_2IS7_NS_30Triangulation_ds_vertex_base_2IvEEEEEENS0_34Delaunay_triangulation_face_base_2IS3_NS_25Triangulation_face_base_2IS7_NS_28Triangulation_ds_face_base_2IvEEEEEEEEEEEESM_NS0_39Delaunay_triangulation_default_traits_2IS3_SM_EEEES7_NS0_11Qt_widget_2INS0_17Default_simulatorINS3_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINSV_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENSV_16Sturm_root_stackINSV_23Sturm_root_stack_traitsIS11_EEEES10_EELb0ELj8EEEEEEEE4drawERNS_9Qt_widgetEd[_ZNK4CGAL7Kinetic18Qt_triangulation_2INS0_24Delaunay_triangulation_2INS0_23Exact_simulation_traitsENS0_45Delaunay_triangulation_recent_edges_visitor_2INS_24Delaunay_triangulation_2INS0_28Default_instantaneous_kernelIS3_EENS_30Triangulation_data_structure_2INS0_36Delaunay_triangulation_vertex_base_2IS7_NS_27Triangulation_vertex_base_2IS7_NS_30Triangulation_ds_vertex_base_2IvEEEEEENS0_34Delaunay_triangulation_face_base_2IS3_NS_25Triangulation_face_base_2IS7_NS_28Triangulation_ds_face_base_2IvEEEEEEEEEEEESM_NS0_39Delaunay_triangulation_default_traits_2IS3_SM_EEEES7_NS0_11Qt_widget_2INS0_17Default_simulatorINS3_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINSV_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENSV_16Sturm_root_stackINSV_23Sturm_root_stack_traitsIS11_EEEES10_EELb0ELj8EEEEEEEE4drawERNS_9Qt_widgetEd]+0x662):
KDS_Delaunay_triangulation_2.cpp:(.text._ZNK4CGAL7Kinetic18Qt_triangulation_2INS0_24Delaunay_triangulation_2INS0_23Exact_simulation_traitsENS0_45Delaunay_triangulation_recent_edges_visitor_2INS_24Delaunay_triangulation_2INS0_28Default_instantaneous_kernelIS3_EENS_30Triangulation_data_structure_2INS0_36Delaunay_triangulation_vertex_base_2IS7_NS_27Triangulation_vertex_base_2IS7_NS_30Triangulation_ds_vertex_base_2IvEEEEEENS0_34Delaunay_triangulation_face_base_2IS3_NS_25Triangulation_face_base_2IS7_NS_28Triangulation_ds_face_base_2IvEEEEEEEEEEEESM_NS0_39Delaunay_triangulation_default_traits_2IS3_SM_EEEES7_NS0_11Qt_widget_2INS0_17Default_simulatorINS3_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINSV_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENSV_16Sturm_root_stackINSV_23Sturm_root_stack_traitsIS11_EEEES10_EELb0ELj8EEEEEEEE4drawERNS_9Qt_widgetEd[_ZNK4CGAL7Kinetic18Qt_triangulation_2INS0_24Delaunay_triangulation_2INS0_23Exact_simulation_traitsENS0_45Delaunay_triangulation_recent_edges_visitor_2INS_24Delaunay_triangulation_2INS0_28Default_instantaneous_kernelIS3_EENS_30Triangulation_data_structure_2INS0_36Delaunay_triangulation_vertex_base_2IS7_NS_27Triangulation_vertex_base_2IS7_NS_30Triangulation_ds_vertex_base_2IvEEEEEENS0_34Delaunay_triangulation_face_base_2IS3_NS_25Triangulation_face_base_2IS7_NS_28Triangulation_ds_face_base_2IvEEEEEEEEEEEESM_NS0_39Delaunay_triangulation_default_traits_2IS3_SM_EEEES7_NS0_11Qt_widget_2INS0_17Default_simulatorINS3_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINSV_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENSV_16Sturm_root_stackINSV_23Sturm_root_stack_traitsIS11_EEEES10_EELb0ELj8EEEEEEEE4drawERNS_9Qt_widgetEd]+0x695):
KDS_Delaunay_triangulation_2.cpp:(.text._ZNK4CGAL7Kinetic18Qt_triangulation_2INS0_24Delaunay_triangulation_2INS0_23Exact_simulation_traitsENS0_45Delaunay_triangulation_recent_edges_visitor_2INS_24Delaunay_triangulation_2INS0_28Default_instantaneous_kernelIS3_EENS_30Triangulation_data_structure_2INS0_36Delaunay_triangulation_vertex_base_2IS7_NS_27Triangulation_vertex_base_2IS7_NS_30Triangulation_ds_vertex_base_2IvEEEEEENS0_34Delaunay_triangulation_face_base_2IS3_NS_25Triangulation_face_base_2IS7_NS_28Triangulation_ds_face_base_2IvEEEEEEEEEEEESM_NS0_39Delaunay_triangulation_default_traits_2IS3_SM_EEEES7_NS0_11Qt_widget_2INS0_17Default_simulatorINS3_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINSV_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENSV_16Sturm_root_stackINSV_23Sturm_root_stack_traitsIS11_EEEES10_EELb0ELj8EEEEEEEE4drawERNS_9Qt_widgetEd[_ZNK4CGAL7Kinetic18Qt_triangulation_2INS0_24Delaunay_triangulation_2INS0_23Exact_simulation_traitsENS0_45Delaunay_triangulation_recent_edges_visitor_2INS_24Delaunay_triangulation_2INS0_28Default_instantaneous_kernelIS3_EENS_30Triangulation_data_structure_2INS0_36Delaunay_triangulation_vertex_base_2IS7_NS_27Triangulation_vertex_base_2IS7_NS_30Triangulation_ds_vertex_base_2IvEEEEEENS0_34Delaunay_triangulation_face_base_2IS3_NS_25Triangulation_face_base_2IS7_NS_28Triangulation_ds_face_base_2IvEEEEEEEEEEEESM_NS0_39Delaunay_triangulation_default_traits_2IS3_SM_EEEES7_NS0_11Qt_widget_2INS0_17Default_simulatorINS3_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINSV_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENSV_16Sturm_root_stackINSV_23Sturm_root_stack_traitsIS11_EEEES10_EELb0ELj8EEEEEEEE4drawERNS_9Qt_widgetEd]+0x6d1):
KDS_Delaunay_triangulation_2.cpp:(.text._ZNK4CGAL7Kinetic18Qt_triangulation_2INS0_24Delaunay_triangulation_2INS0_23Exact_simulation_traitsENS0_45Delaunay_triangulation_recent_edges_visitor_2INS_24Delaunay_triangulation_2INS0_28Default_instantaneous_kernelIS3_EENS_30Triangulation_data_structure_2INS0_36Delaunay_triangulation_vertex_base_2IS7_NS_27Triangulation_vertex_base_2IS7_NS_30Triangulation_ds_vertex_base_2IvEEEEEENS0_34Delaunay_triangulation_face_base_2IS3_NS_25Triangulation_face_base_2IS7_NS_28Triangulation_ds_face_base_2IvEEEEEEEEEEEESM_NS0_39Delaunay_triangulation_default_traits_2IS3_SM_EEEES7_NS0_11Qt_widget_2INS0_17Default_simulatorINS3_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINSV_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENSV_16Sturm_root_stackINSV_23Sturm_root_stack_traitsIS11_EEEES10_EELb0ELj8EEEEEEEE4drawERNS_9Qt_widgetEd[_ZNK4CGAL7Kinetic18Qt_triangulation_2INS0_24Delaunay_triangulation_2INS0_23Exact_simulation_traitsENS0_45Delaunay_triangulation_recent_edges_visitor_2INS_24Delaunay_triangulation_2INS0_28Default_instantaneous_kernelIS3_EENS_30Triangulation_data_structure_2INS0_36Delaunay_triangulation_vertex_base_2IS7_NS_27Triangulation_vertex_base_2IS7_NS_30Triangulation_ds_vertex_base_2IvEEEEEENS0_34Delaunay_triangulation_face_base_2IS3_NS_25Triangulation_face_base_2IS7_NS_28Triangulation_ds_face_base_2IvEEEEEEEEEEEESM_NS0_39Delaunay_triangulation_default_traits_2IS3_SM_EEEES7_NS0_11Qt_widget_2INS0_17Default_simulatorINS3_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINSV_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENSV_16Sturm_root_stackINSV_23Sturm_root_stack_traitsIS11_EEEES10_EELb0ELj8EEEEEEEE4drawERNS_9Qt_widgetEd]+0x742):
In function
CGAL::Kinetic::Qt_widget_2<CGAL::Kinetic::Default_simulator<CGAL::Kinetic::Exact_simulation_traits::Simulator_function_kernel,
CGAL::Kinetic::Two_list_pointer_event_queue<CGAL::POLYNOMIAL::Kernel<CGAL::POLYNOMIAL::Polynomial<CGAL::Lazy_exact_nt<CGAL::Gmpq>
CGAL::POLYNOMIAL::Sturm_root_stack<CGAL::POLYNOMIAL::Sturm_root_stack_traits<CGAL::POLYNOMIAL::Polynomial<CGAL::Lazy_exact_nt<CGAL::Gmpq>
>::Qt_gui_listener::new_notification(CGAL::Kinetic::Qt_widget_2<CGAL::Kinetic::Default_simulator<CGAL::Kinetic::Exact_simulation_traits::Simulator_function_kernel,
>::Listener_core::Notification_type)':
KDS_Delaunay_triangulation_2.cpp:(.text._ZN4CGAL7Kinetic18Qt_triangulation_2INS0_24Delaunay_triangulation_2INS0_23Exact_simulation_traitsENS0_45Delaunay_triangulation_recent_edges_visitor_2INS_24Delaunay_triangulation_2INS0_28Default_instantaneous_kernelIS3_EENS_30Triangulation_data_structure_2INS0_36Delaunay_triangulation_vertex_base_2IS7_NS_27Triangulation_vertex_base_2IS7_NS_30Triangulation_ds_vertex_base_2IvEEEEEENS0_34Delaunay_triangulation_face_base_2IS3_NS_25Triangulation_face_base_2IS7_NS_28Triangulation_ds_face_base_2IvEEEEEEEEEEEESM_NS0_39Delaunay_triangulation_default_traits_2IS3_SM_EEEES7_NS0_11Qt_widget_2INS0_17Default_simulatorINS3_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINSV_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENSV_16Sturm_root_stackINSV_23Sturm_root_stack_traitsIS11_EEEES10_EELb0ELj8EEEEEEEE15Qt_gui_listener16new_notificationENS19_13Listener_core17Notification_typeE[_ZN4CGAL7Kinetic18Qt_triangulation_2INS0_24Delaunay_triangulation_2INS0_23Exact_simulation_traitsENS0_45Delaunay_triangulation_recent_edges_visitor_2INS_24Delaunay_triangulation_2INS0_28Default_instantaneous_kernelIS3_EENS_30Triangulation_data_structure_2INS0_36Delaunay_triangulation_vertex_base_2IS7_NS_27Triangulation_vertex_base_2IS7_NS_30Triangulation_ds_vertex_base_2IvEEEEEENS0_34Delaunay_triangulation_face_base_2IS3_NS_25Triangulation_face_base_2IS7_NS_28Triangulation_ds_face_base_2IvEEEEEEEEEEEESM_NS0_39Delaunay_triangulation_default_traits_2IS3_SM_EEEES7_NS0_11Qt_widget_2INS0_17Default_simulatorINS3_25Simulator_function_kernelENS0_28Two_list_pointer_event_queueINS_10POLYNOMIAL6KernelINSV_10PolynomialINS_13Lazy_exact_ntINS_4GmpqEEEEENSV_16Sturm_root_stackINSV_23Sturm_root_stack_traitsIS11_EEEES10_EELb0ELj8EEEEEEEE15Qt_gui_listener16new_notificationENS19_13Listener_core17Notification_typeE]+0x1d):
undefined reference to `QApplication::main_widget'
CMakeFiles/KDS_Delaunay_triangulation_2.dir/KDS_Delaunay_triangulation_2.cpp.o:(.rodata._ZTI6QGList[_ZTI6QGList]+0x10):
undefined reference to `typeinfo for QPtrCollection'
CMakeFiles/KDS_Delaunay_triangulation_2.dir/KDS_Delaunay_triangulation_2.cpp.o:(.rodata._ZTV6QGList[_ZTV6QGList]+0x18):
undefined reference to `QGList::clear()'
CMakeFiles/KDS_Delaunay_triangulation_2.dir/KDS_Delaunay_triangulation_2.cpp.o:(.rodata._ZTV6QGList[_ZTV6QGList]+0x20):
undefined reference to `QGList::~QGList()'
CMakeFiles/KDS_Delaunay_triangulation_2.dir/KDS_Delaunay_triangulation_2.cpp.o:(.rodata._ZTV6QGList[_ZTV6QGList]+0x28):
CMakeFiles/KDS_Delaunay_triangulation_2.dir/KDS_Delaunay_triangulation_2.cpp.o:(.rodata._ZTV6QGList[_ZTV6QGList]+0x30):
undefined reference to `QPtrCollection::newItem(void*)'
CMakeFiles/KDS_Delaunay_triangulation_2.dir/KDS_Delaunay_triangulation_2.cpp.o:(.rodata._ZTV6QGList[_ZTV6QGList]+0x40):
undefined reference to `QGList::compareItems(void*, void*)'
CMakeFiles/KDS_Delaunay_triangulation_2.dir/KDS_Delaunay_triangulation_2.cpp.o:(.rodata._ZTV6QGList[_ZTV6QGList]+0x48):
undefined reference to `QGList::read(QDataStream&, void*&)'
CMakeFiles/KDS_Delaunay_triangulation_2.dir/KDS_Delaunay_triangulation_2.cpp.o:(.rodata._ZTV6QGList[_ZTV6QGList]+0x50):
undefined reference to `QGList::write(QDataStream&, void*) const'
collect2: error: ld returned 1 exit status
make[2]: *** [KDS_Delaunay_triangulation_2] Error 1
make[1]: *** [CMakeFiles/KDS_Delaunay_triangulation_2.dir/all] Error 2
make: *** [all] Error 2
Laurent Rineau (CGAL/GeometryFactory) wrote
> Le Friday, November 3, 2017 7:56:04 AM CET Anjali Jose a ?crit :
>> Hi everyone!
>> I am new to CGAL. I am using CGAL-4.6.3 and I have qt4 in my system. I am
>> not able to compile the demos in the kinetic data structure package.
>> I am posting below the output of cmake and make
>> -- NOTICE: This demo requires Qt3 and the CGAL Qt3 library, and will not
>> be
>> compiled.
>> Can you please tell me how to rectify this?
>> Thanks a lot!
>> Anjali Jose
> CMake has already told you the hint: install Qt3 on your system, otherwise
> there is no chance you can build that demo.
> Laurent Rineau, PhD
> R&D Engineer at GeometryFactory http://www.geometryfactory.com/
> Release Manager of the CGAL Project http://www.cgal.org/
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://sympa.inria.fr/sympa/info/cgal-discuss
- [cgal-discuss] Problem compiling kinetic data structure demo, Anjali Jose, 11/03/2017
- Re: [cgal-discuss] Problem compiling kinetic data structure demo, Laurent Rineau (CGAL/GeometryFactory), 11/03/2017
- Re: [cgal-discuss] Problem compiling kinetic data structure demo, Anjali Jose, 11/04/2017
- Re: [cgal-discuss] Problem compiling kinetic data structure demo, Biswajit Biswas, 11/04/2017
- Re: [cgal-discuss] Problem compiling kinetic data structure demo, Laurent Rineau (CGAL/GeometryFactory), 11/06/2017
