- To:
- Subject: [cgal-discuss] Face around vertex circulator
- Date: Mon, 6 Nov 2017 07:05:45 -0700 (MST)
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
- Ironport-phdr: 9a23:EWu+VRPG6+3vAgdI2LAl6mtUPXoX/o7sNwtQ0KIMzox0K/vzrarrMEGX3/hxlliBBdydsK0UzbeO+4nbGkU+or+5+EgYd5JNUxJXwe43pCcHRPC/NEvgMfTxZDY7FskRHHVs/nW8LFQHUJ2mPw6alFTps29XQ023dVEtfqWmUrLV2s+43uT395zIaBhTnxK8Z6lzJVO4t1b/rM4T1I9/KaUwzVOdpmZDcqJZzGxsJFuVmFClt5fg1JFm+iVU/fkm8pgTAu3BY60kQOkBX3wdOGcv6Ziw7UHO
Hi,
I have an object of class "SurfaceMesh" and I'm iterating through all the
vertices, for given vertex "V" i need to iterate through all the faces
incident in "V". I came across to CGAL::Face_around_target_circulator, but
I'm not entirely sure how to use it, I can't find any snippet showing how to
use it.
Can you provide any example of simple navigation using circulator?
(Specifically faces around vertex).
Thank you
- [cgal-discuss] Face around vertex circulator, lukkio, 11/06/2017
- Re: [cgal-discuss] Face around vertex circulator, lukkio, 11/07/2017
- Re: [cgal-discuss] Face around vertex circulator, MaelRL, 11/07/2017
- Re: [cgal-discuss] Face around vertex circulator, Luca Gagliano, 11/07/2017
