cgal-discuss - Re: [cgal-discuss] Turn off CGAL assertions
  • To:
  • Subject: Re: [cgal-discuss] Turn off CGAL assertions
  • Date: Fri, 10 Nov 2017 10:03:18 -0800
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23:YgQc3hEiun9Q90on4P/5rZ1GYnF86YWxBRYc798ds5kLTJ75psuwAkXT6L1XgUPTWs2DsrQf1LqQ7viocFdDyKjCmUhKSIZLWR4BhJdetC0bK+nBN3fGKuX3ZTcxBsVIWQwt1Xi6NU9IBJS2PAWK8TXhpQMUAQj1YAppOvzuSMmVlNWyz+n0+pvJYgwOiiD6eqJ3NBzxrAPfsY4djoJmb6ow0RDUuWAbR+MDzmxhIRefng33+9yr1J9l6SVZ/fw7pOBaVqCvVqgxSPR3ASgtM20x4IW/vBXKSE2A62cXUmgSljJHBgHE6FfxWZKn4XiyjfZ0xCTPZZ6+drszQzn3t6o=
Hi Marc,
Thanks for the suggestion!
Neither:
set(CGAL_NO_ASSERTIONS TRUE CACHE BOOL “Turn off Triangulation checks” FORCE)
Nor:
set(CGAL_TRIANGULATION_NO_ASSERTIONS CACHE BOOL “Turn off Triangulation checks” FORCE)
Prevent:
CGAL error: assertion violation!
_expression_ : false
File       : /usr/local/include/CGAL/Delaunay_triangulation_3.h
Line       : 1973
Explanation:
Refer to the bug-reporting instructions at http://www.cgal.org/bug_report.html
If I run in release mode (NDEBUG), that does work. Unfortunately, it also prevents me from interactively debugging my code.
Am I missing something?
Cheers,
Adam
On Thu, 9 Nov 2017, Adam Getchell wrote:
Hello all,
I’m trying to turn off the following:
Line       : 1973
Which, I believe, relates to the triangulation not being Delaunay after the flip.
I’ve read over https://doc.cgal.org/latest/Manual/devman_checks.html and added the following to CMakeLists in order to turn off all the checks:
set(CGAL_NDEBUG "Turn off all checks")
That hasn’t worked. Do I have to compile CGAL with this flag?
Just use NDEBUG instead? CGAL_NO_ASSERTIONS or CGAL_TRIANGULATION_NO_ASSERTIONS should work as well.
Marc Glisse
