cgal-discuss - Re: [cgal-discuss] How to obtain the list of intersecting segments ?
  • To:
  • Subject: Re: [cgal-discuss] How to obtain the list of intersecting segments ?
  • Date: Sat, 11 Nov 2017 17:30:59 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23:mcVrpBxme6YgtSDXCy+O+j09IxM/srCxBDY+r6Qd0u8TIJqq85mqBkHD//Il1AaPBtqLra8cw8Pt8IneGkU4qa6bt34DdJEeHzQksu4x2zIaPcieFEfgJ+TrZSFpVO5LVVti4m3peRMNQJW2NBXupSi54jcWXxn+LgFoPf/dG4jIjs3x2frh1YfUZlBlijv1T7R9IRH++Qjft8cRjoZmAqk0wxrN5HBPfrIFlitTOVuPkkOktY+L95l5/nEItg==
Indeed, Arrangement_with_history_2 is a generic data structure that you can use to solve the problem.
Define an object of a type that is an instance of Arrangement_with_history_2<Traits, Dcel>. Then, insert all the curves into the arrangement. Finally, iterate over the vertices of the arrangement. You can query the degree of a visited vertex to filter out vertices associated with non-intersection points. Also, you can obtain the incident edges to get the inducing curves.
   ____  _        ____             _
  /_____/_) o    /__________  __  //
 (____ (   (    (    (_/ (_/-(-'_(/
                         _/
On 8 November 2017 at 19:01, Nicolas CHARVIN <> wrote:
Hello,
[Disclaimenr: I am a brand new CGAL user, and C++ isn't my main programming language]
I am currently performing simulation on nanowires networks.
So, within a large number N of random segments, I need to detect for each segment which segments it is intersecting.
Naive implementation works well, but of course in O(N2).
I wish I could use sweepline algorithms to perform this way faster, as described in the example "sweep_line.cpp". It works really fast (up to 100,000 segments) but unfortunately, "compute_intersection_points" only return the intersections points, not the two segments involved.
Searching in the list, I found that some people need the same thing in 2012: https://sympa.inria.fr/sympa/arc/cgal-discuss/2012-11/msg00149.html
It has been told in the thread that "
Arrangement_with_history_2" might do the trick. But I have no idea what it means.
Does anyone have any hints to help ?
Regards,
Nicolas
Universite Savoie Mont Blanc
Nicolas CHARVIN
Laboratoire LEPMI - équipe LMOPS / Bât Helios, 60 av du Lac Leman - 73370 Le Bourget du Lac
+33 4 79 75 87 91
Facebook Twitter vimeo   www.univ-smb.fr
Un geste simple pour l'environnement, n'imprimez ce message que si vous en avez l'utilité.
