- To:
- Subject: Re: [cgal-discuss] Want to learn more about mesh processing. Please help.
- Date: Tue, 21 Nov 2017 01:44:57 -0700 (MST)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=None ; spf=Pass
- Ironport-phdr: 9a23:cpfYnRxzp+75Ny3XCy+O+j09IxM/srCxBDY+r6Qd0u0XIJqq85mqBkHD//Il1AaPBtqLra8cw8Pt8IneGkU4qa6bt34DdJEeHzQksu4x2zIaPcieFEfgJ+TrZSFpVO5LVVti4m3peRMNQJW2NBXupSi54jcWXxn+LgFoPf/dG4jIjs3x2frh1YfUZlBtjTe5W5c6eBC/oAGXrM4LkYZmbKI4wBHEinRFfOFb2Xl5K1uYgxHm94G7+5s1oHcYgO4o68MVCfayRK8/V7ENVDk=
Hello,
The bibliography of the Polygon Mesh Processing package contains some
references that you can use:
https://doc.cgal.org/latest/Polygon_mesh_processing/citelist.html
- [cgal-discuss] Want to learn more about mesh processing. Please help., Hush Hush, 11/21/2017
- Re: [cgal-discuss] Want to learn more about mesh processing. Please help., MaelRL, 11/21/2017
